Re: Intake valley pan heat shield
[Re: DusterKid]
#3154400
06/26/23 02:54 PM
06/26/23 02:54 PM
Posts: 10,564 Freeport IL USA
poorboy
Freeport IL USA
The "B" motor (361, 383, 400) has one pan, and the "RB" motor (413, 426 W, 440 & that oddball RB383 back in the late 50s/early 60s) has one pan, they are not the same. That valley pan is also the intake gasket and its a one time use item. If its not replaced, they tend to suck oil up between the valley and the bottom of the intake ports.
[Re: Cab_Burge]
#3154818
06/27/23 09:29 PM
06/27/23 09:29 PM
Posts: 10,720 North Dakota
6PakBee
North Dakota
Are the Intake Valley Pan Heat Shield the same for the 383/400/440? I know 440's valley pan is a little wider as are the valley pan hold downs, but is the heat shield used the same or is the 440 one wider as well? Think about that, I have never seen both of them beside each other but I would bet money they are not identical Parts book shows different part numbers for the end rail reinforcements between the B and RB so the shield would have to be different also. Can't find a number for the shield itself.
[Re: DusterKid]
#3155758
06/30/23 10:45 PM
06/30/23 10:45 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
The heat shields are the same for the 383/440 that hold the insulation
Silencer Package Was Called Part number - 1879 747 383 - 440
The holes are spaced 100 % the same on the hold down bars for 383 / 440
On a 440 the valley pan hold down bars are just longer on the ends , hence different part numbers for bars
Picture is 440 RB Hold Down Bars - Heat shields for 383/440
440 & 383 both have the same holes but the 440 is 8 1/4 long & the 383 is 7 1/4 long
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
