1970 CUDA tail panel black paint. #3153665
06/22/23 08:34 PM
06/22/23 08:34 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
Since my Cuda is coming down to the final stretch at the Painter’s Palace, I needed to go pick up the main paint (thinking either Go mango or Vitamin C) and I needed the tail panel to be blacked out. Do we use a semi gloss black for that, or is there a more correct paint for the rear?
Re: 1970 CUDA tail panel black paint. [Re: migsBIG] #3153707
06/22/23 11:14 PM
06/22/23 11:14 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I want to say the black paint used by the factory on the tail panel area was textured organisol paint.
Re: 1970 CUDA tail panel black paint. [Re: Neil] #3153712
06/23/23 12:31 AM
06/23/23 12:31 AM
Kirkland, Washington
Pacnorthcuda Offline
And you are 100 percent correct. Problem is Organisol was reproduced in many versions, so is tough to choose a suitable paint now.
Re: 1970 CUDA tail panel black paint. [Re: Pacnorthcuda] #3153843
06/23/23 02:10 PM
06/23/23 02:10 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I would contact Frank and see what they have.
https://www.rogergibsonautorestoration.com/frank/home/
Also there is this company as well.
https://8774paint1.com/collections/all/totally-auto
PPG used to sell a urethane version of it along with a texture additive that resembles fine talcum powder, but I've read they don't now? Not sure there...
Martin Senior has textured paint. https://rod-and-restoration-custom-color.martinsenour-autopaint.com/colors/PCRC18
Others on here have said they use Mar hyde paint or SEM paint and play with the paint gun settings to get a finish that looks acceptable.
Re: 1970 CUDA tail panel black paint. [Re: Neil] #3153847
06/23/23 02:38 PM
06/23/23 02:38 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That Martin Senour texture looks pretty good, and it's available in different shades & colors.
Up here where I live, NAPA carries it.
Re: 1970 CUDA tail panel black paint. [Re: topside] #3153996
06/24/23 11:44 AM
06/24/23 11:44 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Frank doesn't have any.
Here is an article that deals head on with what you are asking.
https://moparconnectionmagazine.com...oo-proper-oe-blackouts-on-comeback-cuda/
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: 1970 CUDA tail panel black paint. [Re: MOPARMIKE69] #3154009
06/24/23 01:17 PM
06/24/23 01:17 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
PPG DX1999 additive used in that article has been discontinued best I can tell. They do have an SL texture additive now that may accomplish the same thing?
More info in here from past discussions on this finish.
https://board.moparts.org/ubbthread...ead/Board/19/main/92448/type/thread.html
Re: 1970 CUDA tail panel black paint. [Re: Neil] #3154054
06/24/23 06:24 PM
06/24/23 06:24 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i used this when i painted my textured paint.
perception is 90% of reality
Re: 1970 CUDA tail panel black paint. [Re: MOPARMIKE69] #3154133
06/25/23 08:53 AM
06/25/23 08:53 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
That's all good except they forgot the flake.
Re: 1970 CUDA tail panel black paint. [Re: HEMICUDA] #3154164
06/25/23 11:55 AM
06/25/23 11:55 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
4 parts DCC 9355
3 parts DT reducer
1 part DCX 61 hardener
1 part DX 685 flattening additive
¼ ounce (per pint of mixed paint) DX 1999 texture additive
So help us out and list the flake you would use and the amount of it to make this formula work for all of us? Thanks
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: 1970 CUDA tail panel black paint. [Re: Mr T2U] #3154165
06/25/23 11:56 AM
06/25/23 11:56 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Not available anymore.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: 1970 CUDA tail panel black paint. [Re: MOPARMIKE69] #3159975
07/16/23 02:46 PM
07/16/23 02:46 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Thanks for the info everyone, I'm still looking at options as I'm waiting on paint and looking into some details.
Re: 1970 CUDA tail panel black paint. [Re: migsBIG] #3159993
07/16/23 04:49 PM
07/16/23 04:49 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
FWIW - I still have some black organisol left over, and when I sprayed it, shooting it "dry" was the hot tip to get the texture right.
Easy to accomplish, since it's lacquer.
Re: 1970 CUDA tail panel black paint. [Re: MOPARMIKE69] #3160396
07/17/23 09:33 PM
07/17/23 09:33 PM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
My 70 Cuda is also in the paint shop nearly ready for color. Since I'm personally not looking for a perfectly accurate textured organisol look, I'm using a product called "Essentials". This will be my third time using this product and I much prefer it over the original organisol due to cost and ease of care. Below you can see a photo of my A12 hood painted with Essentials. At the end of the article that MoparMike linked, they actually try using another affordable product called SEM Trim Black, which they modified to get a similar look to organisol with great results. Point being, if you're willing to forego actual organisol, you've got options! And in my opinion your wallet and future-self will thank you every time you dry your car after washing it.
[Linked Image][/url]
I'm using the Essentials (pictured here on my old Roadrunner) on my Cuda's rear tail panel, AAR spoiler, hood, and even the car's dash frame. The Essentials has a satin sheen, not flat, and is smooth to the touch. It's scratch resistant and easy to dry.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 1970 CUDA tail panel black paint. [Re: MOPARMIKE69] #3160425
07/17/23 10:54 PM
07/17/23 10:54 PM
Mr T2U Offline
Mr T2U  Offline
i still have over 1 qt of it.
Re: 1970 CUDA tail panel black paint. [Re: Mr T2U] #3208252
01/26/24 10:30 AM
01/26/24 10:30 AM
GA
roadrunninMark Offline
GA
Any updates on the tail panel paint? I am in the need for some too. Thanks.
Re: 1970 CUDA tail panel black paint. [Re: roadrunninMark] #3208276
01/26/24 12:32 PM
01/26/24 12:32 PM
Woodbridge
Tommy The Chryco Offline
Woodbridge
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
Re: 1970 CUDA tail panel black paint. [Re: Tommy The Chryco] #3213183
02/13/24 10:19 AM
02/13/24 10:19 AM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Originally Posted by Tommy The Chryco
aerosol/can, mix to use, amount? Need a little more info buddy.
Re: 1970 CUDA tail panel black paint. [Re: migsBIG] #3213208
02/13/24 12:36 PM
02/13/24 12:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Migs - judging by teh way the size is listed on his website, I'd guess it's a pint can - not an aerosol.
More than enough for a couple 'Cuda tail panels.
Re: 1970 CUDA tail panel black paint. [Re: topside] #3213268
02/13/24 05:48 PM
02/13/24 05:48 PM
Star Idaho
67vertman Online rolleyes
67vertman  Online Rolleyes
Star Idaho
When I did mine, I used 4oz and had plenty left over.
When I did my grill and front valance with Totally Auto aerosol cans, I used 1 full and about a quarter of another can.
My Monster are real!
Living within your means makes life pretty easy.
