Re: Race day checklist
[Re: Kam*Kuda]
#3169716
08/22/23 02:57 PM
08/22/23 02:57 PM
Posts: 1,774 Keymar, MD
DusterKid
Keymar, MD
I have an enclosed trailer and a small class C motorhome so most of my stuff is already packed. I typically don't travel super far from home and most of my races are single day anymore, or I'd probably pack some more extra spare parts. I've also try and make my racing budget friendly so my cars are nothing special running mid 10's and slower in the 1/4 with basic combos that require little maintenance.
Air Tank Enough race fuel for the weekend fuel funnel Toolbox with typical tools (wrench's, pliers, screw drives, sockets, ratchet, electrical tape, spark plug gapper) Timing light Atleast 1 qt of motor oil and trans fluid Brake Cleaner Bottle jack Floor Jack 2 jack stands Spare parts (rocker arms, pushrods, set of spark plugs, carb gaskets, jets, extra carb return spring, throttle cable, tire tube) Spare trailer tire Battery charger Extension cord Helmet, racing jacket and pants tire gauge Enough food + drink for the race day
[Re: jcc]
#3169921
08/23/23 02:58 PM
08/23/23 02:58 PM
Posts: 19,456 north of coder
moparx
[quote] Originally Posted by jcc [quote] Originally Posted by tboomer Large amount of cash! Define "large". All of it Touche! just stay home and avoid all the anxiety and aggravation................
[Re: moparx]
#3169976
08/23/23 07:34 PM
08/23/23 07:34 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Originally Posted by jcc [quote] Originally Posted by tboomer Large amount of cash! Define "large". All of it [quote=jcc]Touche! just stay home and avoid all the anxiety and aggravation................ But staying home doesn't save you any money if you have none to begin with.
[Re: Kam*Kuda]
#3170856
08/27/23 03:27 PM
08/27/23 03:27 PM
Posts: 5,991 Anoka County, MN
Leigh
Anoka County, MN
I am working making focused task tool boxes. Need to check lash in a hurry? Grab the valve lash toolbox. Everything I need to check lash is in that box. Another for timing, carb adjustment, hooking up the trailer. You get the gist. Thanks to Luke Bogaki, for the idea. Oh, right now my stuff is in Bark Box, cardboard boxes, so you can do it on a budget.
[Re: Leigh]
#3170930
08/27/23 10:14 PM
08/27/23 10:14 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
I am working making focused task tool boxes. Need to check lash in a hurry? Grab the valve lash toolbox. Everything I need to check lash is in that box. Another for timing, carb adjustment, hooking up the trailer. You get the gist. Thanks to Luke Bogaki, for the idea. Oh, right now my stuff is in Bark Box, cardboard boxes, so you can do it on a budget. smaller individual boxes are easier to pack and normally lighter to lift . Most of mine is like that . Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#3171323
08/29/23 12:17 PM
08/29/23 12:17 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Well after our weekend in Norwalk replacing everything in the ignition system, box, controller, coil, trigger pickup, trigger wheel, wires and plugs all of which we had with us and still did not fix our miss issue. The morale of the story is sometimes no how many parts you have with you sometimes it just isn't enough.
[Re: Leigh]
#3171330
08/29/23 12:43 PM
08/29/23 12:43 PM
Posts: 7,491 Minnesota
Hemi_Joel
Minnesota
I am working making focused task tool boxes. Need to check lash in a hurry? Grab the valve lash toolbox. Everything I need to check lash is in that box. Another for timing, carb adjustment, hooking up the trailer. You get the gist. Thanks to Luke Bogaki, for the idea. Oh, right now my stuff is in Bark Box, cardboard boxes, so you can do it on a budget. That's my drag week program now too. I've got a bunch of those cloth tool bags that Ryobi, DeWalt, and Milwaukee power tools come in that were getting thrown away where the trunk monkey works. I have one set up with spark plugs, spark plug gapping tools, spark plug socket, extension, and ratchet. Then another one has The timing light, the remote starter switch, and lash setting tools, and the socket and extension for the valve covers. One with only the tools for removing and installing the exhaust system plus a couple of extra collector gaskets and nuts and bolts, one with extra lifters Any wrench size that the hot rod does not have on any of its fasteners, does not get packed.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3171348
08/29/23 01:17 PM
08/29/23 01:17 PM
Posts: 20,184 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Harbor freight has a lot of nice boxes. I have several with carb parts, electrical parts, etc. rebuilt my carb this week and grabbed this out of my trailer.
[Re: topside]
#3173719
09/08/23 09:18 AM
09/08/23 09:18 AM
Posts: 4,243 Canada
Kam*Kuda
Canada
I like the smaller tool box ideas. That makes sense
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
