Finally made it to the track #3151988
06/16/23 09:45 AM
06/16/23 09:45 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
It’s been over 20 years since I’ve had this car at the track. But I finally made it back!
I was a little disappointed with the et.
1st run off the trailer was the best mph @115 with a net of 12.23
2nd run was 12.007 @ 111
3rd was 12.067 @ 109
Best 60’ was 1.612
It’s a 540 that made 550+ whp and 600tq at the wheels on pump gas
A833 with a 4.10 Dana
1968 barracuda notchback with 30.5” tall et streets.
I did shift really slow almost .5 seconds between gears according to my data log.
Re: Finally made it to the track [Re: 8urvette] #3151994
06/16/23 10:25 AM
06/16/23 10:25 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Congrats on making it to the track!
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Finally made it to the track [Re: 8urvette] #3152033
06/16/23 12:33 PM
06/16/23 12:33 PM
Looking at the time slips make me wonder if something is going south based on the loss of MPH on every run work wrench scope twocents
How much did the weather change from run 1 to the last run?
Re: Finally made it to the track [Re: Cab_Burge] #3152061
06/16/23 02:22 PM
06/16/23 02:22 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Your best 60' and mph are good for mid 11's for sure! It's always a successful day when it is in one piece after a day at the track.
Is it fuel injected or carbureted? It almost looks like fuel starvation as the mph is very close at the 8th and then drops off pretty quickly in the back half. I assume fuel injected based on the datalog comment- would be interesting to see if timing was the same for all runs, and what a/f was doing.
Re: Finally made it to the track [Re: 8urvette] #3152099
06/16/23 05:55 PM
06/16/23 05:55 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Yep. Seems like some stuff is not right. But you'll figure it out and get it right.
Like someone said, it does look like at least down track fuel delivery problems. The 92 mph at the 1/8 mile should result in 115 mph at the 1/4". That said, 540 whp in an A Body should be trapping on the sunny side of 130 mph and probably low 10s.
You'll get it. Have fun!
Re: Finally made it to the track [Re: BSB67] #3152112
06/16/23 07:09 PM
06/16/23 07:09 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Let’s see if this works
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Finally made it to the track [Re: Cab_Burge] #3152194
06/16/23 11:39 PM
06/16/23 11:39 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
I was thinking the same thing, then i looked at my dyno graph and compared it to my dyno sheet. I realized i was spinning the motor way to high!!!! I was shifting around 6800, but peak TQ is at 4000 and by 6500 rpms ive lost over 200 ftlbs of tq. and around 150 HP. I think i need to shift it a bit sooner.
I guess this is all part of the learning process.
Re: Finally made it to the track [Re: Blusmbl] #3152195
06/16/23 11:41 PM
06/16/23 11:41 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
I had thought the same thing. When I looked at the data my AFRS were good and solid, and fuel pressure was constant too. Never leaned out everything looked good. Im thinking I am the problem. HAHAHA
Re: Finally made it to the track [Re: 8urvette] #3152232
06/17/23 08:39 AM
06/17/23 08:39 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Slow shifts will definitely slow you down quite a bit, .5 seconds per shift is 1.5 seconds that you’re not accelerating. Its not as easy as it looks or seems on the street though!
The important thing is you got back to the track, and have a baseline to improve on. Thats not bad at all though, but you really have to hammer those gears for the best time with a stick. If it makes you feel any better my car made 479 RWHP and the best I managed last time out with the 833 was 12.56 @ 113 - sloooow shifts (about .5 seconds like yours, maybe woese) and very soft 60 ft times for me.
At your power level and weight I would think you should be able to go low 11s @ 120+ or quicker, but of course some dynos read high, chassis needs to be optimized, etc. What heads/cam/intake and what compression ratio?
What is strange is that your first run picked up way more MPH on the back end of the track - are you sure you weren’t lifting on the others?
Re: Finally made it to the track [Re: GTX MATT] #3152234
06/17/23 08:57 AM
06/17/23 08:57 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
That looks like it could very well be the reason. Loosing 6 mph but going quicker.
Re: Finally made it to the track [Re: GTX MATT] #3152246
06/17/23 09:51 AM
06/17/23 09:51 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
I agree there seems like there is more in it.
It has victor heads, solid roller cam with 600 lift and like 270ish duration. 10.5 to 1 compression.
The first run with the best MPH I was actually trying to take it easy the slow shifts were intentional, i had stripped the cluster gear in the trans on the street a few months ago. But i also short shifted it on the first run, i am hoping that is why the mph was so much more. the last 2 runs i spun it to 6800/7000 each shift. way out of the power band.
the first run i left the line at 2500 rpms and spun the tires. by the third run i was leaving at 4500 with some light wheel spin. i am excited to get back to the track!!!!
Re: Finally made it to the track [Re: 8urvette] #3152256
06/17/23 10:46 AM
06/17/23 10:46 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Keep playing with it. Have fun !
Re: Finally made it to the track [Re: FastmOp] #3152328
06/17/23 03:05 PM
06/17/23 03:05 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I doubt short shifting effected the trap mph. The 1/8 mile mph were all 92 mph. It slowed down after mid track
Re: Finally made it to the track [Re: 8urvette] #3152425
06/17/23 11:49 PM
06/17/23 11:49 PM
Short shifting makes the motor stay in high gear longer, which has made more MPH on my cars when I short shifted them shruggy
Re: Finally made it to the track [Re: Cab_Burge] #3152623
06/19/23 09:11 AM
06/19/23 09:11 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
We will see. After comparing my runs to my dyno charts I was shifting way to high. A few thousand rpm’s too high.
The track isnt running this week but will do it again next week.
Hope to have more results and maybe some progress by then!
Re: Finally made it to the track [Re: 8urvette] #3152635
06/19/23 09:47 AM
06/19/23 09:47 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I think you would still want to shift at 6k+ to keep it in max average horsepower. There are ideal shift point calculators online to give you an idea.
Re: Finally made it to the track [Re: 8urvette] #3153516
06/22/23 09:12 AM
06/22/23 09:12 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Congrats!
Re: Finally made it to the track [Re: INTMD8] #3153581
06/22/23 02:58 PM
06/22/23 02:58 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
I checked a few shift point calculators and where it makes its power it says the idea shift area is about 6k. I’m hoping between that and speeding up my actual shifts I’ll be in the mid to lo- 11s
Re: Finally made it to the track [Re: 8urvette] #3153587
06/22/23 03:20 PM
06/22/23 03:20 PM
I've had many motors that wanted to be shifted from 300 to 600 RPM above peak HP RPM, you need to shift it so the motor RPM drops down to the peak tuque RPM twocents scope
Testing the shift RPM is another way to find out what your combination wants scope up work
Re: Finally made it to the track [Re: Cab_Burge] #3155096
06/28/23 10:59 PM
06/28/23 10:59 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
WELL I FOUND out tonight that it wants a new clutch or throwout bearing. I added a pressure switch to the hydraulic line for a future tool. I had my dad help bleed the clutch line and i called it good without testing it. Turns out something wasn't right and the clutch would not hold.
Did a 1.8 60' and it just got worse from there.
Ended up with a 14.77 @ like 85 mph. NO i didnt stay in the whole time, i couldnt get the car the shift to second and then once it went it it slipped bad there filling the car with smoke. HA. ill did into it in a week or two and see what the problem is.
