1996 Dodge pickup with tach #3171392
08/29/23 03:32 PM
08/29/23 03:32 PM
Cold Spring, NY
1970GTX Offline OP
1970GTX  Offline OP
Cold Spring, NY
My 96 Ram 1500 318 4wd auto wont fire. It cranks and does one fire, then just cranks.
I hear the fuel pump coming on and smell gas when it tries to fire.
I'll check for spark next, but I want to eliminate the crank position sensor if I do have spark.
So my question is, On a 96, does the tach show something when you are cranking the engine over, I know the later models do. My is showing nothing on the tach.
Thanks in advance for any help.
Re: 1996 Dodge pickup with tach [Re: 1970GTX] #3171396
08/29/23 03:41 PM
08/29/23 03:41 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
What are the codes?
Re: 1996 Dodge pickup with tach [Re: NITROUSN] #3171577
08/30/23 09:46 AM
08/30/23 09:46 AM
Cold Spring, NY
1970GTX Offline OP
1970GTX  Offline OP
Cold Spring, NY
good idea, i'll check.
Re: 1996 Dodge pickup with tach [Re: NITROUSN] #3171801
08/30/23 11:44 PM
08/30/23 11:44 PM
Cold Spring, NY
1970GTX Offline OP
1970GTX  Offline OP
Cold Spring, NY
Only code I got was a 12.
The battery was low when I first tried starting it, so I think that's why it threw that one.
Re: 1996 Dodge pickup with tach [Re: 1970GTX] #3171820
08/31/23 09:14 AM
08/31/23 09:14 AM
N
N
96 is OBD2 and should show P codes on a scanner. The plug is on the dash lip below the steering column. What scanner are you using?
Re: 1996 Dodge pickup with tach [Re: NITROUSN] #3171904
08/31/23 04:13 PM
08/31/23 04:13 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The key on, off, on thing doesn't work well after about the 92- 93 model year.
Re: 1996 Dodge pickup with tach [Re: NITROUSN] #3171977
08/31/23 11:01 PM
08/31/23 11:01 PM
Cold Spring, NY
1970GTX Offline OP
1970GTX  Offline OP
Cold Spring, NY
I thought it was ODB1. I used the check engine light flashes.
I found the scan port. I'll plug in Saturday when I have time.
I use a bluetooth scanner with apps "Car scanner" and "Torque"
Re: 1996 Dodge pickup with tach [Re: 1970GTX] #3172245
09/02/23 09:15 AM
09/02/23 09:15 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
Does this mean it will fire up and stall?
Did you try keeping your foot on the gas?
Quote
No, Tach moved when starting was with the can buss dash which was in 97 or 98.
Quote
Actually the "key dance" started back in the 80's and continued till past 2000. There are different procedures but this will work on a 96. Even if you don't have any codes you will see a 55 code.
Re: 1996 Dodge pickup with tach [Re: 1970GTX] #3172631
09/03/23 06:05 PM
09/03/23 06:05 PM
Cold Spring, NY
1970GTX Offline OP
1970GTX  Offline OP
Cold Spring, NY
Plugged my OBD2 scanner in.
No codes with the key on or trying to start it.
Re: 1996 Dodge pickup with tach [Re: 1970GTX] #3172634
09/03/23 06:19 PM
09/03/23 06:19 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
At this point I would start with checking if there is voltage coming into the throttle position switch, and power to the cam sensor on the back of the head on the right side. The power source for both is supplied by the key on power, and if the wiring fails, it doesn't usually set off a code.
I have not heard of issues with the wiring on the full sized trucks, but there sure was an issue with that era Dakota with a factory wire splice near the battery that supplies the power for both sensors, and there have been other issues with factory wiring connections on a lot of this era Mopars. I might be such a thing as the wiring issues have caught up with the full sized trucks as time passes.
Re: 1996 Dodge pickup with tach [Re: Moparite] #3172890
09/04/23 04:58 PM
09/04/23 04:58 PM
Cold Spring, NY
1970GTX Offline OP
1970GTX  Offline OP
Cold Spring, NY
Originally Posted by Moparite
Quote
It doesn't fire but sounds like it wants to.
I never put my foot on the gas with any injection vehicles. I heard it was a big nono. I can try it though.
Quote
Ok, that eliminates that "problem" good info to know in the future. Thank you.
Quote
I saw 12, then 55. I believe 12 is battery disconnected, or low battery voltage in my case since the battery was low from sitting for a month.
Re: 1996 Dodge pickup with tach [Re: poorboy] #3172891
09/04/23 05:00 PM
09/04/23 05:00 PM
Cold Spring, NY
1970GTX Offline OP
1970GTX  Offline OP
Cold Spring, NY
I see the TPS on my scanner, and it detects the pedal when I press it.
I can check the cam sensor. Thanks
Re: 1996 Dodge pickup with tach [Re: 1970GTX] #3173110
09/05/23 01:03 PM
09/05/23 01:03 PM
Cold Spring, NY
1970GTX Offline OP
1970GTX  Offline OP
Cold Spring, NY
I have spark at the coil. I'm going to check/change the cap and rotor next.
Re: 1996 Dodge pickup with tach [Re: 1970GTX] #3174766
09/12/23 05:59 PM
09/12/23 05:59 PM
Cold Spring, NY
1970GTX Offline OP
1970GTX  Offline OP
Cold Spring, NY
OK, replaced the cap which had corroded contacts, still wouldn't start.
So as per Moparite's advice, I held the pedal to the floor and viola, it started.
Let it warm up.
Shut it off and it wont start unless I hold the pedal to the floor.
So it looks like something with one of the throttle body sensors. Much easier to work on than the distributor. :-)
Re: 1996 Dodge pickup with tach [Re: 1970GTX] #3174768
09/12/23 06:08 PM
09/12/23 06:08 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Sounds like...IAC motor, clean and or replace.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 1996 Dodge pickup with tach [Re: 3hundred] #3175090
09/14/23 01:48 AM
09/14/23 01:48 AM
Cold Spring, NY
1970GTX Offline OP
1970GTX  Offline OP
Cold Spring, NY
Yup, My next step.
