Shift kits in a 727 #3152749
06/19/23 04:18 PM
06/19/23 04:18 PM
BlueRacer69 Offline OP
Hi guys. How hard is it to remove a shift kit from a 727 transmission. Now that I'm a old man I don't like the hard shifts or how long it takes to shift into drive. Seems like it takes forever to go from 2nd gear to drive. I'm talking 40 to 45mph. Need your advice. Thanks.
Re: Shift kits in a 727 [Re: BlueRacer69] #3152752
06/19/23 04:27 PM
06/19/23 04:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The shift kit itself won't cause late 2-3 upshifts, the TP linkage adjustment controls that for the most part. Try shortening the linkage for earlier shifts.
As far as the hard shifts, the orifices in the steel separator plate that have been enlarged are hard to go back from...need stock parts or a whole new stock valve body.
Re: Shift kits in a 727 [Re: John_Kunkel] #3152900
06/20/23 12:47 AM
06/20/23 12:47 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
iagree
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Shift kits in a 727 [Re: John_Kunkel] #3152938
06/20/23 08:36 AM
06/20/23 08:36 AM
Where can I find or get a stock valve body and is it hard to change. As far as the kickdown arm goes its screwed all the way back.
Re: Shift kits in a 727 [Re: BlueRacer69] #3153059
06/20/23 01:59 PM
06/20/23 01:59 PM
moparx Offline
moparx  Offline
valve bodies are easy to change after you drop the pan.
just 14, 1/4" bolts [7/16" head"], and the E clip removed from the park rod. [unless you elect to leave the rod attached, and move the driveshaft around so the ball on the end of the park rod pulls through the slot on the tailshaft "park gear"]
don't forget to remove the NSS, and the kick down and gear selector levers before you start.
i think the trans-go TF-2 instruction pdf has been posted here before. the pictures will show you what needs done.
as for finding a stock valve body, check any transmission repair shops near you. you might get lucky. or post a want add in the proper transmission forum here.
when you say the kick down arm is "screwed all the way back", do you mean it's as short as it can get ?
beer
Re: Shift kits in a 727 [Re: moparx] #3153063
06/20/23 02:28 PM
06/20/23 02:28 PM
beer
Yes I have the kickdown arm thats attached to the carb stud as short as it will go.
Re: Shift kits in a 727 [Re: BlueRacer69] #3153091
06/20/23 04:43 PM
06/20/23 04:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Stock carb or aftermarket:? If aftermarket, does it have the correct Mopar throttle lever adapter?
Re: Shift kits in a 727 [Re: John_Kunkel] #3153160
06/20/23 08:11 PM
06/20/23 08:11 PM
Yes it does have the adapter , and the carb is a Edelbrock Performer AVS 800cfm.
Re: Shift kits in a 727 [Re: BlueRacer69] #3153174
06/20/23 08:39 PM
06/20/23 08:39 PM
A727Tflite Offline
A727Tflite  Offline
I’m north of Clarkston. If you can’t find a good valve body PM me, I have quite a few in stock,
