drilling the yoke for u bolts #3171818
08/31/23 09:11 AM
08/31/23 09:11 AM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
Picked up some strange solid 7260 u joints to replace the hollow ones I have,good idea. I picked up a u bolt kit to replace the straps but not sure if there is enough meat on the yoke. Is this a worthy adventure and anybody do it? seems like a popular mod with the jeep crowd Steve
Re: drilling the yoke for u bolts [Re: stinger] #3171825
08/31/23 09:28 AM
08/31/23 09:28 AM
an8sec70cuda Offline
I would not. If you really want U bolts, get the appropriate yoke. Having said that, if you're still using 7260 U joints, you probably don't need to change anything. I ran in the low 11s and high 10s at 3700 lbs w/ the stock style straps and never had an issue, but that was w/ 7290 U joints.
I'm not sure how fast your car is or what combination you're running though. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: drilling the yoke for u bolts [Re: stinger] #3171885
08/31/23 02:35 PM
08/31/23 02:35 PM
Don't do that tskI did that once realcrazy whineyIt failed puke
The stock CORRECT straps and bolts are a lot stronger on retaining the U joints cups in the pinion yokes than the after market U bolts kits are up twocents
Mopar design the pinion yoke to have the U joint cup inserted more than 50% in the yokes so the straps only hold the cups back into the yoke, they are not adding strength to the U joints scope up wrench
Make sure the straps you have are for your U joint size, don't mix the 7260 straps with a 7290 U joint or visa versa tsk
The way to tell iif you have the correct straps for your U joint is they fit flush, not loose or bound up over the U joint cups scope wrench up
Re: drilling the yoke for u bolts [Re: Cab_Burge] #3172015
09/01/23 09:27 AM
09/01/23 09:27 AM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
Thanks Guy"s I passed on that mod, didn't look like a smart idea to me. Good t know the straps are a strong design but probably going to upgrade to 1350 driveshaft abd yoke over the winter beer
Re: drilling the yoke for u bolts [Re: stinger] #3172199
09/01/23 09:53 PM
09/01/23 09:53 PM
That is the correct way to do driveline upgrades with matching parts up wrench twocents
Re: drilling the yoke for u bolts [Re: Cab_Burge] #3172351
09/02/23 02:20 PM
09/02/23 02:20 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I know I,perials used the U bolts on the ones I had.I saved at least one to change the strap one on y 65.Cant remember what rear they used IIRC mine were 489s
Chrysler Firepower
Re: drilling the yoke for u bolts [Re: therocks] #3172426
09/02/23 06:53 PM
09/02/23 06:53 PM
sweden
carter Offline
carter  Offline
sweden
Yes! Imperials use U-bolts. I have a -742 house from a -67 Imperial.
Re: drilling the yoke for u bolts [Re: carter] #3172431
09/02/23 07:14 PM
09/02/23 07:14 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
What you are looking for is available new. Spicer 10025496 pinion yoke 7290 10 spline
https://www.rockauto.com/en/moreinfo.php?pk=8846484&cc=0&pt=16612&jsn=723&_nck=Ekt6BqBF1pwlXdx0gYlm1XyS%2BrEifIwv%2Fs4mYgfY8Hvof4U6uklzHi1pVrcI7%2FkMUzABBGieOHtrrcgM3yioi3jzTSwR1sdbqq1WlxbL9jDHcZcDKYR4PaP%2BhEUJNXCdiI1v0RY93BO%2BE7mLh%2FWtJwIqleWfqWghAgDMwM4sbB8hYme5sOq%2BBKgosMX%2BnAyfE3hnPAt4iqEdq%2FwmgLZ6A5IN7quz%2BlKBnQduYTgMVznU8P5jvKjxFgcjAoijsVlC3S%2Fzh%2B17qFK1EtgdantiCELyToAg2JDoCJj2u7RXAo0to7h%2FKLSS4IhvhhKjddXn9gXFly%2FygUqet3cSVFOvBqoUNNnY3%2BNk3XIs3tMc%2Bh7nl9TVpSdjzudop0JTHIy7
Re: drilling the yoke for u bolts [Re: carter] #3172505
09/03/23 08:55 AM
09/03/23 08:55 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
As I recall those Imperials one's aren't 7260 or 7290 though I want to say Spicer 1330.
Re: drilling the yoke for u bolts [Re: B1MAXX] #3172599
09/03/23 02:59 PM
09/03/23 02:59 PM
iagree, I think that is the correct I.D. up
Some of the street hemi 4 speed cars with Dana 60 had that yoke also work confused
