Re: FJ6: Single Stage Engine Comp, BCCC Exterior
[Re: A39Coronet]
#3153732
06/23/23 07:19 AM
06/23/23 07:19 AM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Since you haven't done it yet why not paint the under side to simulate how it actually came from the factory , primer color then overspray ?
[Re: A39Coronet]
#3153763
06/23/23 08:53 AM
06/23/23 08:53 AM
Posts: 12,200 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Haven't done that color, but your process is pretty much what we have always used. Touching up the single stage is much easier than base/clear. Are you planning on painting the bottom in primer gray or body color?
Master, again and still
[Re: DaveRS23]
#3153768
06/23/23 09:11 AM
06/23/23 09:11 AM
Posts: 1,113 Usa
A39Coronet
Usa
Since you haven't done it yet why not paint the under side to simulate how it actually came from the factory , primer color then overspray ? I considered this route but ultimately decided I like the look of the painted underneath. The car will have some intentional aspects of OE, but I didn't want to recreate anything that I felt was a byproduct of mass production. Haven't done that color, but your process is pretty much what we have always used. Touching up the single stage is much easier than base/clear. Are you planning on painting the bottom in primer gray or body color? Ok great, thanks for the feedback. I feel like everything I read before buying paint said to go BCCC for exterior. After I bought the paint I feel like everything said to do single stage haha, hopefully it just turns out respectable.
[Re: Stanton]
#3153883
06/23/23 05:45 PM
06/23/23 05:45 PM
Posts: 2,928 Canada
RobR
Canada
[Re: skdmark]
#3153903
06/23/23 07:46 PM
06/23/23 07:46 PM
Posts: 1,113 Usa
A39Coronet
Usa
That's the combo my car (71 Challenger GA4) was done in 30 years ago. Worked well. Only difference was we did the jams in single stage too. Where did you do the cross over...under the weather strip or at the doors edge? More than one way to skin a cat. I would talk to your painter about what he is comfortable with. The more metallics or pearls are in the paint, the harder it will be to get paint to match between single stage and base/clear. Painter is me, and this will be my first paint job...paint is non metallic.
[Re: A39Coronet]
#3153963
06/24/23 09:04 AM
06/24/23 09:04 AM
Posts: 1,002 rust belt
Moparite
rust belt
You may want to spray a test panel of both the bccc and the single stage and see if they are to your liking. You may want to paint the engine compartment bccc also.
[Re: A39Coronet]
#3154024
06/24/23 02:57 PM
06/24/23 02:57 PM
Posts: 117 SE-WI
skdmark
SE-WI
That's the combo my car (71 Challenger GA4) was done in 30 years ago. Worked well. Only difference was we did the jams in single stage too. Where did you do the cross over...under the weather strip or at the doors At the doors. GA4 is a metallic and my painter had no issues in using the 2 different types of paint. It was all done based on his recommendations and experience. It was all PPG product and it was a long time ago. I know the technology and environental requirements of auto paint have changed formulations considerably since then.
