Ballast resistor question #3154496
06/26/23 08:52 PM
06/26/23 08:52 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Can a factory points type ignition ballast resistor be used with a Mopar Performance electronic ignition? Both of my cars have MP ignitions of which I am using the ballast that came with the ignition kit. I have 7 or 8 original type ballasts that I saved over the years. I was just wondering if I could use them for back-ups should the ballast that came with the ignitions fail or are they not compatible?
Re: Ballast resistor question [Re: 6PAX] #3155258
06/29/23 01:55 PM
06/29/23 01:55 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Anyone?
Re: Ballast resistor question [Re: 6PAX] #3155260
06/29/23 02:07 PM
06/29/23 02:07 PM
IL
Dart451 Offline
Dart451  Offline
IL
I have used factory ones with mopar kit, never had a problem
Re: Ballast resistor question [Re: Dart451] #3155269
06/29/23 02:29 PM
06/29/23 02:29 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
if i remember correctly, point type resistors were .5 ohm and the electronic ignition kit is 1.25 ohm there is a noticeable difference with voltage at the coil between the two but a .5 ohm resistor will run ok. i prefer the msd .8 ohm resistor for use with either point or electronic. the msd resistor has been very reliable for me.
