Comp Cams 829-16 Roller Lifter Questions #3167303
08/11/23 04:34 PM
08/11/23 04:34 PM
N.W. INDIANA
moparjohn Offline OP
N.W. INDIANA
I have a big block MOPAR 493 engine used for bracket racing.
The runs are mostly 1/8th mile now days and I'm shifting at 6400 rpm.
How many runs before the Comp Cams 829-16 roller lifters need to be rebuilt?
Has anyone gotten their lifters rebuilt by Comp recently?
If not is there a shop where you can send them to for rebuilding?
Thanks in advance for your input.
MJ
Re: Comp Cams 829-16 Roller Lifter Questions [Re: moparjohn] #3167306
08/11/23 04:45 PM
08/11/23 04:45 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
MJ
I don't think comp rebuilds them anymore. I have run the small block version of that lifter and have had good luck. I put a few thousand miles each on a couple of sets and never had a problem. I had to move away from them for my current R1 block engine.
68 Barracuda Formula S 340
Re: Comp Cams 829-16 Roller Lifter Questions [Re: Bad340fish] #3167307
08/11/23 04:50 PM
08/11/23 04:50 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
If they thumb good I just keep running then. Had to upgrade Ka-Blue-E, but only because rpm went up
Re: Comp Cams 829-16 Roller Lifter Questions [Re: moparjohn] #3167309
08/11/23 04:54 PM
08/11/23 04:54 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Comp doesn’t offer the rebuild service any longer.
Re: Comp Cams 829-16 Roller Lifter Questions [Re: fast68plymouth] #3167334
08/11/23 05:43 PM
08/11/23 05:43 PM
PA
moparacer Offline
moparacer  Offline
PA
How many passes on them now? What spring pressures? More spring pressure, higher RPM, less passes you get before it eats a roller and makes a mess.
I got away from the needle bearing 829s several years ago when I got over 700 lbs open spring pressure.
Comp makes the bushed 829s now and that is what I use.
3rd year and 500+ passes on this set.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Comp Cams 829-16 Roller Lifter Questions [Re: moparacer] #3167355
08/11/23 07:05 PM
08/11/23 07:05 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I may try this place out for rebuilds.
https://johncalliesinc.com/rebuilds.php
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Comp Cams 829-16 Roller Lifter Questions [Re: moparacer] #3167386
08/11/23 08:59 PM
08/11/23 08:59 PM
N.W. INDIANA
N.W. INDIANA
moparacer,
There are 250 1/8th mile passes on the car now.
I don't see a spring pressure number in the build sheet.
Are you saying if you order a set of 829-16 lifters from Comp they will now be the bushed style?
Thanks!
Re: Comp Cams 829-16 Roller Lifter Questions [Re: moparjohn] #3167420
08/12/23 02:23 AM
08/12/23 02:23 AM
moparacer,
Thanks!
Call them and ask them scope twocents
Re: Comp Cams 829-16 Roller Lifter Questions [Re: moparjohn] #3167431
08/12/23 09:14 AM
08/12/23 09:14 AM
PA
moparacer Offline
moparacer  Offline
PA
No you can order them that way. They still make them with the needle bearings.
You probably still have some life left in them with your setup being lower RPM, but I can tell you I couldn't get much more than that out of mine before the problems started.
Re: Comp Cams 829-16 Roller Lifter Questions [Re: Cab_Burge] #3167444
08/12/23 10:12 AM
08/12/23 10:12 AM
So. Burlington, Vt.
So. Burlington, Vt.
The “829’s” are not available bushed.
The bushed lifters are from the Sportsman series.
The bushed version is 96829B-16
Re: Comp Cams 829-16 Roller Lifter Questions [Re: fast68plymouth] #3167511
08/12/23 04:56 PM
08/12/23 04:56 PM
N.W. INDIANA
N.W. INDIANA
So I took a look at Comps website.
The 829-16 lifters that I have been running are now $628.95.
The 96829B-16 are $1,195.95 so I would sure hope they would last longer.
I am going to contact johncalliesinc and see if they will rebuild my 829-16 lifters and go from there.
Thanks for all the replies and information!
MJ
Re: Comp Cams 829-16 Roller Lifter Questions [Re: moparjohn] #3167516
08/12/23 05:59 PM
08/12/23 05:59 PM
AndyF Offline
AndyF  Offline
You might consider switching brands. I'm in the process of building a 521 inch Ford drag race engine and we bought solid roller lifters from Jon Kaase. He has them custom built to his specs by Morel. They cost $575 a set and he says they work just fine on his 800 hp engines. I tend to trust Kaase but I guess we'll find out.
Re: Comp Cams 829-16 Roller Lifter Questions [Re: moparjohn] #3167528
08/12/23 07:40 PM
08/12/23 07:40 PM
PA
moparacer Offline
moparacer  Offline
PA
MJ
Holy cow, they weren't that expensive when I bought them.
But I can attest to the fact that a chewed up roller lifter, metal thrown behind the piston skirts, and a ruined cam isn't cheap either.
Re: Comp Cams 829-16 Roller Lifter Questions [Re: moparacer] #3167604
08/13/23 11:05 AM
08/13/23 11:05 AM
NC
440Jim Offline
440Jim  Offline
NC
What max RPM ? (shift or finish line).
Re: Comp Cams 829-16 Roller Lifter Questions [Re: moparacer] #3167614
08/13/23 11:40 AM
08/13/23 11:40 AM
NC
440Jim Offline
440Jim  Offline
NC
I run the Comp Cams 892 series lifter (pushrod oiling, tall) 892C, 892R, 892L (offset seats).
In 2021 they were $42 each, now they are $69 each. That is +64% and they don't come with link bars, those are extra for whatever engine you run.
Inflation is bad enough, but that is crazy price growth in just 2 years.
Re: Comp Cams 829-16 Roller Lifter Questions [Re: 440Jim] #3167643
08/13/23 02:23 PM
08/13/23 02:23 PM
AndyF Offline
AndyF  Offline
Yes, Comp Cams as well as Holley have been very aggressive with their price hikes. Holley has been raising prices every quarter for most parts.
Re: Comp Cams 829-16 Roller Lifter Questions [Re: AndyF] #3167659
08/13/23 03:55 PM
08/13/23 03:55 PM
So. Burlington, Vt.
So. Burlington, Vt.
BAM lifters just recently had a price increase as well.
Re: Comp Cams 829-16 Roller Lifter Questions [Re: fast68plymouth] #3167665
08/13/23 04:23 PM
08/13/23 04:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
They had a smallish increse IMO. We have purchased 3 sets the last 90 days.
Just got these last Monday and had them 6 days after order shipped across the country
Re: Comp Cams 829-16 Roller Lifter Questions [Re: 440Jim] #3167716
08/13/23 08:09 PM
08/13/23 08:09 PM
PA
moparacer Offline
moparacer  Offline
PA
800 over the nose on the intake side Jim. Less on the exhaust. I was shifting at 6900 and was 72 7300 in the traps in good air when I had 4:88s in it.
Today with 4:56s and bad air it was 6900 6900.
Re: Comp Cams 829-16 Roller Lifter Questions [Re: moparacer] #3167903
08/14/23 04:33 PM
08/14/23 04:33 PM
N.W. INDIANA
N.W. INDIANA
So I have checked with johncalliesinc about roller lifter rebuilding.
They don't answer questions direct and refer you to their dealer list.
So I contacted the closest dealer to me Howards Cams.
The tech guy there got back with me right away.
He informed me that the only roller lifters they rebuild is the house brand MOREL!
So I am still looking for a rebuilder for the Comps and also thinking of switching brands for one that can be rebuilt.
Do the BAM lifters offer a rebuilding service?
Thanks!
