New Radiator Selection for Charger #3150789
06/12/23 11:38 AM
06/12/23 11:38 AM
Cannelton, IN
mike337 Offline OP
mike337  Offline OP
Cannelton, IN
I have a 69 Charger with a new 440 stroker 6-pack engine and automatic trans. I am getting closer to getting it ready to run in the car for the first time (broken in on a dyno), and want to make sure the new cooling system is up to the task.
The engine has a serpentine belt system on it, so I will be sticking with dual electric fans & shroud to go on a new radiator. The electrical system has been upgraded with a Power Master Alternator so no worry on power for the fans.
I have a generic aluminium radiator in the car as a placeholder, but leery of using a radiator of unknown quality on this new engine. Also want to make sure the inlet/outlet connections are correctly placed since I have seen new radiators with different locations for them.
So I am looking for a 26 inch radiator, for an automatic trans car, that can use a shroud with dual fans., and want to confirm outlet locations for a 1969 big block B-Body.
Mike
Re: New Radiator Selection for Charger [Re: mike337] #3151462
06/14/23 12:03 PM
06/14/23 12:03 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I used a Griffin exact fit on the Coronet.
Link to Charger:
https://www.griffinrad.com/inc_results_ymm.php?year=1969&make=dodge&model=Charger
Re: New Radiator Selection for Charger [Re: 451Mopar] #3151512
06/14/23 02:55 PM
06/14/23 02:55 PM
New York, USA
Chargerfan68 Offline
New York, USA
I used the Griffin on my 68 Charger and I’m also very satisfied with it. Fit perfectly and performs very well. I painted it black with Radiator paint snd looks almost stock aside from the tank numbers, tig welded neck. Very nice piece.
Re: New Radiator Selection for Charger [Re: Chargerfan68] #3152111
06/16/23 06:58 PM
06/16/23 06:58 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I use a champion aluminum 4 core rad that I too painted black on my 470 stroker and its almost too efficient lol and you can't beat the price!
Re: New Radiator Selection for Charger [Re: mike337] #3152152
06/16/23 09:16 PM
06/16/23 09:16 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Cold Case 26 inch with dual electric fans on my 69 with a 528 Hemi and A/C. No problems for me.
Re: New Radiator Selection for Charger [Re: NITROUSN] #3152266
06/17/23 12:01 PM
06/17/23 12:01 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
ALWAYS here only good about Champions and Griffin. I really like Chargerfan68's up keeps it somewhat stock appearing.
Facts are stubborn things.
