Page 2 of 3 1 2 3
Re: How "wild & crazy" have you gone w/ converter for street? [Re: B3422W5] #3162658
07/24/23 10:16 AM
07/24/23 10:16 AM
an8sec70cuda Offline
Originally Posted by B3422W5
Originally Posted by n20mstr
UNLESS your daily driving it / commuting with it ...... who really cares??
Get the best converter that works at the track , get a decent cooler on it and a trans temp gauge. Street cruise it....
thats what i would do ..... whistling
Agree 100%… converter technology has come a long ways.
I have never run anything but 8 inch converter suited to best Et at the track, and everything I have had in the last 30 years has been street/ strip. Good cooler, have fun.
iagree Run what the combo needs to go fast. With a decent trans cooler it'll be fine on the street.
I've run a couple of different 5000-5200 converters on the street w/ no issues.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: How "wild & crazy" have you gone w/ converter for street? [Re: an8sec70cuda] #3163270
07/26/23 07:51 AM
07/26/23 07:51 AM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
Like Fred from Scooby Doo says: Hey, gang, I have a plan! wink
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: How "wild & crazy" have you gone w/ converter for street? [Re: Brad_Haak] #3163273
07/26/23 07:59 AM
07/26/23 07:59 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I have a 9" Ultimate in my car, it flashes around 4500 at launch and is ~5k minimum going down the track on nitrous passes. No issues with trans temp, the fluid always looks perfect and I've put thousands of miles on it, including a 700 mile drag and drive last month. I do use ATI synthetic type F though. It cruises fine with 2-3% slip at moderate freeway speeds. 30" tall tire and 4.10's. As long as you can live with the slightly disconnected feeling at low speeds I wouldn't worry at all.
Re: How "wild & crazy" have you gone w/ converter for street? [Re: Brad_Haak] #3163282
07/26/23 08:52 AM
07/26/23 08:52 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I have a Turbo Action "J" converter that was custom built for a completely different combination, totally unrelated to mine (572ci, high compression nitrous A body).
According to Paul at TA it's built as tight as they can possibly make that configuration. It's only around 4500 flash with my wimpy street combination.
Overall I do like it, but I've found the more I load the vehicle down the less I like it.
Back in the days of dragging around two extra wheels and tires, full size steel floor jack, jack stands, couple tool boxes, etc etc etc
(And then hope like hell Blusmbl would show up and help me change the tires), it did feel pretty darn sloppy after an hour and a half on
M59 and 23 commuting to and from Milan in the summer heat. The rest of the time, no complaints. Driving a shorter distance to and from Lapeer and NOT changing tires,
and not hauling tons of extra stuff around, I get along with it much better. Normal cruising without a big payload, it's good.
If anything I'll be adding weight to the car, and 451ci to 572ci is a substantial jump, but I'll try it with the big motor to see if I can get along with it.
Honestly I'd prefer it to be tighter for driving around, and maybe a 572 ci street engine doesn't need all that stall speed, but there's only one way to find out.
Oh, and when I redo the interior I'm putting the 4 speed piece back on the trans tunnel as Chrysler intended.
Because.....well, you never know......The pedals are still there.....
I'll mount an automatic shifter to it but who knows what might happen later?
Rich H.
Esse Quam Videri
Re: How "wild & crazy" have you gone w/ converter for street? [Re: ZIPPY] #3163532
07/26/23 09:44 PM
07/26/23 09:44 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Isn't the solution to this in a modern automatic with electronic control? Run a big stall, but have electronic lockup with a triple disc converter for cruising around and "normal" acceleration.
Re: How "wild & crazy" have you gone w/ converter for street? [Re: Uberpube] #3163563
07/27/23 08:05 AM
07/27/23 08:05 AM
Loudoun County, VA
Loudoun County, VA
^^^ Not for my car, unless you are funding the initiative
Re: How "wild & crazy" have you gone w/ converter for street? [Re: jim sciortino] #3163765
07/27/23 10:44 PM
07/27/23 10:44 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Originally Posted by jim sciortino
Ultimate 8" from Lenny. With a 5.14 rear gear and a 104 rollout tire, it would flash to 7200 rpm, yet was very driveable.
Great converters!
I run an Ultimate/Lenny 8 1/2" 5500 behind a 540, with 4.10s. Totally street driven. Never had any heating issues with a good cooler and deep pan.
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: How "wild & crazy" have you gone w/ converter for street? [Re: jughed] #3163780
07/28/23 12:06 AM
07/28/23 12:06 AM
Every street and strip car that I have had a good tranny temp gauge with a 8 or 9 inch good street and strip converter was hard to get them to run above 160F with a decent size tranny cooler mounted in front of the radiators without routing the tranny fluid through the stock type tranny cooler in them confused shruggy
Dominic ended up moving his down lower behind the front bumper to get his to run above 160F up scope
Re: How "wild & crazy" have you gone w/ converter for street? [Re: Brad_Haak] #3165163
08/02/23 06:22 PM
08/02/23 06:22 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
Originally Posted by Brad_Haak
FWIW, I talked to Sean at Dynamic and asked him if they'd recommend an 8" to better suit the new engine combination than my current 9.5". Surprisingly (to me, at least) he said they'd stick w/ a 9.5" but build it with a different stator (and?) to account for the change in HP & torque curves.
I also e-mailed the ATI tech folks asking about one of their 8" Treemaster converters; not sure when I'll hear back on that, but I'm curious what they say. work ATI's maybe 60-65 miles from me, so they're not too far away.
Myself and friends have had really good success with the Dynamic 9.5 for street and track use, for many years now.
They can do a lot with the stator
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: How "wild & crazy" have you gone w/ converter for street? [Re: Brad_Haak] #3165271
08/03/23 10:13 AM
08/03/23 10:13 AM
Loudoun County, VA
Loudoun County, VA
I'm purchasing an ATI 8" that Dwayne Porter spec'd originally for a 440 bracket car, but never used.
ATI says it's too loose for my application, but the option is always there to have them re-config it w/ different pump & stator, per their Tech Dept.
Re: How "wild & crazy" have you gone w/ converter for street? [Re: Brad_Haak] #3165292
08/03/23 12:34 PM
08/03/23 12:34 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
With my experience with ATI if they say its going to be to loose I would be willing to bet its spot on. Every converter I have ever gotten from them for me or a customer was on the tight side.
Re: How "wild & crazy" have you gone w/ converter for street? [Re: Brad_Haak] #3165329
08/03/23 02:51 PM
08/03/23 02:51 PM
AndyF Offline
AndyF  Offline
The driveshaft speed sensor on your data logger will tell you what the stall speed is
Re: How "wild & crazy" have you gone w/ converter for street? [Re: AndyF] #3165340
08/03/23 03:24 PM
08/03/23 03:24 PM
moparx Offline
moparx  Offline
anyone ever use a transbrake converter with a normal manual valve body ?
if so, did the converter work ok ?
if the converter didn't work out, what was/were the issue/issues with it not working ?
just a general question, as i have a converter that was used in a transmission i have now, that i was planning to use. however, i plan to replace the transbrake valve body that is in the transmission now with a normal manual valve body.
beer
Re: How "wild & crazy" have you gone w/ converter for street? [Re: moparx] #3165406
08/03/23 07:53 PM
08/03/23 07:53 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Just got back from cruising my long dormant street car. Supercharged mild 340, 9.5" PTC 5300 flash, average size trans cooler, generic 2 row aluminum radiator, junkyard electric fan, 4.30 gear, 325/50 radials, 3885lbs with me in it. It's 87 degrees here. Stop and go and a 50 mph cruise. Coolant never went over 195. Trans stayed below 200. Beat on it some to boot.
Doug
Re: How "wild & crazy" have you gone w/ converter for street? [Re: dvw] #3165409
08/03/23 07:58 PM
08/03/23 07:58 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
SAME here on the above
Im pretty fond of my PTC 9.5 vert, hurts many modern car guys feeling when the start talking about there factory 2 step and 7k redline... ha ha ha
STOP POTATO HATE!
Re: How "wild & crazy" have you gone w/ converter for street? [Re: Mr PotatoHead] #3166135
08/06/23 11:16 PM
08/06/23 11:16 PM
wine country
8
8urvette Offline
8urvette  Offline
wine country
is anyone running one of these 300$+ trans coolers? are they necessary????
Re: How "wild & crazy" have you gone w/ converter for street? [Re: 8urvette] #3166160
08/07/23 06:44 AM
08/07/23 06:44 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I think one of those is better suited when you are running it under the car with no airflow.
68 Barracuda Formula S 340
Re: How "wild & crazy" have you gone w/ converter for street? [Re: Bad340fish] #3166190
08/07/23 10:10 AM
08/07/23 10:10 AM
I use an old permacool (i think?) trans cooler I bought off the shelf at advance auto parts 25 years ago, lol.
CHIP
Re: How "wild & crazy" have you gone w/ converter for street? [Re: an8sec70cuda] #3166204
08/07/23 11:09 AM
08/07/23 11:09 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
What is a "Trans Cooler"??? LOL!!!
69 GTX 68 Road Runner
Re: How "wild & crazy" have you gone w/ converter for street? [Re: JERICOGTX] #3166244
08/07/23 12:54 PM
08/07/23 12:54 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
It is used to keep the dustless fluid cool in the magic viscous torque multiplying device with lightning fast shifts.
Page 2 of 3 1 2 3
