NP435 to 727 swap #3154632
06/27/23 10:25 AM
06/27/23 10:25 AM
Alberta
rustbuckett68 Offline OP
Alberta
1980 D200 std. cab, long box 318 4 gear, Dana 60 Since I got it on the road, the clutch chatters bad for about 8000K (5000M). Trans (can't call it a tranny anymore) seems noisy
and is hard to shift on occasion. Thought it would be cheaper to swap in my good 727 and I have all the bits and pieces. Question is, two piece driveshaft. My
Hollander shows the same front D/S for both std. and auto. Haven't rolled my carcass under the truck for a measure yet, wondering if anyone has done this and could
shed a little light on the matter.
Re: NP435 to 727 swap [Re: rustbuckett68] #3154731
06/27/23 04:48 PM
06/27/23 04:48 PM
N
NITROUSN Offline
NITROUSN  Offline
N
If the 727 has a long tail shaft with a slip yoke it will not fit. Your 4 speed should have a yoke with a bolt on u-joint. So if that's the case a short shaft 727 should fit.
Re: NP435 to 727 swap [Re: NITROUSN] #3154824
06/27/23 09:59 PM
06/27/23 09:59 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Yep, the truck 727 was a short tail shaft with a bolted on rear yoke, not a slip in one. If you use a car 727, the driveshaft is going to be different.
Re: NP435 to 727 swap [Re: poorboy] #3154891
06/28/23 09:12 AM
06/28/23 09:12 AM
Alberta
Alberta
Thanks guys, kind of figured that. Trans is in a B300 van, but is a long tailshaft. Looks like I have to track down a one piece d/s.
Re: NP435 to 727 swap [Re: rustbuckett68] #3155259
06/29/23 02:00 PM
06/29/23 02:00 PM
moparx Offline
moparx  Offline
for whatever this is worth..........
i tore apart a small block truck 727 with the short tailshaft and bolt on yolk, then used the tailshaft and output shaft [plus the associated pieces] in a big block case when i put a 440 into my 74 shop/junkyard pickup.
beer
Re: NP435 to 727 swap [Re: moparx] #3155532
06/30/23 12:03 PM
06/30/23 12:03 PM
Alberta
Alberta
Thats an idea. Thanks.
