Intake valley pan heat shield #3154320
06/26/23 10:54 AM
06/26/23 10:54 AM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Are the Intake Valley Pan Heat Shield the same for the 383/400/440? I know 440's valley pan is a little wider as are the valley pan hold downs, but is the heat shield used the same or is the 440 one wider as well?
Re: Intake valley pan heat shield [Re: DusterKid] #3154400
06/26/23 02:54 PM
06/26/23 02:54 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The "B" motor (361, 383, 400) has one pan, and the "RB" motor (413, 426 W, 440 & that oddball RB383 back in the late 50s/early 60s) has one pan, they are not the same. That valley pan is also the intake gasket and its a one time use item. If its not replaced, they tend to suck oil up between the valley and the bottom of the intake ports.
Re: Intake valley pan heat shield [Re: poorboy] #3154403
06/26/23 03:03 PM
06/26/23 03:03 PM
Keymar, MD
Keymar, MD
I've referring to the heat shield portion that bolts on with the hold downs. I think they usually have some type of insulation between the heat shield and valley pan.
Re: Intake valley pan heat shield [Re: DusterKid] #3154486
06/26/23 07:31 PM
06/26/23 07:31 PM
Think about that, I have never seen both of them beside each other but I would bet money they are not identical work scope
Re: Intake valley pan heat shield [Re: DusterKid] #3154552
06/26/23 11:53 PM
06/26/23 11:53 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Intake valley pan heat shield [Re: Cab_Burge] #3154818
06/27/23 09:29 PM
06/27/23 09:29 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Parts book shows different part numbers for the end rail reinforcements between the B and RB so the shield would have to be different also. Can't find a number for the shield itself.
Re: Intake valley pan heat shield [Re: 6PakBee] #3154838
06/27/23 10:45 PM
06/27/23 10:45 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The distance between the heads is different. The RBs intakes are 1" wider then the B motor intakes are..
Re: Intake valley pan heat shield [Re: poorboy] #3155274
06/29/23 02:36 PM
06/29/23 02:36 PM
moparx Offline
moparx  Offline
i don't know where i got these measurements, but i was thinking 11" for the B, and 12" for the RB ?
i have a couple of each on the shelf, but i'm too lazy to go measure. biggrin
i'm thinking that may be from the top of the intake[s] ?
beer
Re: Intake valley pan heat shield [Re: moparx] #3155399
06/29/23 08:28 PM
06/29/23 08:28 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I was thinking 12" or 13", but it could be 11" or 12", its been 25+ years since I've even had my hands on any Mopar big block. The old memory isn't as good as it used to be. beer
Re: Intake valley pan heat shield [Re: poorboy] #3155548
06/30/23 12:43 PM
06/30/23 12:43 PM
moparx Offline
moparx  Offline
my memory is being covered by cobwebs those dang spiders in my old noggin' are working hard to cover ! laugh2
beer
Re: Intake valley pan heat shield [Re: moparx] #3155654
06/30/23 07:15 PM
06/30/23 07:15 PM
Long Island, New York
57Fury440 Offline
57Fury440  Offline
They are different. The bolt holes are spread apart more on the RB engines. You can reuse the gaskets if you use them with paper gaskets sandwiching them between the manifold and heads.
Re: Intake valley pan heat shield [Re: DusterKid] #3155758
06/30/23 10:45 PM
06/30/23 10:45 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
The heat shields are the same for the 383/440 that hold the insulation
Silencer Package Was Called
Part number - 1879 747
383 - 440
The holes are spaced 100 % the same on the hold down bars for 383 / 440
On a 440 the valley pan hold down bars are just longer on the ends , hence different part numbers for bars
Picture is 440 RB Hold Down Bars - Heat shields for 383/440
440 & 383 both have the same holes but the 440 is 8 1/4 long & the 383 is 7 1/4 long
Siberian Huskies
Re: Intake valley pan heat shield [Re: bee1971] #3156411
07/03/23 07:38 AM
07/03/23 07:38 AM
Keymar, MD
Keymar, MD
Thanks.
