Electric Stove - Oven Heat Element Blew:
#3152067
06/16/23 02:47 PM
06/16/23 02:47 PM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
This has never happened in my life before, but last night the bottom heating element in our Frigidaire stove blew - got overheated & hummed, then popped, & sparked & melted in one place. I watched some videos last night on BoobTube - apparently this is not uncommon. SO, I went out & bought a new one this afternoon & just installed it - VERY simple install. This is the type of element our stove has: https://youtu.be/menDB7rH58IAnyway, just installed it, turned the breaker back on, turned the oven on to preheat, & nothing - no heat through the new element. I left it on for about 4 minutes, then turned it off & shut the breaker off. I'm thinking something else internal - not just the coil. Any ideas?
Re: Electric Stove - Oven Heat Element Blew:
[Re: TJP]
#3152175
06/16/23 10:28 PM
06/16/23 10:28 PM
Posts: 4,950 WI
Dcuda69
WI
Had the same thing happen to our GE oven about 3 months ago. Wife had been asking for a new one for a while so we were off to the appliance store within the hour. Some how that morphed into a new fridge and microwave as well......$4500 later......... LMAO I know...right! I can't complain.....she works hard, doesn't ask for much and all those appliances were 20+ yrs old. Now we have all new stuff that looks fantastic and I'm sure will never last 20+ yrs.....lol
[Re: Sunroofcuda]
#3152204
06/17/23 01:05 AM
06/17/23 01:05 AM
Posts: 4,152 Canada -- Posts: 4034 -Registe...
5thAve
This has never happened in my life before, but last night the bottom heating element in our Frigidaire stove blew - got overheated & hummed, then popped, & sparked & melted in one place. I watched some videos last night on BoobTube - apparently this is not uncommon. SO, I went out & bought a new one this afternoon & just installed it - VERY simple install. This is the type of element our stove has: https://youtu.be/menDB7rH58IAnyway, just installed it, turned the breaker back on, turned the oven on to preheat, & nothing - no heat through the new element. I left it on for about 4 minutes, then turned it off & shut the breaker off. I'm thinking something else internal - not just the coil. Any ideas? Does your stove have fuses anywhere? We've had a few oven elements go over the years and they've always worked right off the bat after replacing them. There might also be a wiring diagram inside the rear cover that might help.
[Re: massdaytona]
#3152253
06/17/23 10:29 AM
06/17/23 10:29 AM
Sunroofcuda
Highland, MI.
youtube.com is your friend Hasn't helped much, other than showing how to replace the element. I'm thinking the fuse theory might be more likely.
[Re: GomangoCuda]
#3152320
06/17/23 02:24 PM
06/17/23 02:24 PM
5thAve
Check the wires inside the stove. I've seen them burn up. The most common spot for the wires to go is at the connection to the element but yeah the wiring should be easy to check too with the back off.
[Re: 5thAve]
#3152364
06/17/23 06:12 PM
06/17/23 06:12 PM
Sunroofcuda
Highland, MI.
Well - went & bought a new one. I don't have time to put it on the hoist & rebuild it! I did this with a washer a couple years ago & after buying a $200.00 controller that didn't solve the problem, I said no more! The sales guy today said they go 10-12 years, so I figgered we got a good 15-ish years out of it. It was a good old stove - RIP.
[Re: Dcuda69]
#3152402
06/17/23 09:44 PM
06/17/23 09:44 PM
Posts: 15,408 Omaha Ne
TJP
Omaha Ne
Had the same thing happen to our GE oven about 3 months ago. Wife had been asking for a new one for a while so we were off to the appliance store within the hour. Some how that morphed into a new fridge and microwave as well......$4500 later......... LMAO I know...right! I can't complain.....she works hard, doesn't ask for much and all those appliances were 20+ yrs old. Now we have all new stuff that looks fantastic and I'm sure will never last 20+ yrs.....lol Mine is the same, on 7-11 it'll be 42 years I won big that day
[Re: TJP]
#3152890
06/19/23 11:42 PM
06/19/23 11:42 PM
Posts: 10,218 Someplace you aren't
SomeCarGuy
I remember the element in my grandmas stove exploding. That was one pizza that didn’t get eaten!
I want my fair share
