Dakota Digital 71 RR Who has use one? #3171385
08/29/23 03:05 PM
08/29/23 03:05 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
So, I was intending to send my 71 Roadrunner cluster in and have it converted to work with a GenIII Hemi but my garage burned down with all of my parts in it. I bought a parts car that doesn't have the right cluster but as I begin searching for a cluster I find this:
Dakota Digital 1971-74 B-Body Rallye Retrotech Analog Gauge System RTX-71D-CHG-X.
It looks to be a modern direct replacement kit. If you have used this kit, I would sure like to have some dialogue with you. Pics showing final installations would be great as would input regarding the installation process.
Thanks in advance!
Re: Dakota Digital 71 RR Who has use one? [Re: scoutsr2] #3171497
08/29/23 09:28 PM
08/29/23 09:28 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Good evening! First, sorry about your garage fire! I can't imagine how that makes you feel. I installed a Dakota Digital in my '70 Challenger. Slightly different that your '71 B body. I looked at the instructions for your dash kit and it is pretty close to my install. It is very easy if you have any electrical/mechanical ability. I gutted my original AM radio and put the control box inside so it is hidden. All the other wiring is easy. I love the way mine looks and works. I'm sure you'll love it. The one you are looking at does have more features than the one I installed, mine is the VHX model. If I can help in any way, let me know. Take care, Jeff
Re: Dakota Digital 71 RR Who has use one? [Re: 1969RR] #3171544
08/30/23 03:56 AM
08/30/23 03:56 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Not mine, these are friends that are really happy with them.
Re: Dakota Digital 71 RR Who has use one? [Re: Car Nut] #3171545
08/30/23 03:57 AM
08/30/23 03:57 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Re: Dakota Digital 71 RR Who has use one? [Re: Car Nut] #3171707
08/30/23 04:44 PM
08/30/23 04:44 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Can’t comment on the 71 but used a Dakota Digital in my 69 Super Beez. Easy install looked great in the car and worked flawlessly. I have used Dakota Digital on several builds and have never had an issue. My 55 Dodge pickup has a Dakota Digital in it. That install was in 2013 and has over 65,000 miles on it. Never had a problem. Go for it you won’t be disappointed.
Re: Dakota Digital 71 RR Who has use one? [Re: Dabee] #3171744
08/30/23 07:25 PM
08/30/23 07:25 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Dakota Digitals gauges have a lifetime warranty too.
Re: Dakota Digital 71 RR Who has use one? [Re: scoutsr2] #3171753
08/30/23 08:17 PM
08/30/23 08:17 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
Thank everyone for your input!
Re: Dakota Digital 71 RR Who has use one? [Re: scoutsr2] #3171791
08/30/23 10:55 PM
08/30/23 10:55 PM
AndyF Offline
AndyF  Offline
Here is an earlier RR with the Dakota gauge setup. It works really nice and even interfaces with his EFI system.
https://youtu.be/sNeBSOqpO40
Re: Dakota Digital 71 RR Who has use one? [Re: AndyF] #3172226
09/02/23 06:09 AM
09/02/23 06:09 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
'74 E body, Easy to fit and look great when done. I'm sure you will be pleased with it up
Re: Dakota Digital 71 RR Who has use one? [Re: Tig] #3172306
09/02/23 12:49 PM
09/02/23 12:49 PM
BDW Offline
BDW  Offline
That does look good!
You eliminate the factory light bar bulbs?
Re: Dakota Digital 71 RR Who has use one? [Re: scoutsr2] #3172606
09/03/23 03:19 PM
09/03/23 03:19 PM
SD
RS23 '71 Offline
RS23 '71  Offline
SD
I would be surprised how many people would respond, I machined the 1st run of the gauges and it didn't amount to a very big run. I don't think we have done another run, we base our runs on number of units sold.
Re: Dakota Digital 71 RR Who has use one? [Re: BDW] #3172726
09/04/23 07:13 AM
09/04/23 07:13 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I can switch the std light bar off with a small switch under the dash, all the dash and gauge lamps were converted / swapped to LED, even the interior lighting.
