470" by Compu-Flow came home today #3166064
08/06/23 08:17 PM
08/06/23 08:17 PM
USA
hudsonhornet7x Offline OP
USA
Wanted to share.
470"
1978 400 Block
Trick Flow Intake port matched to heads
Trick Flow 270 heads
Harland Sharp 1.6 rockers
Smith Brothers Push Rods
Holley 950 HP
Comp XS290S solid cam
Ross Pistons
Eagle Rods
Molnar Crank
Compu-Flow valley pan
A.R. Engineering Motor Plate
Re: 470" by Compu-Flow came home today [Re: hudsonhornet7x] #3166090
08/06/23 09:22 PM
08/06/23 09:22 PM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
Sweet! Not sure specs on that cam, but i'm sure it will run well.
Re: 470" by Compu-Flow came home today [Re: hudsonhornet7x] #3166142
08/06/23 11:45 PM
08/06/23 11:45 PM
AndyF Offline
AndyF  Offline
Should be a nice solid 600+ HP engine.
Re: 470" by Compu-Flow came home today [Re: hudsonhornet7x] #3166224
08/07/23 11:58 AM
08/07/23 11:58 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Is this Nicks old business?? A son maybe?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 470" by Compu-Flow came home today [Re: hudsonhornet7x] #3166236
08/07/23 12:25 PM
08/07/23 12:25 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Do you know if they installed a cam button? I see that washer welded to the timing cover.
Did they dyno it?
Re: 470" by Compu-Flow came home today [Re: hudsonhornet7x] #3166241
08/07/23 12:41 PM
08/07/23 12:41 PM
NC
440Jim Offline
440Jim  Offline
NC
Ingine Family:Chrysler 383-440 c.i. 8 Cylinder (1959-1980)
RPM Operating Range:3200-7,000
Grind Number:XS290S
Cam Type:Solid Flat Tappet
Lifter Style:Solid Flat Tappet
Camshaft Series:Xtreme Energy
Usage:Street/Performance
Advertised Intake Duration: 290, Intake Duration at .050 Inch Lift: 252
Advertised Exhaust Duration: 298 Exhaust Duration at .050 Inch Lift: 260
Intake Valve Lift:0.54
Exhaust Valve Lift:0.558
Lobe Separation:110
Is this your cam?
Re: 470" by Compu-Flow came home today [Re: pittsburghracer] #3166292
08/07/23 02:52 PM
08/07/23 02:52 PM
USA
USA
Yes, his son did the work.
Re: 470" by Compu-Flow came home today [Re: GTX MATT] #3166293
08/07/23 02:53 PM
08/07/23 02:53 PM
USA
USA
Did they dyno it?
The engine has been broken it, but no dyno. No cam button that I am aware of. Flat tappet cam.
Re: 470" by Compu-Flow came home today [Re: 440Jim] #3166294
08/07/23 02:54 PM
08/07/23 02:54 PM
USA
USA
Grind Number:XS290S
Lobe Separation:110
Is this your cam?
Yep that is the cam used in this engine.
Re: 470" by Compu-Flow came home today [Re: hudsonhornet7x] #3166576
08/08/23 03:08 PM
08/08/23 03:08 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Good deal, glad you got it done.
Rich H.
Esse Quam Videri
Re: 470" by Compu-Flow came home today [Re: ZIPPY] #3166578
08/08/23 03:14 PM
08/08/23 03:14 PM
USA
USA
Thanks man, I will be able to finish the car and drive it while collecting parts for my hemi. That is the end game but it will take a looong while I am sure!
Re: 470" by Compu-Flow came home today [Re: hudsonhornet7x] #3166740
08/09/23 08:28 AM
08/09/23 08:28 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Nice!
Re: 470" by Compu-Flow came home today [Re: hudsonhornet7x] #3166747
08/09/23 08:47 AM
08/09/23 08:47 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I liked Nick and was sorry to hear that he passed. I hope the business is going well for his son now.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: 470" by Compu-Flow came home today [Re: Brad_Haak] #3166768
08/09/23 10:40 AM
08/09/23 10:40 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Nick was a good dude, I enjoyed talking to him on the phone.
Had to replace a bad block for him once,
and that replacement resulted in the machining program being changed.
I wonder if the current block supply chain has any idea of that tweak, but maybe I shouldn't want to know.
Rich H.
Esse Quam Videri
Re: 470" by Compu-Flow came home today [Re: hudsonhornet7x] #3168597
08/17/23 05:52 PM
08/17/23 05:52 PM
Ontario, Canada
500ciBee Offline
500ciBee  Offline
Ontario, Canada
Nice build!
Is that a standard port intake ported to max wedge size? If so, who did it and how much?
1970 Super Bee prostreet. 383, SMR 727, Dana 60 4:88. Building a 512 low deck.
Re: 470" by Compu-Flow came home today [Re: 500ciBee] #3168636
08/17/23 08:16 PM
08/17/23 08:16 PM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
Excited for you!! Should run great!!
Loved Nick Sr. I live around the corner from him. He followed me home in the Dart one time to make sure everything was running well. Nick Jr is a chip off the old block. Super solid guy
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: 470" by Compu-Flow came home today [Re: 500ciBee] #3168753
08/18/23 10:08 AM
08/18/23 10:08 AM
USA
USA
Originally Posted by 500ciBee
Nice build!
Yes, it is a standard port intake opened up to max wedge. Nick Jr. did that for me when he built the engine. Not sure how much it cost since I had the whole engine done over there.
Re: 470" by Compu-Flow came home today [Re: hudsonhornet7x] #3169037
08/19/23 02:34 PM
08/19/23 02:34 PM
Ontario, Canada
500ciBee Offline
500ciBee  Offline
Ontario, Canada
Nice build!
Thanks! I’ll probably be doing the same.
