Re: Starting a rebuilt engine out of the car
[Re: mgoblue9798]
#3163299
07/26/23 09:56 AM
07/26/23 09:56 AM
Posts: 28,611 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
An old dirt track racer I knew used to rebuild stockish engines for local folks. He would set the oil pan and trans on some old tires and fire them up to break them in right there in the floor. Same way the junk yards did back in the day. Would have manifolds and the short pieces of heads pipes cut off with a fire wrench. Even if smoked and rattled some on start up thet would say something like, purrs like a kitten. If ya have a problem just come back in 30 day's. One place was known to sell almost anything that fired up.and ran that did not knock.
[Re: mgoblue9798]
#3163300
07/26/23 10:01 AM
07/26/23 10:01 AM
Posts: 12,244 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Yep, it doesn't take anything elaborate as long as some common sense is in play.
Master, again and still
[Re: stumpy]
#3163319
07/26/23 10:36 AM
07/26/23 10:36 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
Why do you need to loop the trans lines if the trans doesn't pump in park? Just curious. But if you fill the trans you will need to plug the tail shaft. The trans does pump in park , not as much as it does in neutral , and that is assuming it doesn't have a some type of shift kit or someone put in an updated manual valve.
[Re: DaveRS23]
#3163323
07/26/23 10:37 AM
07/26/23 10:37 AM
JohnRR
Why do you need to loop the trans lines if the trans doesn't pump in park? Just curious. But if you fill the trans you will need to plug the tail shaft. It can still move enough fluid to make a mess. Looping the cooler inlet and outlet is just a good precaution. Along with sticking a plug, or yoke, in the end of the trans .
[Re: 340SIX]
#3163360
07/26/23 12:32 PM
07/26/23 12:32 PM
Posts: 19,589 north of coder
moparx
An old dirt track racer I knew used to rebuild stockish engines for local folks. He would set the oil pan and trans on some old tires and fire them up to break them in right there in the floor. Same way the junk yards did back in the day. Would have manifolds and the short pieces of heads pipes cut off with a fire wrench. Even if smoked and rattled some on start up thet would say something like, purrs like a kitten. If ya have a problem just come back in 30 day's. One place was known to sell almost anything that fired up.and ran that did not knock. just like i did back in my yard ownership days [1972-1984/5] if the engine/transmission unit wasn't in the car. we sold stuff cheap, not to keep. the old "5 days, 500 feet" guarantee............it was just about 600 feet from the yard to the main road. seriously though, if a problem developed in a reasonable amount of time, even if it was an unknown item, we would work through any difficulties that would arise as we figured a good word was worth a thousand bucks ! remember, this was before the interwebs were even considered. we were also one of the, if maybe the only, "pick your own part" yards in existence at the time.
[Re: JohnRR]
#3163500
07/26/23 07:59 PM
07/26/23 07:59 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
[Re: TJP]
#3163836
07/28/23 10:29 AM
07/28/23 10:29 AM
Posts: 940 Metro Detroit
1970RT
Metro Detroit
You'll have to provide power to the ign start and run at the bulkhead terminals. Can you please explain how to go about doing this? I'm not sure what you mean. I don't have a dash harness to connect the bulkhead connector (that is on the engine harness) to other than the one that is in the car. I did order a remote start switch today.
[Re: 1970RT]
#3163904
07/28/23 02:25 PM
07/28/23 02:25 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Personally, I think it would be easier without the harness. Unless you are going to hook up the alternator which does get a bit more complicated with a bit more risk IMHO. I just don't want the possibility of 60+ amps looking for a place to go. I already have plenty to do monitoring the engine itself. If you are concerned about the condition of the alternator, nowadays most auto supplies can test it for you free.
All you need are the ignition components and a few jumper wires to run it.
I just clamp the main starter cable to the positive battery post (Vice Grips will do) and then just touch the smaller starter wire to the same post to crank it. And as I said, I just use a jumper cable to ground it. Easy, peasy.
[Re: DaveRS23]
#3163962
07/28/23 05:18 PM
07/28/23 05:18 PM
1970RT
Metro Detroit
All you need are the ignition components and a few jumper wires to run it. Is there a schematic that would show what gets jumped to what/where? I'm not really that good with the electrical aspect of the engine components.
[Re: 1970RT]
#3163984
07/28/23 07:34 PM
07/28/23 07:34 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
It really is simple. I think you said that you are using factory electronic ignition. If so, all you need is the ECU, ballast resistor, coil and distributor. www.allpar.com/threads/how-to-wire-...icles-that-originally-had-points.229005/Don't worry about wiring the " Ignition 2, start " part. All it does is bypass the ballast during cranking to ensure full voltage during cranking. As long as the battery is hot, you won't need it. But you could also just wire it to the battery while cranking and then disconnect it when the engine starts. Just don't leave it hooked up while running too long, it can heat up the coil after a few minutes of giving it full battery voltage. If you have the single pole style ballast, just wire it and don't worry about it. And you don't have to wire the #1 terminal on the ECU. That's right isn't it? It's been a while since I wired one. Somebody double check me on that. And don't forget to ground the ECU. It needs a solid ground.
[Re: DaveRS23]
#3164366
07/30/23 06:30 PM
07/30/23 06:30 PM
Posts: 2,533 God's Country Maryland
GODSCOUNTRY340
Here's how I've been doing it for years; go to youtube and type in Detrick 440 engine.
[Re: mgoblue9798]
#3164430
07/31/23 07:53 AM
07/31/23 07:53 AM
Posts: 215 Green Bay
Andyvh1959
Green Bay
Before i prep my Dakota chassis to install my 56 Dodge cab I could just install the 5.2 Magnum and trans in the chassis and get it all set up and running before locating the cab onto the Dak chassis. It'll be good to know everything is working before its under the 56 cab/fenders/hood. At least then I know what to expect as I connect more functions in the 56 cab.
My 56 C3-B8 Dakota build
