Opinions on aftermarket shifters #3161546
07/21/23 09:07 AM
07/21/23 09:07 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I am trying to decide on an aftermarket automatic shifter for my car. I've narrowed my choices down to a Hurst Promatic, B&M Quicksilver and TA Cheetah. I'm not interested in any other shifters other than these three. I know the Cheetah is highly recommended for race applications but my car is only driven on the street. I do like the looks of the Cheetah best but my main concern is ease of use as my wife will drive the car occasionally as well. I've never had an aftermarket shifter in any of my cars so I'm not really sure what is easier to use, a ratchet or a gate shifter.
Re: Opinions on aftermarket shifters [Re: 440mopar] #3161562
07/21/23 10:17 AM
07/21/23 10:17 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
The Cheetah, being gated, is easiest - basically one motion to change gears, and intuitive; I don't have to look at it when using them.
I've even had a buddy with a ratchet in his car get the hang of the Cheetah immediately, and he liked it.
Ideally, you could compare them all yourself, as you'll get different opinions, but I've used them on track and on the street with no issues.
Re: Opinions on aftermarket shifters [Re: topside] #3161571
07/21/23 10:48 AM
07/21/23 10:48 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
It's all about personal preference.
I like the Hurst Quarter stick with the pistol grip. Never had a problem with this other than a burned cable recently (which was my fault).
'63 Dodge 330
11.19 @ 121 mph
Re: Opinions on aftermarket shifters [Re: topside] #3161646
07/21/23 01:35 PM
07/21/23 01:35 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
iagree
I put a turbo action Cheetah in the 69 Dart and love it.
You clearly know what gear you’re in without having to look at it.
It was replacing a ratchet shifter that you could never tell what gear you were in visually.
The Cheetah came from A&A transmissions and was a rear cable to the trans setup. That way the cable doesn’t go anywhere near the headers so it doesn’t get melted like all the front cable ones usually do.
Re: Opinions on aftermarket shifters [Re: 440mopar] #3161648
07/21/23 01:35 PM
07/21/23 01:35 PM
I've had and used in my old race cars a lot of the popular 3 speed aftermarket (Hurst, B M, T.A, Fairbanks and Winters) shifters for Mopar 727 and two of the better Powerglide shifters in my last S/P car. I will buy and use the Turbo Action shifters for all my cars being converted to floor shifters up scope thumbs
Re: Opinions on aftermarket shifters [Re: Cab_Burge] #3161699
07/21/23 04:09 PM
07/21/23 04:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What ever cable shifter you use be sure you have a good engine ground. The shifter cable can act as a ground which melts tthem real fast. BTDT
Re: Opinions on aftermarket shifters [Re: stumpy] #3161713
07/21/23 05:19 PM
07/21/23 05:19 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Biggest issue for me is is the cable front or rear entry. I don’t ever want to use a shifter with a front entry entry. Rear entry only.
Re: Opinions on aftermarket shifters [Re: markz528] #3161716
07/21/23 05:28 PM
07/21/23 05:28 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I agree.
Besides the Turboaction what other shifters are there for a 727 with a rear cable?
I have an old TurboAction shifter with front cable. Can it be changed to rear cable? Can you just turn the detent plate around and mount the shifter backwards. Is there a spring inside that would push the lever to the wrong side of the detent? I'll have to dig it out and look at it. It would also need a different cable bracket at the trans end. Available from TA?
Re: Opinions on aftermarket shifters [Re: 440mopar] #3161776
07/21/23 10:04 PM
07/21/23 10:04 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
myself I loved the Hurst Dual gate shifters as they were simple with no pull this, push that, scratch your but etc. Just put it in whatever gear you want and go. Manual shift, no problem. I have never understood the need for the ratsh-t shifters. If one is so excited they can't shift to the next gear without overshooting it maybe they shouldn't be in the car to begin with shruggy twocents
Re: Opinions on aftermarket shifters [Re: TJP] #3161835
07/22/23 08:46 AM
07/22/23 08:46 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I used a B&M star shifter and i liked it. For everyday use it acts like a normal shifter but on the occasion when you want to "get on it" you drop it down into "ratcheting mode" and just hit the shifter to go into the next gear. You don't have to look at the shifter to see what gear it's in.
Re: Opinions on aftermarket shifters [Re: Moparite] #3161890
07/22/23 11:24 AM
07/22/23 11:24 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have a Promatic 2 and a Cheetah. I know this isn't a popular opinion, but the Cheetah sucks.
That said, Quarterstick all day long.
Re: Opinions on aftermarket shifters [Re: 440mopar] #3162078
07/22/23 06:28 PM
07/22/23 06:28 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I like my B&M QuickSilver...but having melted the 5ft cable (the one supplied with the shifter) I am now going through the pains of installing the replacement, that being a 'Race' cable, but a 4ft one. Needless to say, for my ride it would appear that literally 4.5ft is the PERFECT length!!! lol
Anyways, to those who say: aim for the rear trans cable hookup - YUP - completely agree, I wish there was an easy way to convert the B&M stuff to that.
Re: Opinions on aftermarket shifters [Re: 440mopar] #3162087
07/22/23 07:17 PM
07/22/23 07:17 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
The sloppiness of the Cheetah would make it an easy street car shifter….. and it’s an aged has been of a race shifter. Personally I really liked the Promatic 2 back in my street days. Just make sure to route the cable carefully and cover with firesleave.
Re: Opinions on aftermarket shifters [Re: stumpy] #3162100
07/22/23 08:15 PM
07/22/23 08:15 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have A PPP in one of my cars with rear exit cable helps with header clearance issues.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Opinions on aftermarket shifters [Re: 6PKRTSE] #3162245
07/23/23 09:42 AM
07/23/23 09:42 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I wish I could have the machined billet aluminum pistol grip handle from the Hurst Quarter stick- but on a full ratchet shifter like the B&M Pro Ratchet.
Keep old mopars alive.
Re: Opinions on aftermarket shifters [Re: 440mopar] #3162354
07/23/23 01:21 PM
07/23/23 01:21 PM
Cold Spring, NY
1970GTX Offline
1970GTX  Offline
Cold Spring, NY
I personally love the looks of the quicksilver. Not sure about the ease of use because I've never personally used one.
Re: Opinions on aftermarket shifters [Re: 1970GTX] #3162500
07/23/23 06:53 PM
07/23/23 06:53 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I had great results with my Quick Silver for many years. But went Hurst because i needed reversed pattern and liked the billet pistol grip plus has a button for the line lock or NOS
Works great so far.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Opinions on aftermarket shifters [Re: 340SIX] #3162735
07/24/23 01:06 PM
07/24/23 01:06 PM
K
Kiddart Offline
Kiddart  Offline
K
does anyone use the pistol grip handle on a older quarter stick? does the release lever go high enough.
a picture would be great. I want to change the hurst ball and go to the pistol grip for looks just wanting to know.
Thank you
Kiddart
Re: Opinions on aftermarket shifters [Re: Kiddart] #3162772
07/24/23 02:08 PM
07/24/23 02:08 PM
340SIX Offline
340SIX  Offline
Re: Opinions on aftermarket shifters [Re: 440mopar] #3162789
07/24/23 02:59 PM
07/24/23 02:59 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Used the Hurst Promatic for years in 2 of my race cars. They worked well and I liked them. After melting the cable in each of the cars I switched them to a Cheetah shifter. The promatic has a front entry to the trans and the reason the cable melted was due to breaking in a camshaft in a new motor and didn't think to have a fan blow air under the car to help keep the cable cool. Both cars had under chassis headers at the time, but the one car previously had fenderwell headers and never had an issue before. I personally prefer the rachet shifter vs the gate, but the rear entry of the Cheetah along with knowing which gear you're in, makes it a easy choice IMO. Wish more shifters were rear entry, but there's few and far between for a Mopar. Always wanted to try a PPP shifter, but that's out of my budget.
