Calling All 727 Experts #3167675
08/13/23 05:19 PM
08/13/23 05:19 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Background - my transmission guy is no rookie and has successfully gone through this transmissions a few times in the past. I am not faulting him!
With my new motor combination, the output shaft was a weak link. This is an A&A transmission and I bought an aftermarket shaft and my trans guy put it in. Also new converter.
The car did not have neutral or reverse - went forward. The transmission was heavily contaminated with magnetic particles otherwise we saw zero wrong with the transmission or where the contamination came from. We thought it was a converter issues - converter guys says minor contamination and all good with the converter.
Carefully cleaned everything and reassembled. Same issue.
- goes forward in neutral and reverse
- brake is fully engaged in neutral
- in third gear on the brake it was slipping against the brake but moving forward
- magnetic particle contamination in the pan although not as bad as the first time
What are we missing?
Re: Calling All 727 Experts [Re: markz528] #3167687
08/13/23 06:15 PM
08/13/23 06:15 PM
A727Tflite Offline
A727Tflite  Offline
Regarding the contamination - how did you clean the cooler and lines ?
Re: Calling All 727 Experts [Re: A727Tflite] #3167697
08/13/23 06:43 PM
08/13/23 06:43 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
I was very anal. Denatured alcohol. Flushed about 3 minutes. 30 micron filter.
Re: Calling All 727 Experts [Re: markz528] #3167701
08/13/23 06:55 PM
08/13/23 06:55 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
First thing always when you have a weird transmission problem is to put a set of gauges on it. Especially a Mopar transmission. The engineers were actually nice to you a pressure port for every friction element. Valvebody controls the fluid flow so if it has pressure where it is not supposed to be a valvebody issue, if it has pressure where it is supposed to be then a mechanical issue with the band or clutch pack. Plus with the valve body off you you can air check all the clutches and bands as well and listen for any leakage past sealing rings.
Re: Calling All 727 Experts [Re: jwb123] #3167724
08/13/23 09:02 PM
08/13/23 09:02 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'm assuming the same valve body. Also assuming this issue didn't exist before the new output shaft was installed. Unless the input and output shaft are stuck together the rear clutch has to be driving the front planetary annulas. I'd look real close at the stack up between the annulas and the rear clutch pack being it has a new output shaft.
Doug
Re: Calling All 727 Experts [Re: dvw] #3167728
08/13/23 09:56 PM
08/13/23 09:56 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Thank you for the replies!
I like the idea of putting gauges on it. I will see what Rick Allison says about that.
I really know very little about these transmissions. But starting to drink from a fire hose to learn. Correct that the trans was fine until we put the output shaft in it. And always done by the same guy.
The symptoms should lead us down the right path. Why the contamination? From the drum? It is a steel drum.
Re: Calling All 727 Experts [Re: markz528] #3167739
08/13/23 10:32 PM
08/13/23 10:32 PM
A727Tflite Offline
A727Tflite  Offline
If you were meticulous and had the whole trans apart and cleaned, and the cooler and lines were cleaned as you say, then there has to be a dirt generator inside - need to find it.
Re: Calling All 727 Experts [Re: markz528] #3167752
08/14/23 01:00 AM
08/14/23 01:00 AM
I don't think ethanol alcohol will touch, clean, or dilute petroleum base lubricants scope twocents
methanol will dilute oil but I don't think it will clean it like petroleum based cleaners will like cleaning solvents or brake or carb cleaners due scope up
I buy petroleum base cleaning solvents form my local gas and oil bulk storage plants scope up
I found out that they will sell you containers of solvents in various sizes, 55 gallon, 30 gallons and 5 gallons pails and they also stock it in bulk and will fill my containers a lot cheaper than buying it in theirs up scope twocents
Re: Calling All 727 Experts [Re: markz528] #3167756
08/14/23 04:45 AM
08/14/23 04:45 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Sounds like something is stuck, maybe in the transbrake solenoid, Other than that it would be a cross leak.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Calling All 727 Experts [Re: dvw] #3167793
08/14/23 10:12 AM
08/14/23 10:12 AM
NC
440Jim Offline
440Jim  Offline
NC
Doug
This is understanding also.
I always document the clutch pack clearances when assembling the trans. Just in case something changed even if the rear clutch looked good. Lack of rear clutch clearance could cause it.
Re: Calling All 727 Experts [Re: 440Jim] #3167804
08/14/23 11:00 AM
08/14/23 11:00 AM
VA
dragon slayer Offline
VA
Did you compare the new input shaft to the old one, making sure correct in everyway?
Re: Calling All 727 Experts [Re: jwb123] #3167809
08/14/23 11:25 AM
08/14/23 11:25 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Except the clutches, no way to gauge the pressure at them and the line pressure test port is blocked in many race VB's.
Re: Calling All 727 Experts [Re: John_Kunkel] #3167891
08/14/23 04:04 PM
08/14/23 04:04 PM
PA
O
Ody1003 Offline
Ody1003  Offline
O
PA
Had it happen. bellveive ( spelling) broke. All forward in or out of gear. Talk to A&A. newer model better design.
Re: Calling All 727 Experts [Re: dragon slayer] #3167965
08/14/23 09:00 PM
08/14/23 09:00 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Apples to oranges….. but if you run the A&A output shaft on a 904 you HAVE to use their accompanying input shaft. They utilize a bearing and shim between the two. Might not be a thing with the 727, just thought I’d throw it out there.
Re: Calling All 727 Experts [Re: J_BODY] #3185711
10/22/23 01:50 PM
10/22/23 01:50 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Update - well no surprise it appears to be in the rear clutch. I pulled the valve body. It fails the rear clutch air pressure test................ Will get fixed next month.
Re: Calling All 727 Experts [Re: markz528] #3191916
11/18/23 11:40 PM
11/18/23 11:40 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Well its apart again. Not what I expected. Its got the wrong stator in it. That's why it failed the rear clutch air test. Somehow he did not put my original stator back in.
Re: Calling All 727 Experts [Re: markz528] #3191955
11/19/23 08:57 AM
11/19/23 08:57 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Wrong stator? Or wrong stator support? I can't see how the wrong stator would affect rear clutch apply.
Doug
Re: Calling All 727 Experts [Re: dvw] #3191960
11/19/23 09:17 AM
11/19/23 09:17 AM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Is this the stator or stator support. I circled the difference in the ports.
Re: Calling All 727 Experts [Re: dvw] #3191965
11/19/23 09:49 AM
11/19/23 09:49 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Doug
The stator support is how the fluid gets to the clutches, fluid goes from the valvebody into the case into the pump, stator support and to the clutches. One of the common air tests to do when rebuilding is to stack the two drums on the front pump and apply air to the feed holes in the pump to apply the clutches and check for leaks. If the rebuilder had performed that test he would have found the issue on the bench.
Re: Calling All 727 Experts [Re: markz528] #3191966
11/19/23 09:50 AM
11/19/23 09:50 AM
A727Tflite Offline
A727Tflite  Offline
Stator support. That unit takes the input shaft with no hole between the two input shaft sealing rings.
