If the number is stamped on the piston, it's more than likely just an engineering number.
The packaged kit with wrist pins and a decal, most times (not always)....would fall under a different, unrelated part number.
It Can be difficult to figure out.
If it is a forging, most of the ancient P5249 series were supplied by Wiseco, and Wiseco may still have some data on them
Rich H.
Esse Quam Videri
