Page 1 of 3 1 2 3
69 Dart GTS Fender tag help please. Updated!! #3167298
08/11/23 04:21 PM
08/11/23 04:21 PM
tboomer Online work OP
tboomer  Online Work OP
Went to work on my soon to be acquired 69 GTS today.fuel pump has been changed and we took the 4160 Holley off and put in an accelerator pump diaphragm. Car starts but won't stay running unless you keep tapping the throttle. I think the sock in the tank may be plugged or the carb needs a rebuild! I had my wife write down the fender tag numbers in hopes that you guys can tell me what I have...No cash has exchanged hands until I can drive it onto a trailer! Her's what we got off the tag and there will be some missing numbers...
M25R11V1 X END
C15 C55 C15 C33 L31 6?1
B5 P68 83 404 1696 C4 Thanks fellas! Ted wave
Re: 69 Dart GTS Fender tag help please. [Re: tboomer] #3167312
08/11/23 04:58 PM
08/11/23 04:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If it keeps running by tapping the throttle then the tank sock is not plugged because it is still feeding the carb fuel. What happens if you close the choke a little?
Re: 69 Dart GTS Fender tag help please. [Re: stumpy] #3167319
08/11/23 05:04 PM
08/11/23 05:04 PM
We didn't try that Stumpy...
Re: 69 Dart GTS Fender tag help please. [Re: tboomer] #3167325
08/11/23 05:18 PM
08/11/23 05:18 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Good point Stumpy has, seems lean and probably needs the carb serviced/cleaned. Could even be a float level issue?
Re: 69 Dart GTS Fender tag help please. [Re: A12] #3167336
08/11/23 05:53 PM
08/11/23 05:53 PM
I think you are correct!
Re: 69 Dart GTS Fender tag help please. [Re: tboomer] #3167353
08/11/23 06:58 PM
08/11/23 06:58 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Some detective work ahead of ya - like, does the seller know when that issue started (any changes) ?
Will it idle at a higher idle speed ? Runs roughly or smoothly ? Better when engine's up to temp ?
Hopefully the diaphragm base & cap are flat - they're commonly warped.
Need to check floats for corrosion, leaking fuel (won't float), setting.
Squirt some carb cleaner into the carb, especially the bleeds.
Could be a few things: plugged jets, improper idle adjustment...
Worth looking in the distributor & cap for corrosion while you're there.
Double-check your FT, some of that info doesn't read correctly...
Decoder info: https://www.mopar1.us/6971codes.html
Re: 69 Dart GTS Fender tag help please. [Re: topside] #3167380
08/11/23 08:30 PM
08/11/23 08:30 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Sometimes it's faster and easier to swap a known good working carburetor over if you have one, or can borrow one.
Re: 69 Dart GTS Fender tag help please. [Re: tboomer] #3167390
08/11/23 09:25 PM
08/11/23 09:25 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Me, I would use this to my advantage to maybe reduce the price of the car a little wink wink You know it runs but of course not like it should and it's going to take (a little) work or $$$ to get it corrected. Doesn't seem to me like it going to really be a big issue to resolve. A new carburetor, a carb rebuild, a carb swap with a known working used one. Ask the owner if with this issue they would consider less for it? What happens if you get it running correctly and the guy then figures it's worth more than what he was hoping to get, then you just fixed it for him and then wants more $$$. I'd see if he will take less and get it home and get it running correctly. twocents (and don't offer any help at this point on what might be wrong, again twocents
Sorry if I'm misreading the situation here but is seems you are fixing something that you don't own at the moment?
Mike
Re: 69 Dart GTS Fender tag help please. [Re: A12] #3167392
08/11/23 09:51 PM
08/11/23 09:51 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Mike
up iagree
years ago (1974?) A friend found a 68 GTS sitting in an apartment stall and had been there a while by the dust covering it. We made contact with the owner and he wanted 650 for it as i recall but it wouldn't start (which is why he parked it). I offered 450 and he was waffling. My buddy comments the money is greener than the car (it was green) So the owner took the offer. I popped in a new set of plugs I kept in the glove box of my 69 Swinger for unexpected late night uhhh contests smile Hit the key and away we went. AC plugs didn't seem to like leaded fuel and 340's at the time and that is what the car had in it wink Put about 30 or 40 k on it before selling it for 1,000 apimp up
Re: 69 Dart GTS Fender tag help please. [Re: TJP] #3167421
08/12/23 05:18 AM
08/12/23 05:18 AM
No cash has exchanged hands yet...I have a Moparts friend in the area that will try to help. I do want this car so I have no problem spending a few bucks on it. Topside..Thank you for that chart! My wife had some things wrong and I did figure out part of the tag.
Re: 69 Dart GTS Fender tag help please. [Re: tboomer] #3167453
08/12/23 11:24 AM
08/12/23 11:24 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
That IMO is even worse! Buy it/pay for it and I'll help you push it up on your trailer, go get the title transferred and then we'll fix YOUR GTS at home. Just saying because I can see and have seen good deals go bad. If you don't agree then post the contact info here and kiss it goodbye. Just close the deal if you really want it and then we'll all help to get it running so you can drive it OFF of your trailer at your home. twocents
Re: 69 Dart GTS Fender tag help please. [Re: A12] #3167457
08/12/23 11:57 AM
08/12/23 11:57 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Ted, I hope you're not gonna be in a position where you get the car running and then the price goes up.
If that's the seller's plan, your time and parts should be deducted from the new price, or you should be paid to walk away.
Maybe that's not a worry, but it's worth mentioning.
I've never bought a car that I had to work on before making the deal, but of course I don't know the whole story.
Just trying to be protective.
Re: 69 Dart GTS Fender tag help please. [Re: topside] #3167489
08/12/23 02:58 PM
08/12/23 02:58 PM
Here's an update...The owner called me and is having the carb rebuilt. I don't have to pay for it. He knows I will walk from the deal if something isn't right. Thanks for the help guys! I have never owned a Dart before. wave
Re: 69 Dart GTS Fender tag help please. [Re: A12] #3167523
08/12/23 07:09 PM
08/12/23 07:09 PM
IL us
I
ink Offline
ink  Offline
I
IL us
thought the same. if you get it running Nicey and he no longer wants to sell it or wants more?
Re: 69 Dart GTS Fender tag help please. [Re: ink] #3167527
08/12/23 07:18 PM
08/12/23 07:18 PM
If he no longer wants to sell it it's no big deal... And he is the one that is getting it running. Not me! And I did try to get it for less. He knows what he has.There's been guys trying to buy it for 20 years.
Re: 69 Dart GTS Fender tag help please. [Re: ink] #3167530
08/12/23 08:14 PM
08/12/23 08:14 PM
IL us
I
ink Offline
ink  Offline
I
IL us
I went through something similar a year ago "kind of" guy comes out to lqqk at a 68 gts I have for sale.12.5 was the agreed price. I consider 12.5 a project! I bought it as! car is rock solid with great dry bones. soiled floors. runs and drives fender tag q11 paint code 4 speed complete car. first problem his wife won't let him carry this much cash. tried to pay me every other way but cash (not happening) asks me if we can meet at his bank and do the transaction there? sure. Problem 2 he wants to drive the car to bank 2 hrs.' away? I don't even know if heater works and its feb, and 0*out. I tell him this and he said he will suit up. I told him I will trailer it for him. problem 3 for whatever reason he refuses. (My guess is he want to see how it runs long distance) I told him again this is a 12.5 project, and he can drive it around the block a hundred times but i think it safer to trailer it the two hrs. Again, he says he's wanting to drive it. the next morning! I messaged him and just laid into him!!!!!! I had had enough. if anything was to go wrong, I'm sure he can jump out of car and get in his father's truck following as I will be left on side of road in freezing weather.so what I'm saying is this. People think that they are going to buy a mopar like a 68 gts for 12.5 and take the grandkids for ice-cream or something? my guess is he is selling it at a price to sell? (project)? and if you keep heehawing around it just becomes not worth it for the seller! I was so sick of him he was the last person I was selling it to! I agree, you ether want it, or you don't! at the Vere least he now asks for more or tell you to pound sand! good luck!! I wouldn't push it through!
Re: 69 Dart GTS Fender tag help please. [Re: ink] #3167593
08/13/23 09:49 AM
08/13/23 09:49 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
If I want something badly I'll jump on it. He who snoozes, loses, is painfully true. However, if you don't have a burning desire to own the car, then it just doesn't matter. And that's not meant to be derogatory, it's just the truth.
Re: 69 Dart GTS Fender tag help please. [Re: tboomer] #3167792
08/14/23 10:10 AM
08/14/23 10:10 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
M25 R11 V1X END
There's a lot of missing numbers , like the entire bottom line for starters .
How old is the gas in the tank ? I had a similar issue many moons ago , I dumped gas in a tank that I THOUGHT was empty to get my Superbee running before I bought it , turns out the 5 gallons I dumped in was on top of the gas/varnish that was in it already , the bottom of the float was rotten away i discovered later when I pulled the tank ... try running the car from a known clean gas jug running a line from the fuel pump into the jug ...
Re: 69 Dart GTS Fender tag help please. [Re: tboomer] #3167801
08/14/23 10:51 AM
08/14/23 10:51 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
M25R11V1 X END
Tag should read:
M25 R11 V1X V8X End
C16 C55 G15 G33 L31 M21
B5 P6B B3 404 1696?4
E55 D32 LS23 P9B XXXXXX
This is a normal layout for a 69 GTS 340 automatic.
E55=340
D32=727 automatic trans
LS23=Dart Special hardtop
P9B=340 1969 Hamtramck, MI
XXXXXX=VIN number
B5=Blue metallic
P6B=Premium Blue Bucket seats
B3=Light blue door frame paint
404=April 4, 1969 build date
1606?4=SO# with one digit not reading correctly
C16=Console
C55=Bucket seats
G15=Tinted windshield only
G33=Left Hand outside chrome remote mirror
L31=Fender top turn signals
M21=Drip rail moldings
M25=Body sill moldings
R11=AM radio 2 watt
V1X=Black vinyl top
Should have a V88 or V8X indicating stripe
END=End of sequence
JB Rhinehart, Realist
A-Body's RULE!
Re: 69 Dart GTS Fender tag help please. [Re: JohnRR] #3167853
08/14/23 01:49 PM
08/14/23 01:49 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Second that notion. I bought this to use as a temporary fuel tank when the stock tank is unavailable for whatever reason. Tie wrap it to the grille and away we go.
Temporary Fuel Tank
Page 1 of 3 1 2 3
