How bad did I just screw up? RE46 related
#3161514
07/20/23 11:34 PM
07/20/23 11:34 PM
Posts: 10,559 Freeport IL USA
poorboy
Freeport IL USA
When I had the trans pan off my RE46, I installed a trans drain. For the last few months its been marking its spot in the garage because the drain plug is leaking. Its something I would address when I drain the fluid the next time, it really isn't anything serious, but it was the cause of my screw up.
I need to know how bad I messed up.
The trans has 9 quarts of AFT+4 in it. I checked it the other day, and it was just about down to the add line, so I grabbed what I thought was a quart of AFT+4, and added about 2- 3 ounces of fluid to the trans. It turned out, what I added was not the ATF+4, but was synthetic 5W 20 motor oil in a similar color bottle. That motor oil bottle was full, and there is only 2 to 3 ounces out of it.
Can/will those 2-3 ounces of synthetic motor mixed with 8 1/2 quarts of ATF+ 4 going to harm this trans? If there is concern, I'll dump the fluid, change the filter, and add fresh ATF+4, but if the consensus is it won't cause any problem, I would rather wait until next spring to dump the $100+ worth of ATF when its closer to the ATF's normal change time frame.
What do you guys think?
Re: How bad did I just screw up? RE46 related
[Re: poorboy]
#3161607
07/21/23 12:22 PM
07/21/23 12:22 PM
Posts: 19,402 north of coder
moparx
my opinion ? i don't think it will hurt a thing. i base this on my experience with a 727 [yes, i know it's NOT like the 46RE transmission] i purposely dumped a quart of motor oil into, as per a magazine article i read at the time, stating this would help with lubrication. that transmission worked for many thousands of miles afterward, with no problems whatsoever. just my opinion. mileage from others will inevitably vary.
