oil pan gaskets #3172427
09/02/23 06:53 PM
09/02/23 06:53 PM
BlueRacer69 Offline OP
Hey Guy's recommend me a good oil pan gasket. What's good and what's crap these days. Actually I need 2 gaskets because of the windage tray. 1969 440 motor. 893 oil pan. Thanks.
Re: oil pan gaskets [Re: BlueRacer69] #3172430
09/02/23 07:10 PM
09/02/23 07:10 PM
MI
I
IROC78 Offline
IROC78  Offline
I
MI
Within the last six months I have used both the Hughes 3420S gasket ($10.75) and the Milodon 40700 ($23.99) and was very pleased with both. I used the Hughes gasket on the first engine I assembled and would have used it again but time was an issue and I was able to find the Milodon in stock locally without having to wait to have one shipped. I would recommend either though as they were both quality pieces .
Re: oil pan gaskets [Re: BlueRacer69] #3172481
09/03/23 12:46 AM
09/03/23 12:46 AM
SCE cork/rubber gaskets work very well up scope
Re: oil pan gaskets [Re: Cab_Burge] #3172503
09/03/23 08:39 AM
09/03/23 08:39 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
The mahle cork with metal center OS31416TC is my fav.
2nd fel-pro black fiber ones 1808
Re: oil pan gaskets [Re: B1MAXX] #3172532
09/03/23 10:24 AM
09/03/23 10:24 AM
Do you use any type of gasket sealer on these Fel-pro 1808s. If so what's your favorite. Many thanks.
Re: oil pan gaskets [Re: BlueRacer69] #3172571
09/03/23 12:56 PM
09/03/23 12:56 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Ultra grey or ultra black.
Re: oil pan gaskets [Re: B1MAXX] #3172582
09/03/23 01:49 PM
09/03/23 01:49 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
X2 wink
Re: oil pan gaskets [Re: B1MAXX] #3172621
09/03/23 04:40 PM
09/03/23 04:40 PM
Thanks guys. I have a tube of the Permatex Ultra Black in my tool box. Many Thanks.
Re: oil pan gaskets [Re: BlueRacer69] #3172897
09/04/23 05:22 PM
09/04/23 05:22 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I used one of these on the last 440 I built and I won't go back to the 2 gaskets and tray mess.
https://www.summitracing.com/parts/sum-g2339/make/dodge
Gus beer
64 Plymouth Savoy
Dana 60
Re: oil pan gaskets [Re: fourgearsavoy] #3173213
09/05/23 08:06 PM
09/05/23 08:06 PM
PA
moparacer Online content
moparacer  Online Content
PA
I never used them on stock pans, but the Superformance gaskets are the best I have ever used on windage trays and milodon pans. I don't use any RTV and have reused them over and over.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: oil pan gaskets [Re: BlueRacer69] #3173240
09/06/23 12:09 AM
09/06/23 12:09 AM
AndyF Offline
AndyF  Offline
Total crap shoot with a stock pan. With a pan that has a nice thick billet rail I use the Cometic gaskets since they'll seal up tight as a drum but with a flimsy steel pan you really have to be careful about using a "trick" gasket. A set of oil pan rail supports might help.
Re: oil pan gaskets [Re: fourgearsavoy] #3173244
09/06/23 03:53 AM
09/06/23 03:53 AM
Gus beer
I've used a couple of them also, no fed back from the customers yet work
I'll probably use one on the motor I'm putting together for myself to race on NOS with E85 next year, hopefully wrench luck
Re: oil pan gaskets [Re: fourgearsavoy] #3173330
09/06/23 12:39 PM
09/06/23 12:39 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Gus beer
Is that a solid tray like the original mopar trays ? If so is the tray part steel ? It really needs louvers like a milodon tray, or a one way screen center, to help the oil get back to the sump faster ...
Re: oil pan gaskets [Re: moparacer] #3174264
09/10/23 07:13 PM
09/10/23 07:13 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Same exact here
Repo 402 Oil Pan - Factory windage tray
Best oil pan gaskets made
Not one drop in years
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: oil pan gaskets [Re: BlueRacer69] #3174294
09/10/23 09:58 PM
09/10/23 09:58 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I just posted this on the radiator hose leak question, but it's SO much more appropriate here up whistling
Forget all that hi tech stuff and try this:
Had a friend years ago. He built his own deep sump pan and put the drain plug on the BOTTOM. ( that really didn't matter as the pan was TOO low anyway). He installed the the pan, windage tray ( 440) and gaskets with 3m's YELLOW DEATH weather-strip adhesive. as he was told it was the best sealant to prevent leaks
Of course the first dip in the road took out the drain plug.
I will never forget him hanging under the car with two long prybars swearing while trying to get the pan off 🤣🤣.
When he finally did after quite some time, the pan and windage tray were destroyed. He then had to get the remains off the block with scrapers and solvents. Don't think he ever used that stuff for gaskets again beer
