Re: Motorhome 440 combos
[Re: Cab_Burge]
#3152926
06/20/23 07:18 AM
06/20/23 07:18 AM
Posts: 9,860 MI, usa
dvw
MI, usa
My son had a low comp style 440. MP 484 cam, Eddy heads, RPM intake, 600 Eddy carb, headers, 3.91, large 12" low performance stock torque converter, 255/60 radial T/A's. Though this combo seems all wrong it ran pretty decent. The cam/converter allowed no spin starts from just over idle. Ran 12.90@109 in a all stock 65 Belvedere. Doug
[Re: Cab_Burge]
#3153180
06/20/23 09:18 PM
06/20/23 09:18 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I wish I remembered the combo I built for my Dad many years ago. .030’over 440, aftermarket cam, and I even ported his heads. That thing was a bear and towed great.
[Re: pittsburghracer]
#3153263
06/21/23 08:30 AM
06/21/23 08:30 AM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
The easiest combo in the world is a 440 block that's bored to 4.342 (standard 400) and a stroker 4.15 crank with standard 440 6.76" rods using the stock 400 piston. This is combo the 4.15" stroke was decided upon by Mopar. Throw on a set of stealth heads and make some cheap power and torque. As I remember the piston comes up very close to zero deck, maybe. .015-.020 in the hole
People fuss about the heavy bobweight but it's lighter than a factory 440, even more if you whack 1/2" off the factory pressed pins.
[Re: Streetwize]
#3153280
06/21/23 09:31 AM
06/21/23 09:31 AM
Posts: 4,689 Wichita
GY3
Wichita
I had a cast crank '75 440 that was a re-ring and bearing special. It had the MP .484 cam and, at first, 906 heads and stock intake. Within a year it had standard port Stealths and a Holley Street Dominator. It ran really well for what it was and was a lot of fun. I thought I had a 6500 chip in the MSD when it turns out it was a 7500 chip. One day on a particularly spirited run down the highway I lost a wrist pin at the top of 2nd gear. The huge cast piston just couldn't take it anymore. The rod ended up sawing my perfect virgin block in half and made a metal soup out of the lower end. We were going fast enough I made it to the turnoff for the neighborhood and coasted within a few blocks of my house. The neighbor that was with me swore the car came off the ground when it blew and we were skating in oil and antifreeze for a bit... I never made it to the track but assume it was a probably a mid 12's combo as the car was lighter back then. I figured I had about $300+ in the shortblock and the heads came out unscathed so it was a reasonably priced lesson.
[Re: Burlapen]
#3153284
06/21/23 10:19 AM
06/21/23 10:19 AM
Posts: 2,926 A shed in England
Tig
A shed in England
Many years ago we built a motorhome block 440, it went 12.50's with a Torker II, 750 d/p Holley, a .509 cam, headers 3.90 gears and a B&M 10" converter. Weighed about 3700lb w/d at the time. Eventually it ran in the hi 11's with Indy S/R heads and 1.6 ratio rocker arms. An even later incarnation of the motor ran 12.00's with iron heads and a performer rpm.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Streetwize]
#3153292
06/21/23 11:08 AM
06/21/23 11:08 AM
Posts: 712 Southern Alberta
Uberpube
Southern Alberta
People fuss about the heavy bobweight but it's lighter than a factory 440, even more if you whack 1/2" off the factory pressed pins. Wouldn't one have to cut some valve reliefs in the pistons with that? Even with the low-comp pistons down in the hole there is a limit to what cam can be run even with stock valve size
[Re: Uberpube]
#3153367
06/21/23 05:00 PM
06/21/23 05:00 PM
Streetwize
Weddington, N.C.
I had all the parts and I mocked one up but never built it with the oem pistons, but I think an KB Hypereutectic piston was 1.9 ch and stuck out about +.030 which I think I would have milled down, it already had the eyebrows. I would up using a bushed rod with a .990 BBC pin and an Arias piston
I think It would actually be a really cool combination with the KB's which were about $200 a set back then. i wouldn't have blinked at putting some eyebrows in the pistons though, I think the exhaust might have been more of an issue than the intake on that one.
