timing light #3160177
07/17/23 08:48 AM
07/17/23 08:48 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Point ignition vs electronic conversion . Is the same type timing light used for either or is another type for electronic conversion ? If so, anyone have a current model/part number? Thanks to all in advance. Thanks MOPARTS
Re: timing light [Re: terzmo] #3160213
07/17/23 10:41 AM
07/17/23 10:41 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Yes, same light for either. The real choice is whether you use an inductive vs an on-plug type light. Again, either will work but the inductive is usually more convenient if not a bit more finicky. Some lights struggle with multi strike ignitions.
I have had good luck looking on Marketplace or Craigslist for used ones. $20 or less usually. I have a couple of the old chrome Craftman inductives that have served me well. Bought both used. Only need one, but the last one was still in it's box, looking new for $10. Couldn't say no even though I didn't need it.
Master, again and still
Re: timing light [Re: DaveRS23] #3160218
07/17/23 11:16 AM
07/17/23 11:16 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Been using the old chrome Craftsman lights since the late 70's or so. So far, so good. up
Re: timing light [Re: bobby66] #3160226
07/17/23 11:44 AM
07/17/23 11:44 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Same. Non-dial back style--I just use a timing tape.
Even used it with my old MSD 6AL box on my last car and it did not seem to mind..
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: timing light [Re: wingman] #3160234
07/17/23 12:04 PM
07/17/23 12:04 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Thanks for all the info
Re: timing light [Re: terzmo] #3160296
07/17/23 02:35 PM
07/17/23 02:35 PM
Cab_Burge Online work
Cab_Burge  Online Work
I have two of the older, bought in the late 1970 or early 1980s Craftsman dial back timing lights and one battery power Flaming river timing light., that one is easer to use and brighter up scope twocents
I do remove the battery after using it and put them back in when I need to use it again, I don't want the battery going bad and corroding the inside of it as sit is in my race trailer year round and it gets really cold here in the winter wrench up
Re: timing light [Re: bobby66] #3160311
07/17/23 03:34 PM
07/17/23 03:34 PM
Shopping @ HoBo Fright
340SIX Online content
Doc Flappergas's Evil Twin
340SIX  Online Content
Been using the old chrome Craftsman lights since the late 70's or so. S5o far, so good. up
Same here. But also bought a,Sun Engine Tune Up box set
It is light, vacume, a line tgat screws into spark plug holes to test compression and that gauge so yiu can also compress to swap spring's or seals. And of coarse the Main bix that shows dwell, RPM ect. And a few other thing's ijjn there All like new
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: timing light [Re: terzmo] #3160411
07/17/23 10:18 PM
07/17/23 10:18 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Have a FERRET digital looking for a home, Little use. PM for pics etc. if interested beer
Re: timing light [Re: TJP] #3160447
07/18/23 07:35 AM
07/18/23 07:35 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
ok..side question. Back in the 60's I did tune ups and when setting the timing on certain vehicles the vacum advance was plugged at the distributor or plugged at the carb for setup. I have mechanical advance and the vacum cannister on My distributor is plugged and no vacum to it at all. Am I good to go to check timing as is ? Thanks in advance to all. Thanks..Moparts
Re: timing light [Re: terzmo] #3160461
07/18/23 09:33 AM
07/18/23 09:33 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Yes. You do not want the vacuum advance to influence the initial setting. Just make sure that the carb does not have a resulting vacuum leak that could raise the idle.
Re: timing light [Re: DaveRS23] #3160462
07/18/23 09:37 AM
07/18/23 09:37 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Typically what you are setting is base timing. There should be no vacuum advance due to vacuum (plug line) and no mechanical advance due to high engine speed (maintain specified idle speed). If you are setting total timing or something other than base, that is another conversation.
Re: timing light [Re: 6PakBee] #3160471
07/18/23 10:25 AM
07/18/23 10:25 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Rev the engine until all the mechanical advance is in (vacuum advance disconnected). The rpm it is all in will be determined by the springs you have in the distributor. Put Mr. Gasket #925B in to get a quick advance.
Set the total timing there. Let the base timing fall where it will. I would start with 34-35*.
'63 Dodge 330
11.19 @ 121 mph
Re: timing light [Re: DaveRS23] #3160475
07/18/23 10:40 AM
07/18/23 10:40 AM
that's the story of my life!
Re: timing light [Re: GY3] #3160586
07/18/23 02:01 PM
07/18/23 02:01 PM
moparx Offline
moparx  Offline
isn't the mr. gasket spring set for GM distributors ?
beer
Re: timing light [Re: moparx] #3160630
07/18/23 04:08 PM
07/18/23 04:08 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
beer
#925B is two springs for the OEM Mopar distributors.
'63 Dodge 330
11.19 @ 121 mph
Re: timing light [Re: GY3] #3160925
07/19/23 11:49 AM
07/19/23 11:49 AM
moparx Offline
moparx  Offline
ok, thanks for the clarification.
i thought, at one time anyway, there was a mr. gasket spring kit recommended that was for GM distributors.
not that i can be "cornfused" easily............. laugh2
beer
Re: timing light [Re: moparx] #3161052
07/19/23 03:33 PM
07/19/23 03:33 PM
beer
They were available for GM type distributors the last time I checked. shruggy
I bought 5 or 6 of the 95B kits to have them as needed, I do weld up the advance slots on the old type stock Mopar distributors and adjust the new type so I can have 12 to 16 degrees initial advance at a low idle and 34 to 36 degrees total advance above 2000 RPM up
Re: timing light [Re: Cab_Burge] #3161610
07/21/23 12:34 PM
07/21/23 12:34 PM
moparx Offline
moparx  Offline
i have welded the slots as well Cab, and i have a couple of those limiting plates here, but i have never tried those yet.
a lot of performance can be gained by fiddling with the distributor weights and vacuum advance !
well worth the time trying different combinations, and a distributor machine will help, but not really necessary if one does not have access to one.
beer
Re: timing light [Re: moparx] #3161731
07/21/23 06:26 PM
07/21/23 06:26 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: timing light [Re: moparx] #3161843
07/22/23 09:16 AM
07/22/23 09:16 AM
5thAve Offline
5thAve  Offline
For some reason in the past few years I've had a couple timing lights come my way, still no digital ones or dial back ones tho and some are the older style that go in line with the plug wire.
beer
That's one nice thing about the mallory built mopar performance distributors, that you can you don't have to weld slots or change parts other then the springs.
