Bearing check please #3165147
08/02/23 05:04 PM
08/02/23 05:04 PM
Spahn Ranch
RMCHRGR Offline OP
RMCHRGR  Offline OP
Spahn Ranch
I am taking apart a 416" that I built several years ago to refresh it and change some top end parts. This engine has only seen dyno time but then afterwards it sat for 7+ years. I used the appropriate sticky red assembly lube on all the bearing surfaces and journals. The oil system was primed before startup. The engine fired on the first try during the break-in and was run through the proper break-in procedure. Oil pressure was fine.
To me, these rod bearings look a little rough but I'm not sure. Clearly there was some dirt in the engine but as far as I could tell, there were no visible shavings in the oil pan or stuck to the drain plug. I'm wondering if junk got in there while it was sitting and the rash happened when it was turned over? I suppose the bearings did their job embedding whatever debris was in there. All 8 look like this to some degree.
My question is do I need to get new bearings? I have not taken the crank out yet so I don't know if those look the same. The rod journals on the crank seem OK though, I don't see any gouges or what have you. Obviously I need to do a better job cleaning when I reassemble it.
Thanks for any input.
Greg
'71 Duster
'17 Ram 1500
Re: Bearing check please [Re: RMCHRGR] #3165153
08/02/23 05:33 PM
08/02/23 05:33 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
Definitely some dirt. You’re in the bottom end, put new ones in. Old engine builder told me to buff the bearings with paper bag paper, makes the bearing nice and smooth without removing any material. Clean with lint free shop towels. Super clean everything.
Re: Bearing check please [Re: rickraw] #3165155
08/02/23 06:02 PM
08/02/23 06:02 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Send IT
Re: Bearing check please [Re: FastmOp] #3165185
08/02/23 08:24 PM
08/02/23 08:24 PM
A727Tflite Offline
A727Tflite  Offline
If the mains are perfect then you had debris in the rod journal oilers in the crank.
If the mains have the same appearance then you had debris upstream, galleries, etc. look at the cam bearings too.
Rifle brush the crank passages, same with the block passages if you pull the engine down.
I would just Scotch Brite the bearings and wash them with soap and water then with mineral spirits.
I don’t dry any internals with a shop or paper towel. Blow it dry. Then lube it as you assemble.
Of course make sure you have a clean well functioning water and dirt trap/filter on your air line.
You should make sure you have a dedicated air hose after the filter/trap that you use just for engine/trans assembly and that it never gets used without that filter.
Blow the air gun in to a clean, old t shirt and see if trash comes out. Sorry for the long post.
Re: Bearing check please [Re: RMCHRGR] #3165239
08/03/23 03:17 AM
08/03/23 03:17 AM
Is one of those bearing shells coated with a black dry film lube? Either way I would replace that bearing based on how deep that scratched groove is int that bearing half twocents
I had a old timer tell me years ago that engine assembling is like brain surgery, it is absolutely impossible to keep it to clean iagreeup
Re: Bearing check please [Re: Cab_Burge] #3165274
08/03/23 10:19 AM
08/03/23 10:19 AM
Spahn Ranch
RMCHRGR Offline OP
RMCHRGR  Offline OP
Spahn Ranch
Well here is the #2 cap bearing.
'71 Duster
'17 Ram 1500
Re: Bearing check please [Re: RMCHRGR] #3165281
08/03/23 11:02 AM
08/03/23 11:02 AM
A727Tflite Offline
A727Tflite  Offline
Check all the mains and all the rods. Then see my earlier post.
If all the rods look the same and all the mains look good like this one then likely you had some minor debris in the crank oilers itself.
Your call of course - replace the bearings or clean them up. Good luck. 👍
Re: Bearing check please [Re: RMCHRGR] #3165589
08/04/23 03:08 PM
08/04/23 03:08 PM
Boise
Moparteacher Offline
Boise
The parallel lines on the bearing seams to indicate there's a problem with the finishing on the crank, dirt aside. The first pic has lost most of the the top coat of babbit, the second bearing is dirt or metal. The main and first rod pic says crank finish. Polish the bearing with anything and they are no longer tri-metal, but now bi-metal bearings. The babbit is soft, thin, and porous, and designed to capture and hold micro particles of carbon to protect the crank surface. You no longer have that protection.
Re: Bearing check please [Re: Moparteacher] #3165621
08/04/23 06:15 PM
08/04/23 06:15 PM
Spahn Ranch
RMCHRGR Offline OP
RMCHRGR  Offline OP
Spahn Ranch
Thanks for the replies. I think I'm going to get new bearings. These are King XP bearings, probably some of the best bearings out there. Replacing them is not going to be cheap so this was an expensive lesson in cleanliness.
These are not the coated type but they do have electroplating. I might get the coated type this time. If debris gets in the engine the coating is supposed to re-embed itself into the bearing surface which is like another layer of protection. The clearances are the same.
Except for lubing the parts, I've never done anything to bearings before putting them in. Sorry, but I can't see polishing them with paper or taking Scotchbrite to these would do anything except remove the top layer.
Hard to figure what could be wrong with the crank finish? Not that it has anything to do with wear but the crank turns so effortlessly in the block, it's almost fun to spin it by hand. The lines almost look like chatter marks. I'll double check everything before buttoning up the bottom end but the clearances were damn near perfect.
'71 Duster
'17 Ram 1500
Re: Bearing check please [Re: RMCHRGR] #3165623
08/04/23 06:25 PM
08/04/23 06:25 PM
A727Tflite Offline
A727Tflite  Offline
Back in the 60’s and 70’s Chrysler used aluminum bearings in some or most applications, uncoated.
Edit.
Those bearings have consistent wear marks, evenly spaced. That means only one thing, poor finish grind if on one journal. If on all journals it’s part of the machining process of the bearings.
You can’t get dirt to be evenly spaced like that.
Good luck.
Re: Bearing check please [Re: A727Tflite] #3165625
08/04/23 06:51 PM
08/04/23 06:51 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
How tight are your clearances? I have a set of bearings, king coated that show them exact same lines and they were on a K1 crank. In my case they were just a bit on the tight side. I did not re use them. Can take pics if it would help.
STOP POTATO HATE!
Re: Bearing check please [Re: Mr PotatoHead] #3165656
08/04/23 08:29 PM
08/04/23 08:29 PM
Spahn Ranch
RMCHRGR Offline OP
RMCHRGR  Offline OP
Spahn Ranch
Clearances are .0025". My machinist is very good. I double checked it with Plastigage on assembly, was right on the money.
Pics would be great if you can, thanks. I'd like to see for my own edification as I'm sure others might too. I'd rather not get new main bearings if there's no need.
'71 Duster
'17 Ram 1500
Re: Bearing check please [Re: RMCHRGR] #3165659
08/04/23 09:34 PM
08/04/23 09:34 PM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
So is it crank imperfections or something in the bearing MFG process? This was a K1 forged stroker kit and owner was set on using kings vs the supplied clevite.
The story here is a friend had a box fresh R block and had all the machine work done including align hone. He asked if he could bring it over and use my test stand to break in cam. It had crazy high OP from the start 90 idle and up from there so we knew something was wrong but it never got over 160 and cam broke in without issue.
After an oil change and maybe a total 1 hour run time with a few blips just over 4k it was the same high op. I told him imo it would not fly as it was and there was some material in the filter. Turns out there was a skirt issue that the mfg. went well above to correct.
When I pulled the crank I found two like this, was supposed to be king extra .001 mains but there were two STD halves in the lowers. This did not shock me because I myself have found this three times with King Bearings. They seem to understand it happens as they are quick to take care of it.
So I started to measure things further. He says he told the machine shop he needed at the end of the day .003 on the mains but in reality someone got crossed as there was a consistent .0015 TOTAL. (He used a shop not deep into performance builds and maybe that was part of the confusion, who knows)
So block went back to get align honed properly. Pistons got replaced by mfg. and King sent a new set of matched bearings and all was happy after that.
The pattern looks much like yours... Please keep in mind some of the dirt might be from these being in the "oops" box on my junk shelf for like 5 years, maybe longer so I had to wash and they have been tossed around a good but without care.
STOP POTATO HATE!
Re: Bearing check please [Re: Mr PotatoHead] #3165663
08/04/23 09:59 PM
08/04/23 09:59 PM
A727Tflite Offline
A727Tflite  Offline
I edited my post - I agree, these marks being from the bearing manufacturing process if all the bearings in a set look the same and not on just one bearing upper/lower.
Re: Bearing check please [Re: Mr PotatoHead] #3165667
08/04/23 10:14 PM
08/04/23 10:14 PM
Spahn Ranch
RMCHRGR Offline OP
RMCHRGR  Offline OP
Spahn Ranch
There you go, thank you! Has to be the way they make the bearings. I will call King again on Monday and see if they will confirm this is normal. Still going to replace the rod bearings because of the one badly scratched one but seems like the mains are OK.
If it was a crank journal finish issue you'd think there would be some sort of damage to the crank journals themselves which there isn't.
'71 Duster
'17 Ram 1500
Re: Bearing check please [Re: RMCHRGR] #3165671
08/04/23 10:27 PM
08/04/23 10:27 PM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
This whole set showed like the one I posted. I also noticed you posted yours were from many years ago. I know this deal I explained was at least five years ago possibly longer, I will look in my notebook tomorrow just for kicks.
STOP POTATO HATE!
Re: Bearing check please [Re: A727Tflite] #3165673
08/04/23 10:27 PM
08/04/23 10:27 PM
Spahn Ranch
RMCHRGR Offline OP
RMCHRGR  Offline OP
Spahn Ranch
Agree, thanks.
'71 Duster
'17 Ram 1500
