Rodent smell removal. #3170003
08/23/23 08:52 PM
08/23/23 08:52 PM
Star Idaho
67vertman Offline OP
Star Idaho
What have you used successfully to remove mouse piss smell from your interior.
I pulled all the carpet, and pad and cleaned all the lose stuff. Now I need to deodorize the interior to remove the smell.
The truck had set in a barn and field for the last 33 plus years.
Thanks.
My Monster are real!
Living within your means makes life pretty easy.
Re: Rodent smell removal. [Re: 67vertman] #3170010
08/23/23 09:23 PM
08/23/23 09:23 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I have an ozone generator I bought for another problem that may do the trick. Might take a day or two in the car with the windows closed and another couple of days to air things out. I haven't used it for this issue so i cannot say one way or the other frown
See what others have to say and PM me if interested. Only other solution I know of is an ALL new interior beer
Re: Rodent smell removal. [Re: TJP] #3170012
08/23/23 09:29 PM
08/23/23 09:29 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: Rodent smell removal. [Re: 67vertman] #3170081
08/24/23 09:34 AM
08/24/23 09:34 AM
Newburgh, NY
Old_Moparz Offline
Old_Moparz  Offline
Newburgh, NY
Before you buy anything expensive that's designed to remove odors, try Hydrogen Peroxide first. It's much cheaper & works quite well. I've used it in my house for cat urine & also in my car for when an outside cat was locked in my garage & used my back seat as a litter box.....LOL laugh2
Peroxide & other methods.....
https://www.randrmagonline.com/articles/89702-5-tips-for-natural-odor-control
This site said it may discolor fabrics but it never did in all the times I've used it. I doused the area heavily with just the peroxide & then covered the spot with aluminum foil to prevent it from evaporating too quickly.
Re: Rodent smell removal. [Re: Old_Moparz] #3170097
08/24/23 10:14 AM
08/24/23 10:14 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
You need a disinfectant - most odors are caused by bacteria. There are a few different disinfectant cleaners available at hardware stores like OdoBan. The active ingredient in all of them will be dimethtl benzyl ammonium chloride. Most of them are concentrated. Put this in a backpack or hand sprayer, and absolutely soak any fabrics that you need to reuse, scrub with a drill brush attachment, pressurewash, and repeat. This will work well on the carpet.
Then wet vac it as dry as you can get it, and let it set out in the sun and dry. The longer you can leave it in fresh air before reinstalling the better.
Any soft materials you can just throw out and not use do so. Clean hard materials the same way. Certain soft materials like late model headliners are difficult or impossible to save. If you really need to reuse delicate soft items your best bet is lysol and let it sit out in fresh air as long as possible.
Re: Rodent smell removal. [Re: GTX MATT] #3170115
08/24/23 11:35 AM
08/24/23 11:35 AM
Detroit area
6PAX Online content
6PAX  Online Content
Detroit area
There was mouse piss smell in my Duster when I got it. Bought a bottle of Resolve Urine Destroyer from Home Depot. Pardon the pun, but it didn't work worth a piss. It made the car smell nice for a little while but the smell returned each time I tried using it.
Re: Rodent smell removal. [Re: 67vertman] #3170119
08/24/23 12:36 PM
08/24/23 12:36 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
When I worked at a car dealership, they had some kind of deodorizer that came in a can. Had a fellow pop one open and take a sniff . He dropped to the floor and almost passed out ! Took him long time of time to recover ! there was a warning label he disregarded. Apparently this is really strong stuff for professional use. So I suggest you check with some dealers or detailers about what they use like this .
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Rodent smell removal. [Re: doctor_mopar] #3170129
08/24/23 01:13 PM
08/24/23 01:13 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
33 years of mouse piss...
I wish you the best of luck, that sounds really difficult..
That sounds like the ozone deodorizer I was given by my local Dr. Vinyl franchiser for some odors in one of my cars - it was a can, I pulled the top off, all kinds of breathing hazard warnings, left it in the closed up car for a week. It reduced the odor, but not rid of it. I've since used a plastic bucket of Damp-Rid from Home Depot.. it is meant to absorb moisture, but it has a decent aroma too, so I left it in the car for a month.. it worked better, but still not completely gone.
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Rodent smell removal. [Re: 67SATisfaction] #3170132
08/24/23 01:19 PM
08/24/23 01:19 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
I've had good luck with ammonia. Pour some in a couple of bowls, set on the floorboards, shut the doors and windows.
Let it sit a day or two. Refill the bowls if needed. Letting it sit in the sun will help bake out the stink as well.
Good luck
Re: Rodent smell removal. [Re: A990] #3170142
08/24/23 01:50 PM
08/24/23 01:50 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
It gets absorbed by the fibers & soft trim. You'll have to clean everything, remove & clean what you can (seat & belts at least), replace carpet & padding.
Re: Rodent smell removal. [Re: topside] #3170187
08/24/23 04:28 PM
08/24/23 04:28 PM
Star Idaho
Star Idaho
Thanks for the ides and suggestions everyone.
My first step, other than removing the carpet. pad and seat, will be to wash the inside thoroughly with a sanitizer of some type. Once that is done I will try some of your suggestions and let you know what works.
Re: Rodent smell removal. [Re: 67vertman] #3170978
08/28/23 08:44 AM
08/28/23 08:44 AM
WV
Little Detroit Offline
WV
new product out advertised on TV it is called "Poof" designed for killing oders from Garbage dumps near populated area's
Re: Rodent smell removal. [Re: Little Detroit] #3170982
08/28/23 08:51 AM
08/28/23 08:51 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
I remover 15years of cats living in a car with club soda. Drench in club soda wet vac then drench in water and wet vac again. And this was cloth upholstery.
1969 Hemi Roadrunner 2nd owner
