1350 u-joint ? #3160625
07/18/23 03:45 PM
07/18/23 03:45 PM
moparx Offline OP
moparx  Offline OP
i need a new driveshaft made for my charger because the joint "ear hole" on the front of the shaft [the shaft has the damper ring on the front if that matters] has become slightly egg shaped, allowing play in the shaft between the joint cup and the front ear hole of the shaft.
with that said, what i would like to do is get a shaft made with a forged yoke for the 727, and use 1350 joints on both ends of the shaft.
with that said, however, is there a 1350/7290 [or 7260] conversion joint made ?
the reason for asking is, i am keeping the 8 3/4 rear the car came with, and i have several sets of 3.91 gears, all in 742 or 741 cases, having the 7260 joint size on them.
i have a good 7290 pinion yoke i can swap [just remove the 7260 joint, replace seal, install 7290 yolk, torque down with a new nut and done ?] so i figured i would do that, but have a nice 1350 joint shaft, if and whenever i decided to purchase a 1350 pinion yolk.
please show me where i am screwing up, but remember, the 8 3/4 will be staying. TIA ! bow
beer
Re: 1350 u-joint ? [Re: moparx] #3160696
07/18/23 07:35 PM
07/18/23 07:35 PM
Cab_Burge Online work
Cab_Burge  Online Work
Call NAPA or Mark Williams and ask them, if their available they can sell it to you scope twocents
I have used several different adapter U joints, 7260 to 7290 and maybe 7290 to 1350 but that was a long time ago and my memory ain't that good blush
Re: 1350 u-joint ? [Re: moparx] #3160827
07/19/23 03:53 AM
07/19/23 03:53 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Re: 1350 u-joint ? [Re: SNK-EYZ] #3160859
07/19/23 09:08 AM
07/19/23 09:08 AM
an8sec70cuda Offline
Originally Posted by SNK-EYZ
iagree I had a 7290 to 1350 conversion joint under my road runner for a while. Got it from Dr. Diff.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 1350 u-joint ? [Re: an8sec70cuda] #3160870
07/19/23 09:44 AM
07/19/23 09:44 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
If you need a driveshaft made, Dr. Diff or Summit can get you a Strange unit in short order. Summit is a bit cheaper.
'63 Dodge 330
11.19 @ 121 mph
Re: 1350 u-joint ? [Re: GY3] #3160972
07/19/23 12:40 PM
07/19/23 12:40 PM
moparx Offline OP
moparx  Offline OP
i was thinking of having the good doctor make up a shaft for me.
however, i was really wanting solid [non-greasable] joints. i know a 1350 joint is available that way, but i wonder if a conversion joint is ?
as to the pinion yolk[s], mine are the 10 spline variety.
i know the google may be able to help me, but i was wondering about other's experience doing what i want to do [if any].
beer
Re: 1350 u-joint ? [Re: moparx] #3160988
07/19/23 12:50 PM
07/19/23 12:50 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
beer
On the drive shaft PLEASE get one made by Mark Williams, its a long story & A LOT of wasted money on my Charger, MW for the win !!!!!
Re: 1350 u-joint ? [Re: CSK] #3161009
07/19/23 01:27 PM
07/19/23 01:27 PM
moparx Offline OP
moparx  Offline OP
hmmmm.............
i know it's none of my business, but would it be possible to pm me with the story ?
as you know what i have to deal with, my funds are only few and far between to attempt to get my junk back on the road, so i have to be judicious with my spending in order to be able to afford other costs in my life that are way more important.
beer
Re: 1350 u-joint ? [Re: CSK] #3161038
07/19/23 02:40 PM
07/19/23 02:40 PM
WI
mopar873 Offline
mopar873  Offline
WI
I've heard that ALOT regarding M/W as the right place to go first. Not to side track, but is Denny's still competitive in this market as far as quality/price? I have to get one cut soon for a Brand X high 8 sec NA car.
Re: 1350 u-joint ? [Re: moparx] #3161045
07/19/23 03:07 PM
07/19/23 03:07 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
hmmmm.............
beer
as you know I have an a518 [46rh] OD trans, lots of potential drive line angle issues, so I had a Alum shaft made here in houston by a well known company, $750, FOUGHT & FOUGHT a drive line vibration, ie EVERYTHING possible LOL, pinion angle,trans angle ect, I gave up, blew up my 8 3/4 & had to get them to shorten the drive shaft $150, now the vibration was WORSE, took it back to them three times for a rebalance ,,, NO change, in desperation I ordered a Strange steel custom shaft $450 & it changed the vibration considerably but at high speeds it came back, I called Strange & asked them what RPM they spin the shaft for balancing, they said, 500 rpm was the fastest they spin them, so I did the old chalk marker test on the shaft on jack stands at 60 mph, the chalk marks were at the same spot as the welded on weights, so I cut them off & ended up adding weight almost opposite of where they had them, the vibration was ALMOST gone but at 120mph it was still pretty bad, so, I called Mark Williams & asked them what RPM they can spin the shaft, They said as fast as you want, so I had them build me a new shaft $650 with their better yoke, the car is SMOOTH as GLASS !!!!!! another one of my expensive lessons learned the hard way smile & yes I have the large u joint 1350
Re: 1350 u-joint ? [Re: CSK] #3161263
07/20/23 09:28 AM
07/20/23 09:28 AM
Makes me happy that my local truck service shop built steel driveshaft has held up for so long running 8s at 3800 lbs. punkrocka
CHIP
Re: 1350 u-joint ? [Re: an8sec70cuda] #3161296
07/20/23 12:01 PM
07/20/23 12:01 PM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
All the local parts stores around me stock the conversion u-joint. It shouldnt be hard to find.
As far as a shaft, my last two aluminum shafts have come from Action Machine in South Bend, IN and are awesome. Usually have them at my door in 10 days.
Re: 1350 u-joint ? [Re: CSK] #3161307
07/20/23 12:42 PM
07/20/23 12:42 PM
moparx Offline OP
moparx  Offline OP
hmmmm.............
beer
i kind of thought that was the story. i have always believed in high speed balancing, and truck driveshaft places do not do that because the truck driveline does not see the shaft speed a car does because of the huge difference in tire size.
beer
Re: 1350 u-joint ? [Re: moparx] #3161628
07/21/23 12:57 PM
07/21/23 12:57 PM
Locomotion Offline
Locomotion  Offline
Look up what Spicer has to offer in solid conversion u-joints. I have some 7260/1310 solid conversion joints in some applications and have used their "regular" solid joints over the years as well. Never a problem and are the best in the business IMHO.
