Page 1 of 3 1 2 3
NGK Plugs..... #3170635
08/26/23 04:08 PM
08/26/23 04:08 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
I stopped using these in the early 90's because they are crap and would just quit when conditions were not perfect. So I have not bought any since....The other day my ATV needed a plug, and Napa sells me an NGK plug even after I protested....They say they are good now.
Well I went to install the effing POS plug and what happens, it breaks in half right at the threads....The threaded part in down in the bore, and then entire rest of the plugs comes out....electrode and all...Anyone ever worked on an ATV...there is no room in there to work. This sucks, and it wasn't even tight yet..
NGK still sucks!!!!!!!!!!!
PS....Why do you think I was changing the plug in the first place...gas went bad over winter, even with stabilizer, and it had an NGK plug that stopped firing...Other ATVs with same fuel, no issue...
Re: NGK Plugs..... [Re: Dragula] #3170640
08/26/23 04:55 PM
08/26/23 04:55 PM
PA
moparacer Offline
moparacer  Offline
PA
Well if they suck I must have been lucky the last 15 years or so I have ran them. Every one has always been gapped the same out of the box too. I could have slapped every set in and never checked them. More than I can say for the other brands.
The set I took out of my car last month was 3 years old. The set in my Barracuda are maybe 10?
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: NGK Plugs..... [Re: moparacer] #3170641
08/26/23 05:02 PM
08/26/23 05:02 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I use nothing but NGK and have had great results. They are easy to read with a nitrous tune, too! shruggy
'63 Dodge 330
11.19 @ 121 mph
Re: NGK Plugs..... [Re: GY3] #3170643
08/26/23 05:04 PM
08/26/23 05:04 PM
K
Kiddart Offline
Kiddart  Offline
K
i use them as well no issues ever.
Thank you
Kiddart
Re: NGK Plugs..... [Re: Kiddart] #3170647
08/26/23 05:08 PM
08/26/23 05:08 PM
Dragula Offline OP
Dragula  Offline OP
I guess I only have bad luck then....
Re: NGK Plugs..... [Re: GY3] #3170650
08/26/23 05:17 PM
08/26/23 05:17 PM
PA
moparacer Offline
moparacer  Offline
PA
Yep easy to read the timing mark on the ground strap.
Re: NGK Plugs..... [Re: moparacer] #3170653
08/26/23 05:34 PM
08/26/23 05:34 PM
Dragula Offline OP
Dragula  Offline OP
NGK....Pure Quality.
Re: NGK Plugs..... [Re: Dragula] #3170657
08/26/23 05:50 PM
08/26/23 05:50 PM
PA
moparacer Offline
moparacer  Offline
PA
Did you put it in with a 1/2 breaker bar or 3/4 impact? laugh2
That is literally the first NGK plug I have ever seen do that.
It might be a issue with that particular plug number but If you do that with a NGK automotive plug I think you dont know your own strength.
Re: NGK Plugs..... [Re: Dragula] #3170659
08/26/23 05:53 PM
08/26/23 05:53 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I’m sorry but I would be afraid walking next to you in a rain storm.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: NGK Plugs..... [Re: pittsburghracer] #3170681
08/26/23 07:40 PM
08/26/23 07:40 PM
Dragula Offline OP
Dragula  Offline OP
Long as you are shorter, all is good...
Re: NGK Plugs..... [Re: Dragula] #3170685
08/26/23 08:05 PM
08/26/23 08:05 PM
PA.
"Little"John
"Little"John
PA.
I’m shorter but I’ll bet I’m wider. Lol 😂
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: NGK Plugs..... [Re: pittsburghracer] #3170692
08/26/23 09:03 PM
08/26/23 09:03 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Nothing but NGK in all our stuff. Sometimes I run them 3 years in the racecar. Still runs 9.0s
Doug
Re: NGK Plugs..... [Re: moparacer] #3170695
08/26/23 09:24 PM
08/26/23 09:24 PM
Dragula Offline OP
Dragula  Offline OP
As I said, getting into an ATV to change a plug is not somthing you can use any real tools on...And it was just a short handled wrench...And it was not even tight yet...Then I had to figure out hot to get that portion out of the cylinder.
Re: NGK Plugs..... [Re: dvw] #3170705
08/26/23 10:06 PM
08/26/23 10:06 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
All I use as well. I've been running the same set for 8 yrs. Every season I say I'm going to change them, just haven't. Fires right up and sets into a nice even idle. Last week was 7.043, 7.045 and 7.044. Just need the driver to get as consistent.
Ok
Re: NGK Plugs..... [Re: cudatom] #3170732
08/27/23 12:20 AM
08/27/23 12:20 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Ngk is all I’ve run since auto lite decided to close up shop here and set up in places I don’t trust. Run them in everything. The ford guys say to put them in eco boost motors. Apparently they make them for ford, to some crap spec, so you have to go with the ngk branded ones to get things right.
I want my fair share
Re: NGK Plugs..... [Re: Dragula] #3170749
08/27/23 07:32 AM
08/27/23 07:32 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I've never seen any make of plug snap there before. I recently swapped from NGK to Champion because the price of the NGK's has got so high. Out of the box the earth strap on the champions is twisted and not centered over the electrode, 6 of the 8 were like this. Not particularly impressed. blush
Re: NGK Plugs..... [Re: Tig] #3170761
08/27/23 09:02 AM
08/27/23 09:02 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
There are counterfeit NGK plugs circulating. Not sure how to check for origin on them but I bet that's what you have there.
Re: NGK Plugs..... [Re: Dragula] #3170765
08/27/23 10:10 AM
08/27/23 10:10 AM
sweden
carter Online content
carter  Online Content
sweden
Only NGK here.
Same plugs for five years now in a 512 cu street & strip, run a new best couple of month ago.
Re: NGK Plugs..... [Re: carter] #3170772
08/27/23 10:45 AM
08/27/23 10:45 AM
PA.
"Little"John
"Little"John
PA.
48 years of running Autolite racing plugs for me.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: NGK Plugs..... [Re: Dragula] #3170781
08/27/23 11:11 AM
08/27/23 11:11 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Sorry about your luck with the NGK. Since your on the topic of spark plugs, what heat range did you run in your 511/512? Not sure whats best for a 12.5:1 511.
Page 1 of 3 1 2 3
