Re: TTI Header Question/Customer Service
[Re: jcc]
#3169912
08/23/23 02:04 PM
08/23/23 02:04 PM
Posts: 19,405 north of coder
moparx
You nailed it, Thanks " #2 tube height from the attaching bolt centerline at #6 tube is 3 3/8".
You have the header that was my first choice and the one expected to be the tallest, but I should be able to make that work. Never really expected to solve my problem here, I just needed to rant. glad that was somewhat useful to you. as for ranting, i'm old, and old guys are supposed to crab and bit$h all the time............
[Re: TJP]
#3169915
08/23/23 02:17 PM
08/23/23 02:17 PM
moparx
Myself, I would make it a poin tocall Sam next week. If he doesn't know what his employees are doing you can't expect it to improve. I many time encourage owners of comapnies to call in with questions like yours to see the responses On the ceramic coating, i stoppe buying coated headers after watching exactly what you described, 6-12 months and they are going to 🔥 . the only coatings i have found stand up are those from JET HOT or VHT period. when using the jet hot [doesn't the headers need sent out for this ?] and especially the vht, after application of the vht, were the headers baked before use ? luckily for me, there is a metal fabrication place that is only a couple of miles from me [they are rated in the top 40 manufacturing companies in the U.S.A. ] and they do powder coating of all types. they especially like to work with old car enthusiasts, which is another plus ! when i get my exhaust finished, i am going to have them coat the whole system. after talking to them, they said if i decided to use another product on the headers, they would blast, clean, [they use gloves in all steps] and spray whatever product i decided upon. they would then bake the exhaust system as the product required. all of this for roughly $150-200.00.
[Re: A12]
#3169979
08/23/23 07:42 PM
08/23/23 07:42 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Those two stories above... from an AMERICAN company is a good example of why China and other overseas companies, are making so much money. These U.S. companies like TTI better get their act together, asap. And who do you call when your China made product fails or disappoints and who will answer and speaks American English to most likely tell you the same thing or less?...............I'll wait over here for that answer............ The answer is you don't expect to get an answer from the Chinese conpany, and pay less. You pay more expecting to get support from an American company. So if you don't get that support, why pay the premium? I shared nothing that this was something of any urgency, and it's not. The person responded, "I don't know how to measure that". I responded, "Use a tape measure." He responded, "I don't have time to go out back and take a measurement." I responded, "well who might?" He responded "Sam, call back next week" I responded, "who is Sam?" He responded, "the owner" The person at TTI, from what I read, didn't totally not offer an answer but seemed not to be the person that had the technical knowledge to do what was asked. When questioned "then who might?" He responed with the "OWNER". Seems like he would have gotten an answer to his not so urgent question from the top. I'm sure the OP wasn't the only customer on the phone or holding for customer service, Just got the wrong customer service person at the wrong time that didn't have the time to go back and measure a set of headers at that moment. Your take on the interaction is not out of bounds, but one thing hard to convey here is "tone", and It seemed to be, "I don't care to answer such a silly question and you are bothering me" Early on if he would have just said, "Give Sam the owner a call when he returns next week as he knows the most around here", this thread would not exist. Maybe I expect too much.
[Re: larrymopar360]
#3169985
08/23/23 08:08 PM
08/23/23 08:08 PM
Posts: 18,419 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I'm interested in possibly getting TTi headers for my E-body, small block... having the longer T/A Fast Ratio PITMAN ARM, as well as the longer IDLER ARM (required to make the proper radius equal in turning left-right... also known as fast-ratio Idler arm... simply a '70 C-body idler arm).
I need to know IF their headers will clear those longer arms. The person I spoke to gave me a quick "I don't know...".. and he supposedly asked someone else inside TTi... same answer... "... don't know..".
As TTi concentrates on MOPARS, I thought they should know.
I'll find out sooner or later, but I do know that the Hooker 5115 do clear both arms (I have them)... longer idler arm requires slight dinging on one tube.. Maybe I'll just buy another set of Hookers. I know it's not the same but I have TTI headers and Fast ratio pitman and idler arm and they clear. '89 Diplomat Police. Nice 4wd Diplomat.
[Re: Mopar Mitch]
#3170009
08/23/23 09:17 PM
08/23/23 09:17 PM
jcc
Bitopia
I'll find out sooner or later, but I do know that the Hooker 5115 do clear both arms (I have them)... longer idler arm requires slight dinging on one tube.. Maybe I'll just buy another set of Hookers. Everything I have read on their website indicates to me that nothing they offer works with a fast ratio arm set-up. The easiest option with TTI is then Borg PS box to get any faster ratio it seems to me. Or you could call Sam next week.
[Re: moparx]
#3170015
08/23/23 09:39 PM
08/23/23 09:39 PM
Posts: 15,357 Omaha Ne
TJP
Omaha Ne
when using the jet hot [doesn't the headers need sent out for this ?] and especially the vht, after application of the vht, were the headers baked before use ? luckily for me, there is a metal fabrication place that is only a couple of miles from me [they are rated in the top 40 manufacturing companies in the U.S.A. ] and they do powder coating of all types. they especially like to work with old car enthusiasts, which is another plus ! when i get my exhaust finished, i am going to have them coat the whole system. after talking to them, they said if i decided to use another product on the headers, they would blast, clean, [they use gloves in all steps] and spray whatever product i decided upon. they would then bake the exhaust system as the product required. all of this for roughly $150-200.00. Yes on the headers having to be sent to Jet Hot. I took a set to the machine shop t to have them dynoed with the motor that was freshly built. When I went back his first question was: Who coated those headers??? He said he had yet to see a set make it through break in, tuning etc. without the coating failing near the exhaust ports. VHT is best applied to a freshly blasted surface and then handled carefully until it's cured. This other nice thing is most ,aterial burns off and if not once removed they can easily bet touched up. Been using the SP117 for over 47 years Myself, it's Jet hot or VHT. At 69 Years old Ii have yet to see anything comparable. Do keep in mind I have owned and operated a classic car repair/ resto facility for over 25 years
[Re: Mopar Mitch]
#3170083
08/24/23 09:39 AM
08/24/23 09:39 AM
Posts: 801 central CT
cudazappa
central CT
I'll find out sooner or later, but I do know that the Hooker 5115 do clear both arms (I have them)... longer idler arm requires slight dinging on one tube.. Maybe I'll just buy another set of Hookers. I used Dougs D453. No problems. (yes, I'm running the fast ratio arms)
1971 Challenger
[Re: cudazappa]
#3170462
08/25/23 07:29 PM
08/25/23 07:29 PM
Posts: 15,871 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Try again. This is my '89 Dip AHB with TTI's and FR pitman and idler arms.
Facts are stubborn things.
