Re: 470" by Compu-Flow came home today
[Re: hudsonhornet7x]
#3166224
08/07/23 11:58 AM
08/07/23 11:58 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Is this Nicks old business?? A son maybe?
#3166236
08/07/23 12:25 PM
08/07/23 12:25 PM
Posts: 5,161 CT
GTX MATT
CT
Do you know if they installed a cam button? I see that washer welded to the timing cover.
Did they dyno it?
#3166241
08/07/23 12:41 PM
08/07/23 12:41 PM
Posts: 16,925 NC
440Jim
NC
Ingine Family:Chrysler 383-440 c.i. 8 Cylinder (1959-1980) RPM Operating Range:3200-7,000 Grind Number:XS290S Cam Type:Solid Flat Tappet Lifter Style:Solid Flat Tappet Camshaft Series:Xtreme Energy Usage:Street/Performance Advertised Intake Duration: 290, Intake Duration at .050 Inch Lift: 252 Advertised Exhaust Duration: 298 Exhaust Duration at .050 Inch Lift: 260 Intake Valve Lift:0.54 Exhaust Valve Lift:0.558 Lobe Separation:110 Is this your cam?
[Re: pittsburghracer]
#3166292
08/07/23 02:52 PM
08/07/23 02:52 PM
Posts: 1,541 USA
hudsonhornet7x
USA
Yes, his son did the work.
[Re: GTX MATT]
#3166293
08/07/23 02:53 PM
08/07/23 02:53 PM
Posts: 1,541 USA
hudsonhornet7x
USA
Did they dyno it? The engine has been broken it, but no dyno. No cam button that I am aware of. Flat tappet cam.
[Re: 440Jim]
#3166294
08/07/23 02:54 PM
08/07/23 02:54 PM
Posts: 1,541 USA
hudsonhornet7x
USA
Ingine Family:Chrysler 383-440 c.i. 8 Cylinder (1959-1980) RPM Operating Range:3200-7,000 Grind Number:XS290S Cam Type:Solid Flat Tappet Lifter Style:Solid Flat Tappet Camshaft Series:Xtreme Energy Usage:Street/Performance Advertised Intake Duration: 290, Intake Duration at .050 Inch Lift: 252 Advertised Exhaust Duration: 298 Exhaust Duration at .050 Inch Lift: 260 Intake Valve Lift:0.54 Exhaust Valve Lift:0.558 Lobe Separation:110 Is this your cam? Yep that is the cam used in this engine.
[Re: ZIPPY]
#3166578
08/08/23 03:14 PM
08/08/23 03:14 PM
Posts: 1,541 USA
hudsonhornet7x
USA
Good deal, glad you got it done. Thanks man, I will be able to finish the car and drive it while collecting parts for my hemi. That is the end game but it will take a looong while I am sure!
#3166747
08/09/23 08:47 AM
08/09/23 08:47 AM
Posts: 1,126 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Yes, his son did the work. I liked Nick and was sorry to hear that he passed. I hope the business is going well for his son now.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3166768
08/09/23 10:40 AM
08/09/23 10:40 AM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
Nick was a good dude, I enjoyed talking to him on the phone.
Had to replace a bad block for him once, and that replacement resulted in the machining program being changed. I wonder if the current block supply chain has any idea of that tweak, but maybe I shouldn't want to know.
Rich H.
Esse Quam Videri
#3168597
08/17/23 05:52 PM
08/17/23 05:52 PM
Posts: 136 Ontario, Canada
500ciBee
Ontario, Canada
Nice build! Is that a standard port intake ported to max wedge size? If so, who did it and how much?
1970 Super Bee prostreet. 383, SMR 727, Dana 60 4:88. Building a 512 low deck.
[Re: 500ciBee]
#3168636
08/17/23 08:16 PM
08/17/23 08:16 PM
Posts: 314 Medina, OH
dart440_72
Medina, OH
Excited for you!! Should run great!! Loved Nick Sr. I live around the corner from him. He followed me home in the Dart one time to make sure everything was running well. Nick Jr is a chip off the old block. Super solid guy
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
[Re: 500ciBee]
#3168753
08/18/23 10:08 AM
08/18/23 10:08 AM
Posts: 1,541 USA
hudsonhornet7x
USA
Nice build! Is that a standard port intake ported to max wedge size? If so, who did it and how much? Yes, it is a standard port intake opened up to max wedge. Nick Jr. did that for me when he built the engine. Not sure how much it cost since I had the whole engine done over there.
#3169037
08/19/23 02:34 PM
08/19/23 02:34 PM
500ciBee
Ontario, Canada
Nice build! Is that a standard port intake ported to max wedge size? If so, who did it and how much? Yes, it is a standard port intake opened up to max wedge. Nick Jr. did that for me when he built the engine. Not sure how much it cost since I had the whole engine done over there. Thanks! I’ll probably be doing the same.
