Mini-tubbed 67-69 Barracuda Fastbacks - what wheels / tires
#3160349
07/17/23 06:43 PM
07/17/23 06:43 PM
Posts: 2,886 Bowling Green KY / Nashville, ...
300by500
Getting ready to order an S60 rear end for the mini-tubbed 69 Barracuda.
From what I’ve seen so far online, looks like a 335/50/15 is the street tire most people are running. But after doing some measuring, I think I can fit something bigger if I could find wheels with different backspacing?
I was just wondering (before ordering a rear end) what other options might be available.
Thanks, Moparts!
Re: Mini-tubbed 67-69 Barracuda Fastbacks - what wheels / tires
[Re: BloFish]
#3160419
07/17/23 10:42 PM
07/17/23 10:42 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
That is how I built my car. I built it around the wheels and tires.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: AndyF]
#3160636
07/18/23 04:14 PM
07/18/23 04:14 PM
Posts: 16,487 On the run…
BloFish
On the run…
What spacers do you use Andy?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#3160674
07/18/23 06:34 PM
07/18/23 06:34 PM
Posts: 4,730 Moved to N.E. Tennessee
GomangoCuda
What spacers do you use Andy? I'll take a SWAG that Andy makes his own spacers exactly the size he wants.
[Re: BloFish]
#3160783
07/18/23 10:26 PM
07/18/23 10:26 PM
Posts: 4,684 On the parachute mount
n20mstr
really a lot of things to consider here, what ar the goals for the car?? i ask because if you want a double beadlock sometime in the future, you really want as little back space as possible. It really helps to mount the tires with 2" or so backspacing. Anyway as mentioned, buy the wheels and tires you want or borrow , situate them under the car and measure between them. Also as mentioned make sure you subtract 1/4 to 1/2 for brake spacing. Also as mentioned , its easier to add a 1/8 or 1/4 wheel spacer than to re shorten the housing !!
When you have your final measurement , call Strange or whoever and thats your "width" it is absolutely the best way to do it. I did my car (1973 dart ) this way 12" rim double beadlock with 275 radials. And my sons duster 12" rim with 315 radials
....BAD A$$ STREET CAR.....
[Re: 300by500]
#3162641
07/24/23 09:00 AM
07/24/23 09:00 AM
Posts: 34,927 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
On race cars, spacers are a no no
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
