WIW Hemi Booster and Actuator #3155301
06/29/23 03:52 PM
06/29/23 03:52 PM
Valpo Indiana
SMILINJOE Offline OP
Valpo Indiana
Booster looks like it was modified into Hemi bolt pattern.
Actuator looks like an original.
Also years ago a friend had some Actuators made via water jet. Firewall mounting holes were off by a 1/4ā€. Too small.
Rest of brackets are correct. Some minor pitting on booster.
So WIW.
Thanks for the help.
Re: WIW Hemi Booster and Actuator [Re: SMILINJOE] #3155452
06/29/23 11:53 PM
06/29/23 11:53 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Got a friend near Chicago that is looking for a power brake set-up for an E-Body, will this work? shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: WIW Hemi Booster and Actuator [Re: Rhinodart] #3155479
06/30/23 06:55 AM
06/30/23 06:55 AM
WV
Little Detroit Offline
WV
that actuator is not original and the booster has been modified and looks to be a b-body booster also no spacers for bracket
IMO.
Re: WIW Hemi Booster and Actuator [Re: Little Detroit] #3155492
06/30/23 08:54 AM
06/30/23 08:54 AM
Valpo Indiana
Valpo Indiana
Pulled packing material out of box. Was wrapping back up and found spacers, nuts and washers.
Also a sheet from The Ram Man
Booster will work for B&E Body
Re: WIW Hemi Booster and Actuator [Re: SMILINJOE] #3155796
07/01/23 05:33 AM
07/01/23 05:33 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
B and E body brackets are different. What you have is a cobbled together mess from the rammer man. I know people who had experience with his booster conversation and they were very unhappy. I had an original E body one that I sold with booster and linkage. If I was going to install a hemi in a car, Iā€™d use the repop kit from DoctorDiff with the booster and brackets.
Re: WIW Hemi Booster and Actuator [Re: fastmark] #3155863
07/01/23 10:32 AM
07/01/23 10:32 AM
VA
dragon slayer Online content
dragon slayer  Online Content
VA
The brackets are not different B and E, just the lever that attaches to the petal is.
Re: WIW Hemi Booster and Actuator [Re: dragon slayer] #3156105
07/02/23 06:15 AM
07/02/23 06:15 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Correct. I should have been more specific. The ASSEMBLY is different between the two body styles. The lever is different and so is the length of the rod that attaches to the pedal.
