LED Dash Lights #3150542
06/11/23 05:02 PM
06/11/23 05:02 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I know the dimmer will give the lights a flicker, so set the dimmer and leave it alone so i have read.
But what brand or type has anyone used with Sucess and nice appearance.
this is for my 72 demon.
thank you
Thank you
Kiddart
Re: LED Dash Lights [Re: Kiddart] #3150549
06/11/23 05:19 PM
06/11/23 05:19 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
There are significant variables for LED dash lites for color and brightness....
My recommendation would be to buy 3 or 4 different single LEDs, try each and then choose which one delivers the expected performance...
Just my $0.02... wink
Re: LED Dash Lights [Re: Sinitro] #3150600
06/11/23 07:18 PM
06/11/23 07:18 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
are there any brands better than the other?
Thank you
Kiddart
Re: LED Dash Lights [Re: Kiddart] #3150612
06/11/23 07:58 PM
06/11/23 07:58 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
We have used multiple brands and didn't find any significant differences for reliability. As I posted previously, I would get a few samples and go from there, I did find a wide range of color and brightness, but once U find one that U like buy enough quantity and a couple of spares.
Though frequently some people will mention a favorite but again this comes down to a personal choice.
Re: LED Dash Lights [Re: Sinitro] #3150635
06/11/23 08:50 PM
06/11/23 08:50 PM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
Here is what I put in the Rallye Gauge light bar in my 71 Barracuda.
Good color (warm white), brighter than the OE incandescent (e-bodies have notoriously dark gauge lighting) and dimmable.
https://www.amazon.com/gp/product/B085W99H2F/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1
Re: LED Dash Lights [Re: skdmark] #3150666
06/11/23 11:15 PM
06/11/23 11:15 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
That was by choice not chance: will become fatiguing/or distracting to drive around at night with bright dash lamps for hours .
Re: LED Dash Lights [Re: PhillyRag] #3150714
06/12/23 06:09 AM
06/12/23 06:09 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
I went with https://www.superbrightleds.com/ for my car. Some that I used are no longer available. They are dimmable, but kind of flicker when they dim. I have a 70 Monte Carlo and the dash lenses are green tinted. I went with green lights in the console and white in the dash. May swap to green if I ever take it apart again. The color of bulb should match the color of the lens (hi beam is blue, so go with blue bulb).
Re: LED Dash Lights [Re: MI_Custumz] #3150807
06/12/23 12:16 PM
06/12/23 12:16 PM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
I too went with the superbrightleds.com lights.
Mine are not dimmable - its either on or off.
I went with the cool blue ones as I want them clear and bright at night.
Re: LED Dash Lights [Re: 76Beeper] #3151013
06/12/23 08:59 PM
06/12/23 08:59 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I agree, these are the best
https://www.superbrightleds.com/led...e-135-lumens+color-Green+packamt-10-Pack
This is what I used on my '89 Diplomat and the first I found to be dimmable and work nicely. Past ones in white were too bright and washed out gauges. I was able to select green and they dim and look great. Been over a year now stilling working well. My picture isn't as good as it looks in person.
Facts are stubborn things.
Re: LED Dash Lights [Re: larrymopar360] #3151305
06/13/23 06:59 PM
06/13/23 06:59 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I don’t want to hijack this post, but would like to see a ‘68-69 B body dash with LED’s and what color was used. I’m thinking about upgrading mine this winter.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: LED Dash Lights [Re: 68LAR] #3151318
06/13/23 07:21 PM
06/13/23 07:21 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I can tell you this much. Using white in my Diplomat with the factory greenish/blueish covers was a mistake. Too bright in LED form and washout the factory covers and turned everything white instead of factory green. I ordered more in green and it looks perfect and dims. I would order what ever color bulb the factory gauge color was, which I guess was also green in the '68-'69 B Body. twocents
Re: LED Dash Lights [Re: larrymopar360] #3151379
06/13/23 11:06 PM
06/13/23 11:06 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Thanks. Good info. What part number and where did you get your LED’s How many did you order? I’m thinking I could leave the turn signal, brake, high beam and oil lights as is.
Re: LED Dash Lights [Re: 68LAR] #3151572
06/14/23 05:38 PM
06/14/23 05:38 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
These are the exact ones I bought, in green and I bought ten I think (it's been awhile) because I wasn't sure how many I needed until I pulled it apart but ten was plenty. I don't know how many yours will need and your twisty bulb holders are probably different size so I'd check with seller to see what size you need. But again, these particular brand and bulb dim, look good and are reilable. up
Re: LED Dash Lights [Re: larrymopar360] #3151616
06/14/23 07:54 PM
06/14/23 07:54 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Thank you so much. Really appreciate your help
Re: LED Dash Lights [Re: 68LAR] #3151767
06/15/23 01:29 PM
06/15/23 01:29 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
this is what I purchased and installed. I put them in last night getting ready for this weekend cruising around.
I bought them from superbrightleds.com
194 LED Bulb - COB LED - T3.25 Miniature Wedge Base - 135 Lumens - Cool White - 10 Pack
SKU: 194-CWCOB1W-10PK
1 $28.95
194 LED Bulb - COB LED - T3.25 Miniature Wedge Base - 135 Lumens - Cool White - Single
10 x 194 LED Bulb - COB LED - T3.25 Miniature Wedge Base - 135 Lumens - Cool White - Single $0.00
Thank you
Kiddart
Re: LED Dash Lights [Re: Kiddart] #3152008
06/16/23 11:18 AM
06/16/23 11:18 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Used Ebay LED's here, they dim with no issue. They work with the Dakota Dash just fine and I can switch them off by turning the dimmer right down if needed.
Night settting :
Day setting :
