Re: 4-speed reverse switch plunger not engaging help [Re: RSI700VIPER] #3056433
07/05/22 06:56 PM
07/05/22 06:56 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Try another switch, I have found some have a slightly longer push travel to activate...
Just my $0.02... wink
Re: 4-speed reverse switch plunger not engaging help [Re: biggE] #3056483
07/05/22 10:22 PM
07/05/22 10:22 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Originally Posted by biggE
You can order the correct gasket from Brewers
And the correct switch as well wink beer
Re: 4-speed reverse switch plunger not engaging help [Re: RSI700VIPER] #3056813
07/06/22 05:20 PM
07/06/22 05:20 PM
IMGTX Offline
IMGTX  Offline
I had this problem on my Challenger and it was a worn reverse shift lever. The hole was a little wallowed out on the inside of the lever where it bolts to the transmission not the rod end.
It would not turn the lever far enough to engage the switch.
Worth a look.
Re: 4-speed reverse switch plunger not engaging help [Re: Sinitro] #3056877
07/06/22 08:27 PM
07/06/22 08:27 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
As I posted previously these replacement switches can be problem..
We have found some to be shorted and some have varying activation push length.
All this points to made in China and inconsistent quality control. I have a collection of 4 or 5 switches bought on-line and each operates differently... eek
Once in awhile I will see an NOS 1 on-line but they want big $$ so spending $15-20 for a Chinese clone may seem like a better deal..
Re: 4-speed reverse switch plunger not engaging help [Re: IMGTX] #3057046
07/07/22 09:33 AM
07/07/22 09:33 AM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
Worth a look.
Appreciate the comment but as mentioned earlier, the lever is up against the case inside the trans. It can't go back any further. I've ordered a new switch hoping it reaches in a hair deeper.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: 4-speed reverse switch plunger not engaging help [Re: RSI700VIPER] #3057048
07/07/22 09:37 AM
07/07/22 09:37 AM
NW New Jersey
NW New Jersey
Worth a look.
I couldn't immediately find a NOS switch so I ordered a "Standard" brand. Hopefully its not made in China.
Re: 4-speed reverse switch plunger not engaging help [Re: RSI700VIPER] #3152599
06/19/23 01:46 AM
06/19/23 01:46 AM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
kinda curious if you ever got this resolved and if the "standard" brand switch worked. i'm having the same problem with my challenger with the passon 5 speed. i might call brewers because i think i read somewhere that they have a switch that addresses this problem.
Re: 4-speed reverse switch plunger not engaging help [Re: SV_MOPARS] #3152668
06/19/23 12:17 PM
06/19/23 12:17 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
From time to time, we have needed to machine the shoulder back on the switch to allow it to screw in deeper. Obviously this is for the A833/A230....assume it would be the same for the trans you mentioned. I would check the switch with a meter to see if that is the case before modifying anything.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: 4-speed reverse switch plunger not engaging help [Re: SV_MOPARS] #3152694
06/19/23 01:10 PM
06/19/23 01:10 PM
NW New Jersey
NW New Jersey
It worked, but only after I substituted a very, very thin washer. Good luck.
Re: 4-speed reverse switch plunger not engaging help [Re: RSI700VIPER] #3152901
06/20/23 12:57 AM
06/20/23 12:57 AM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
Will probably machine the surface down a bit. thanks for the response from the both of you.
