New Radiator Selection for Charger
#3150789
06/12/23 11:38 AM
06/12/23 11:38 AM
Posts: 1,530 Cannelton, IN
mike337
Cannelton, IN
I have a 69 Charger with a new 440 stroker 6-pack engine and automatic trans. I am getting closer to getting it ready to run in the car for the first time (broken in on a dyno), and want to make sure the new cooling system is up to the task.
The engine has a serpentine belt system on it, so I will be sticking with dual electric fans & shroud to go on a new radiator. The electrical system has been upgraded with a Power Master Alternator so no worry on power for the fans.
I have a generic aluminium radiator in the car as a placeholder, but leery of using a radiator of unknown quality on this new engine. Also want to make sure the inlet/outlet connections are correctly placed since I have seen new radiators with different locations for them.
So I am looking for a 26 inch radiator, for an automatic trans car, that can use a shroud with dual fans., and want to confirm outlet locations for a 1969 big block B-Body.
Mike
Re: New Radiator Selection for Charger
[Re: 451Mopar]
#3151512
06/14/23 02:55 PM
06/14/23 02:55 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I used the Griffin on my 68 Charger and I’m also very satisfied with it. Fit perfectly and performs very well. I painted it black with Radiator paint snd looks almost stock aside from the tank numbers, tig welded neck. Very nice piece.
[Re: NITROUSN]
#3152266
06/17/23 12:01 PM
06/17/23 12:01 PM
Posts: 15,871 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
ALWAYS here only good about Champions and Griffin. I really like Chargerfan68's keeps it somewhat stock appearing.
Facts are stubborn things.
