Modifying column shift for drag racing #3168445
08/17/23 08:45 AM
08/17/23 08:45 AM
WI
68hemiss Offline OP
68hemiss  Offline OP
WI
I believe there was a thread a while ago on modifying a column shifter for drag racing. Modifying detents for more positive gear selection. Any suggestions?
Re: Modifying column shift for drag racing [Re: 68hemiss] #3168487
08/17/23 11:52 AM
08/17/23 11:52 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Couple decades ago I had an idea to modify one for ratchet shifter operation, but it seemed too bulky and cumbersome so I abandoned it.
To mount it somewhere other than the engine bay would mean column-Cable-remote mounted shifter mechanism-cable-trans which is too much for me.
The indicator wouldn't read correctly either, it would appear to be in neutral visually so that's no good.
Maybe someone smarter than me (should be pretty easy to find LOL) can figure that out, sell it, and retire from the proceeds.....
Rich H.
Esse Quam Videri
Re: Modifying column shift for drag racing [Re: ZIPPY] #3168513
08/17/23 12:44 PM
08/17/23 12:44 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
I did one on a Duster, reverse VB, ground the detent so it’s flat from original neutral to second, pull into first (drive spot) pull down to second, pull toward you and down for third. Worked slick as a whistle. Really just smack the lever down for second. I still have the detent piece so could show pictures. At finish line push up to first or neutral, both freewheel. As long as you’re pushing down it won’t go into reverse. I would lay my palm on top of lever lever, except for third, not in front. Majority grab it with a reversed fist, a no no
Re: Modifying column shift for drag racing [Re: cudaman1969] #3168519
08/17/23 12:54 PM
08/17/23 12:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
pictures please
Re: Modifying column shift for drag racing [Re: cudaman1969] #3168534
08/17/23 01:17 PM
08/17/23 01:17 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I don't have a picture but this is how mine was done, have a reverse manual valve body in my Fury and it's straight down from 1(old D) to 2nd, then pull back and down for 3rd. It took me a few tries on the street to learn how to not go from 1st right to 3rd, now I make sure I'm pushing forward slightly on the 1-2.
Re: Modifying column shift for drag racing [Re: 68hemiss] #3168538
08/17/23 01:22 PM
08/17/23 01:22 PM
Stick shift or automatic? shruggy
Re: Modifying column shift for drag racing [Re: Cab_Burge] #3168548
08/17/23 02:12 PM
08/17/23 02:12 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I think some of the F.A.S.T. guys have column shifters? Dudek's Hemi Cuda I think has a column shifter from a video I watched awhile ago.
Wonder if they run thru the gears by hand, or leave it in D and move the shift point rpms way up? Not supposed to launch in D with a normal automatic valve body though???
Re: Modifying column shift for drag racing [Re: Neil] #3168606
08/17/23 06:11 PM
08/17/23 06:11 PM
fredericksburg,va
fredericksburg,va
Here’s the piece laying on a stock one.
Total slot is approx .610, worked well for me. I highlighted it with silver paint.
Re: Modifying column shift for drag racing [Re: cudaman1969] #3168626
08/17/23 07:45 PM
08/17/23 07:45 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That's handy, thanks for the photo.
I'm undecided on whether a forward pattern isn't better with a column shifter, since you go towards Neutral.
Done that many a time on street cars.
Ain't no way I can beat the valve body going backwards, if I had to get Neutral quickly at speed.
Re: Modifying column shift for drag racing [Re: topside] #3168651
08/17/23 08:54 PM
08/17/23 08:54 PM
fredericksburg,va
fredericksburg,va
Not a problem either way, very quick, depending on you of course
Re: Modifying column shift for drag racing [Re: 68hemiss] #3168706
08/18/23 01:18 AM
08/18/23 01:18 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
The RO/WO cars had a modified detent and it's easy to file yours for a manual vb. I've still got my old detent if you want a picture of of it. And for me I wouldn't have it any other way even though it is a bit challenging keeping your arm positioned with the G-force working against you. Running 11s wasn't to bad but running solid 10s it tested me.
Re: Modifying column shift for drag racing [Re: Neil] #3168737
08/18/23 09:21 AM
08/18/23 09:21 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Pretty sure , like 99% the FASTEST of the FAST racers are running full manual valvebodies, I'm interested in the picture because if I ever get my Dart going and it runs into the 11's with my junk that I'm going to swap from a 4speed to a column automatic. It's an original 383, no console 4 speed car and I don't to alter the body in anyway.
Re: Modifying column shift for drag racing [Re: cudaman1969] #3168738
08/18/23 09:22 AM
08/18/23 09:22 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks for that photo , so that is the D gate that you widened ?
Re: Modifying column shift for drag racing [Re: 52savoy] #3168739
08/18/23 09:23 AM
08/18/23 09:23 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes picture please ...
I imagine it was easier to do it with a shift lever to grab hold of vs. doing it with a pushbutton ...
Re: Modifying column shift for drag racing [Re: JohnRR] #3168788
08/18/23 12:26 PM
08/18/23 12:26 PM
fredericksburg,va
fredericksburg,va
Yes, no detent for first just second. You’ll be grinding off the second step, down from the drive spot. I smacked the lever down when going to second, pull for third. One thing else, the engine will have to be tied down so it doesn’t torque up, that will mess with linkage adjustment. No problem feeling when in goes in first gear. I thought of welding a little knob before the reverse notch but after running a few times never had a problem going from 3 back to N as long as I pushed down and up on lever. 11.6 second Duster
Re: Modifying column shift for drag racing [Re: cudaman1969] #3168801
08/18/23 01:16 PM
08/18/23 01:16 PM
For those that have a reverse pattern manual valve body with low band apply, DO NOT shift if from high gear to neutral at the finish line in the 1/4 mile, those type valve bodies will apply low gear for a tiny bit of time, NOT GOOD down
I learned that lesson a long time ago by almost making my stocker start doing lock up rear tire sliding at the finish line shock puke
I ended up waiting to put in neutral by stopping car completely before shifting it into neutral up twocents
Be safe, especially ay the tracks up
