Semi Flat Black Paint
#3171989
09/01/23 12:58 AM
09/01/23 12:58 AM
Posts: 821 On the open road
Hrtbkr
On the open road
Hello- Back in the day, Krylon 1613 Semi Flat Black was the go-to paint for various finishes.
I'm having trouble finding Krylon at all, much less Semi Flat. And I learned neither Satin nor Semi-Gloss works.
Can anyone suggest alternatives?
While outside on the turnpike
They got this new hit tune
Where thrills become as cheap as gas
And gas as cheap as thrills
Re: Semi Flat Black Paint
[Re: A12]
#3172027
09/01/23 10:31 AM
09/01/23 10:31 AM
Posts: 10,719 North Dakota
6PakBee
North Dakota
This: Krylon K01613A00 Semi Flat Black according to the other brand car forums is the old Krylon 1613 and only available as "industrial" paint. Available at Granger, and most industrial supply places and Amazon and a few other online stores.
KRYLON® 1613 Industrial ACRYLI-QUIK™ Semi-Flat Black Acrylic Lacquer Paint, K01613A00
Hmm. I'd guess availability is somewhat limited because of the "l" word (lacquer).
[Re: Droop69]
#3172703
09/03/23 10:18 PM
09/03/23 10:18 PM
Posts: 21,511 N.E. OHIO, USA
A12
N.E. OHIO, USA
SEM trim black just works! Good stuff. Agree but if you have ever used Krylon 1613 Semi-Flat like for the behind the grille blackout or on anything or anywhere else there is a big, big difference between SEM or any other brand of trim paint and the original 1613 Semi-Flat. Trim paint is thin and has no real "meat" to it. That's just one point.
[Re: THESHAKERPROJECT]
#3175793
09/17/23 11:53 AM
09/17/23 11:53 AM
Posts: 984 rust belt
Moparite
rust belt
I used SEM 15014 with a paint gun before with good results. This was used for interior trim pieces. I would trust SEM more than what you can get in your local home improvement store(Krylon/Duplicolor).
