Re: Opinions on aftermarket shifters
[Re: topside]
#3161571
07/21/23 10:48 AM
07/21/23 10:48 AM
Posts: 4,697 Wichita
GY3
Wichita
It's all about personal preference.
I like the Hurst Quarter stick with the pistol grip. Never had a problem with this other than a burned cable recently (which was my fault).
[Re: topside]
#3161646
07/21/23 01:35 PM
07/21/23 01:35 PM
Posts: 10,155 A Red State
SNK-EYZ
A Red State
The Cheetah, being gated, is easiest - basically one motion to change gears, and intuitive; I don't have to look at it when using them. I've even had a buddy with a ratchet in his car get the hang of the Cheetah immediately, and he liked it. Ideally, you could compare them all yourself, as you'll get different opinions, but I've used them on track and on the street with no issues. I put a turbo action Cheetah in the 69 Dart and love it. You clearly know what gear you’re in without having to look at it. It was replacing a ratchet shifter that you could never tell what gear you were in visually. The Cheetah came from A&A transmissions and was a rear cable to the trans setup. That way the cable doesn’t go anywhere near the headers so it doesn’t get melted like all the front cable ones usually do.
[Re: stumpy]
#3161713
07/21/23 05:19 PM
07/21/23 05:19 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Biggest issue for me is is the cable front or rear entry. I don’t ever want to use a shifter with a front entry entry. Rear entry only.
[Re: markz528]
#3161716
07/21/23 05:28 PM
07/21/23 05:28 PM
Posts: 4,743 Moved to N.E. Tennessee
GomangoCuda
Biggest issue for me is is the cable front or rear entry. I don’t ever want to use a shifter with a front entry entry. Rear entry only. I agree. Besides the Turboaction what other shifters are there for a 727 with a rear cable? I have an old TurboAction shifter with front cable. Can it be changed to rear cable? Can you just turn the detent plate around and mount the shifter backwards. Is there a spring inside that would push the lever to the wrong side of the detent? I'll have to dig it out and look at it. It would also need a different cable bracket at the trans end. Available from TA?
[Re: Moparite]
#3161890
07/22/23 11:24 AM
07/22/23 11:24 AM
Posts: 20,203 Park Forest, IL
slantzilla
Park Forest, IL
I have a Promatic 2 and a Cheetah. I know this isn't a popular opinion, but the Cheetah sucks.
That said, Quarterstick all day long.
[Re: 440mopar]
#3162078
07/22/23 06:28 PM
07/22/23 06:28 PM
Posts: 1,763 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I like my B&M QuickSilver...but having melted the 5ft cable (the one supplied with the shifter) I am now going through the pains of installing the replacement, that being a 'Race' cable, but a 4ft one. Needless to say, for my ride it would appear that literally 4.5ft is the PERFECT length!!! lol
Anyways, to those who say: aim for the rear trans cable hookup - YUP - completely agree, I wish there was an easy way to convert the B&M stuff to that.
[Re: stumpy]
#3162100
07/22/23 08:15 PM
07/22/23 08:15 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
I have A PPP in one of my cars with rear exit cable helps with header clearance issues.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3162245
07/23/23 09:42 AM
07/23/23 09:42 AM
Posts: 4,786 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I wish I could have the machined billet aluminum pistol grip handle from the Hurst Quarter stick- but on a full ratchet shifter like the B&M Pro Ratchet.
Keep old mopars alive.
[Re: 1970GTX]
#3162500
07/23/23 06:53 PM
07/23/23 06:53 PM
Posts: 28,606 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I had great results with my Quick Silver for many years. But went Hurst because i needed reversed pattern and liked the billet pistol grip plus has a button for the line lock or NOS Works great so far.
[Re: 340SIX]
#3162735
07/24/23 01:06 PM
07/24/23 01:06 PM
Posts: 1,553 Michigan
Kiddart
does anyone use the pistol grip handle on a older quarter stick? does the release lever go high enough.
a picture would be great. I want to change the hurst ball and go to the pistol grip for looks just wanting to know.
Thank you Kiddart
[Re: Kiddart]
#3162772
07/24/23 02:08 PM
07/24/23 02:08 PM
340SIX
a picture would be great. I want to change the hurst ball and go to the pistol grip for looks just wanting to know. .
