C Body Crossmember #3157128
07/05/23 09:55 AM
07/05/23 09:55 AM
Stuarts Draft
Dan K Offline OP
Dan K  Offline OP
Stuarts Draft
Good Morning, I'm new to C Bodies and have a question I bought a 1969 Sport Fury roller and it did not have a crossmember. I came across a 1968 c body crossmember for sale on EBay and I'm wondering if thy are the same? I'm having a hard time finding one.
TIA
Dan
Re: C Body Crossmember [Re: Dan K] #3157139
07/05/23 10:29 AM
07/05/23 10:29 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
TIA
Dan
I really doubt it. Check over at http://www.forcbodiesonly.com
someone over there will know for sure.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: C Body Crossmember [Re: 3hundred] #3157149
07/05/23 11:06 AM
07/05/23 11:06 AM
Back in Blue Jersey.
P
polara71 Offline
polara71  Offline
P
I'm 99.9% they are not. 68 was a slab , 69 was a Fuselage. Two completely different animals.
Re: C Body Crossmember [Re: polara71] #3157383
07/05/23 11:23 PM
07/05/23 11:23 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
By "crossmember" are you talking about the transmission crossmember, or the entire front frame bolt in section?
if you are talking the entire bolt in front frame section, Chrysler changed how they were bolted onto the body shell. My guess would be, 66 & 67 and then 68-70 and then 71 -72 would interchange. The spool motor mounts came along in 73 but those might fit up into the downsizing after 78. The demand for the "big" cars dropped around the gas crunch in 74, Chrysler didn't change much under those big cars after the demand fell off.
Transmission crossmember? 68-72 then 73 on. My guess.
Re: C Body Crossmember [Re: poorboy] #3157472
07/06/23 10:48 AM
07/06/23 10:48 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Now that you say that I think you're right. It wouldn't be a roller without the front frame. If it really is the trans crossmember, i think '65 to '73 should work.
'69 300 Convertible
'16 300 S Hemi
Re: C Body Crossmember [Re: 3hundred] #3159587
07/14/23 01:50 PM
07/14/23 01:50 PM
P
polara71 Offline
polara71  Offline
P
I agree, I've been out of it awhile but I think you guys are correct.
