Mopar Performance Pistons P5249907 Specs #3118915
02/04/23 07:08 PM
02/04/23 07:08 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
These pistons are for an AMC 360 but were discontinued 20-ish years ago from what I've been told. I'm looking for the specs but haven't been able to find any information.
Anyone know where I can find the specs for these?
Re: Mopar Performance Pistons P5249907 Specs [Re: VITC_GTX] #3119108
02/05/23 03:09 PM
02/05/23 03:09 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Found a bit of info on a jeep forum JEEP FORUM
might want to snoop around jeep engine builders and or forums, or find an old MP catalog from that era beer
Re: Mopar Performance Pistons P5249907 Specs [Re: TJP] #3119139
02/05/23 05:11 PM
02/05/23 05:11 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks for the link and the idea. I had seen that thread but unfortunately it doesn't list compression height. I was going to try and calculate compression with these, without actual measurements (depth in hole, cc heads). I adopted a complete, rebuilt 360 with these pistons (used a bore scope to see part number those spark plug hole). I may just tear the engine apart and measure, probably a good idea anyway since I didn't bolt it together.
Re: Mopar Performance Pistons P5249907 Specs [Re: VITC_GTX] #3119205
02/05/23 09:48 PM
02/05/23 09:48 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree beer
Re: Mopar Performance Pistons P5249907 Specs [Re: VITC_GTX] #3173202
09/05/23 07:14 PM
09/05/23 07:14 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
It's been 7 months so I thought I would bring this back up to the top.
I've googled this but haven't found much. Anyone have any other information they could share? Maybe you have an old Mopar Performance catalog that covers the AMCs?
Re: Mopar Performance Pistons P5249907 Specs [Re: VITC_GTX] #3173337
09/06/23 12:55 PM
09/06/23 12:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have a 2002 MP catalog , nothing in it .
Re: Mopar Performance Pistons P5249907 Specs [Re: JohnRR] #3173365
09/06/23 02:34 PM
09/06/23 02:34 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
If the number is stamped on the piston, it's more than likely just an engineering number.
The packaged kit with wrist pins and a decal, most times (not always)....would fall under a different, unrelated part number.
It Can be difficult to figure out.
If it is a forging, most of the ancient P5249 series were supplied by Wiseco, and Wiseco may still have some data on them
Rich H.
Esse Quam Videri
