Biggest tire on an e body Barracuda #3166005
08/06/23 03:09 PM
08/06/23 03:09 PM
Moved to N.E. Tennessee
GomangoCuda Offline OP
I've been using 275-60 for years. I am going to put a b body dana in it with Drdiff 1" offset spring mounts. Looks like 295-65 should fit and 315-60 might fit. Will a 10.5 slick fit? Who has done any of these.
Re: Biggest tire on an e body Barracuda [Re: GomangoCuda] #3166012
08/06/23 03:27 PM
08/06/23 03:27 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I ran 295/65s for years. Offset springs, a little trimming on the wheel lip molding, a 3/8" spacer in front of the front spring perch and custom back spacing on the 10" Cragars. The rear shackle hanger did rub some on the rear valance.
A little tip on the rims: If you need to order custom back spacing like I did, order them with about 1/4" too little inside spacing. They are not usually perfect. And it is a lot easier to space them out a bit than it is to move them in. twocents
Master, again and still
Re: Biggest tire on an e body Barracuda [Re: DaveRS23] #3166023
08/06/23 04:30 PM
08/06/23 04:30 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
29565/ 0r 295/50's will fit nicely with the B Body axle and -1" relocation kit. 315/60's will not fit. I had to mine tub mine and move the springs to the frame rails to get 315's to fit on mine.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Biggest tire on an e body Barracuda [Re: 6PKRTSE] #3166094
08/06/23 09:29 PM
08/06/23 09:29 PM
Thanks, 295's it is.
Re: Biggest tire on an e body Barracuda [Re: GomangoCuda] #3166512
08/08/23 11:53 AM
08/08/23 11:53 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
The Nitto 325-50/15's mounted on 15 x 10" steelies fit my '70 'Cuda with a B-body Dana, plus 1" Espo springs & Dr Diff inset hanger kit. Doesn't rub on springs or body. I do use steel spacers and slightly longer wheel studs to fine tune the position of the wheels in the wheel well.
Re: Biggest tire on an e body Barracuda [Re: jbc426] #3166639
08/08/23 07:09 PM
08/08/23 07:09 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
A friends 70 Barracuda AAR (with Hemi) with stock springs had iirr, 14/32 Firestones, a little messaging around the edges was done.
