Biggest tire on an e body Barracuda
#3166005
08/06/23 03:09 PM
08/06/23 03:09 PM
Posts: 4,722 Moved to N.E. Tennessee
GomangoCuda
I've been using 275-60 for years. I am going to put a b body dana in it with Drdiff 1" offset spring mounts. Looks like 295-65 should fit and 315-60 might fit. Will a 10.5 slick fit? Who has done any of these.
Re: Biggest tire on an e body Barracuda
[Re: GomangoCuda]
#3166012
08/06/23 03:27 PM
08/06/23 03:27 PM
Posts: 12,085 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I ran 295/65s for years. Offset springs, a little trimming on the wheel lip molding, a 3/8" spacer in front of the front spring perch and custom back spacing on the 10" Cragars. The rear shackle hanger did rub some on the rear valance. A little tip on the rims: If you need to order custom back spacing like I did, order them with about 1/4" too little inside spacing. They are not usually perfect. And it is a lot easier to space them out a bit than it is to move them in.
Master, again and still
[Re: DaveRS23]
#3166023
08/06/23 04:30 PM
08/06/23 04:30 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
29565/ 0r 295/50's will fit nicely with the B Body axle and -1" relocation kit. 315/60's will not fit. I had to mine tub mine and move the springs to the frame rails to get 315's to fit on mine.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: GomangoCuda]
#3166512
08/08/23 11:53 AM
08/08/23 11:53 AM
Posts: 3,278 West Coast, USA
jbc426
West Coast, USA
The Nitto 325-50/15's mounted on 15 x 10" steelies fit my '70 'Cuda with a B-body Dana, plus 1" Espo springs & Dr Diff inset hanger kit. Doesn't rub on springs or body. I do use steel spacers and slightly longer wheel studs to fine tune the position of the wheels in the wheel well.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
