440 4-speed, severe grinding in and out of every gear #3169093
08/19/23 08:35 PM
08/19/23 08:35 PM
Northern Virginia
Moparmaniacc Offline OP
Northern Virginia
I don't know how to describe what is going on with my 4-speed, basically it sounds like I'm trying to push it into gear without the clutch, but then again it sounds like that even when I am OUT of gear. This is a 23-sline A-833 in a 70' Challenger.
I can still get it to shift, all 4 gears and reverse, with difficulty but even then the grinding noise is there, it's not as bad when you are at the optimum speed for that gear. Is it a linkage adjustment gone wrong? or did my 1-2 and 3-4 synchros die at the same time?
Sorry if this doesn't make sense.
thanks
Re: 440 4-speed, severe grinding in and out of every gear [Re: Moparmaniacc] #3169106
08/19/23 09:47 PM
08/19/23 09:47 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
thanks
So are you saying it grinds sitting still? In all gears? what does it do in neutral with the clutch in and out?? confused
Re: 440 4-speed, severe grinding in and out of every gear [Re: Moparmaniacc] #3169107
08/19/23 09:47 PM
08/19/23 09:47 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Sounds like the input shaft isn't slowing down. Either your input shaft is bound up in the end of the crank with a stuck pilot bushing or the clutch is not disengaging. Severe mis-alignment could also do that .
Dis it happen all of a sudden or did you change something?
Gus beer
64 Plymouth Savoy
Dana 60
Re: 440 4-speed, severe grinding in and out of every gear [Re: fourgearsavoy] #3169113
08/19/23 10:12 PM
08/19/23 10:12 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Just drain out some fluid and see what it looks like.
Any metal like residue would point towards bearings bad, or other item.
let us know what it looks like.
Re: 440 4-speed, severe grinding in and out of every gear [Re: PhillyRag] #3169122
08/20/23 12:17 AM
08/20/23 12:17 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Had a deal in 2019 that sounds similar to that problem - a couple of the snap rings had been improperly installed in a previous rebuild, and the internals were moving fore & aft.
Basically, the trans was eating itself; went from "what the hell is that" to a horrible grinding racket very quickly.
Had to replace countershaft, synchro rings, bearings, and snap rings.
Brewer's had everything for about $200 and shipped quickly.
Re: 440 4-speed, severe grinding in and out of every gear [Re: topside] #3169134
08/20/23 05:27 AM
08/20/23 05:27 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
First, don’t drive it. You’re eating up your gears. I put synthetic gear oil in mine once and it was so slick, the synchros would not stop the gears and it would grind. Sounds like your input or clutch is not disengaging. Time to start pulling the transmission to check everything.
Re: 440 4-speed, severe grinding in and out of every gear [Re: Moparmaniacc] #3169193
08/20/23 12:59 PM
08/20/23 12:59 PM
How much clutch travel do you have before it starts to get harder to push down?
If more than one inch I adjust it so the pedal has minimum travel (less than one ich travel up scope wrench) before it starts pushing on the pressure plate, I buy the A body A motor clutch rods to use in all my 4 speed cars, the stock B and E bodies are a lot shorter than the A body rods are scope up
Re: 440 4-speed, severe grinding in and out of every gear [Re: fastmark] #3169207
08/20/23 01:39 PM
08/20/23 01:39 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
^This is my guess too. Wrong trans fluid.
Re: 440 4-speed, severe grinding in and out of every gear [Re: A12] #3169225
08/20/23 03:04 PM
08/20/23 03:04 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
At different times, I've run gear oil, ATF & synthetic in an A833, and never heard any roughness or grinding.
Re: 440 4-speed, severe grinding in and out of every gear [Re: Moparmaniacc] #3169320
08/20/23 09:51 PM
08/20/23 09:51 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
If it's grinding AFTER your in gear & driving it, it's metal-on-metal contact.
If that's true: has nothing to do about linkage/shifter adj, clutch petal travel, etc.
Re: 440 4-speed, severe grinding in and out of every gear [Re: PhillyRag] #3169390
08/21/23 11:41 AM
08/21/23 11:41 AM
Findlay
Ramman Offline
Ramman  Offline
Findlay
Wrong gear lube.
GL-4 only!
Not GL-5
Not GL 4/5
GL-4 only!
Re: 440 4-speed, severe grinding in and out of every gear [Re: Ramman] #3169402
08/21/23 12:13 PM
08/21/23 12:13 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
OP registered in 2004, has 744 posts work
1.5 days 10 responses from all but the OP whistling maybe he put an auto in it whistling
Re: 440 4-speed, severe grinding in and out of every gear [Re: TJP] #3169448
08/21/23 03:13 PM
08/21/23 03:13 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I out the passion gear oil in one and it went from smooth shifting to grinding. Drained it immediately. Old lube hadn’t been changed by me and came out with some moisture even. So I thought I’d done good until first drive. I put 85w-140 in and it was back to being business as usual. I mentioned this before on here and somebody said that meant the trans was worn out if it wouldn’t shift right with the passion juice. That might’ve been, but I wasn’t doing a tear down of a good working trans so I could run a certain type of gear oil.
I want my fair share
Re: 440 4-speed, severe grinding in and out of every gear [Re: SomeCarGuy] #3169455
08/21/23 03:50 PM
08/21/23 03:50 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Guess what's good-for-the-goose, may not be good-for-the-gander. (i.e. Passion vs A833)
Baffles me why many don't use the "normal" gear oil in an a833.
It thins out enough soon after driving as to not be a problem, except in colder weather.
And really, how many Really drive them in cold weather?
