1938 Dodge truck parts #3151313
06/13/23 07:12 PM
06/13/23 07:12 PM
lancaster,california
johnnycuda Offline OP
Hey guys, I am looking for a few parts for my 38 Dodge truck, thought I would ask here, see if anybody has parts they are willing to sell. I am looking for outside door handles, the Dodge emblem for the center of the dash, a passenger rear fender, and a pair of tailight brackets.
Please let me know if you have or know someone that does, thanks in advance.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: 1938 Dodge truck parts [Re: johnnycuda] #3151580
06/14/23 05:54 PM
06/14/23 05:54 PM
AZ
Mike P Offline
Mike P  Offline
AZ
Afraid I don't have anything on your wish list.....it would be great to see a picture of your project though grin
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: 1938 Dodge truck parts [Re: Mike P] #3151721
06/15/23 10:05 AM
06/15/23 10:05 AM
Dandridge TN
Dabee Online content
Dabee  Online Content
Dandridge TN
Roberts Motor Parts may have the door handles. Try giving them a call.
https://www.robertsmotorparts.com/
Re: 1938 Dodge truck parts [Re: Mike P] #3151750
06/15/23 12:26 PM
06/15/23 12:26 PM
II appreciate you letting me know, here is how I got the truck, ( have the grill some other parts were inside), it is torn apart now, rack and pinion front with disc brakes, we made a set of CalTrac bars and Split Mono springs for it, 8.75 rear with 3.55 suregrip, mounted a fuel cell behind the rear axle.
Re: 1938 Dodge truck parts [Re: johnnycuda] #3151791
06/15/23 02:25 PM
06/15/23 02:25 PM
AZ
Mike P Offline
Mike P  Offline
AZ
Looks like a great starting point.
I found this place just after I "finished up" my 37, so I really haven't dealt with him but he does seem to have some nice patch panels if you need them.
Does yours have the fender mounted spare?
Re: 1938 Dodge truck parts [Re: Mike P] #3151838
06/15/23 05:44 PM
06/15/23 05:44 PM
It does have the fender mounted spare, I wish it didn't, I bought a weld in patch for that from a JR's PT50 site, but it seems a bit too small, like 1/4-3/8" all the way around, got a fuel neck hole cover from him as well.
I got all new glass for it from a place in Washington state, found the windshield crank that goes in the center of the dash, I don't have the mechanism, not sure what I will do there.
Re: 1938 Dodge truck parts [Re: johnnycuda] #3151891
06/15/23 09:03 PM
06/15/23 09:03 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Will the windshield mechanism from a 39-47 work?
I happen to have one here (missing the crank handle, but the mechanism works great). PM me.
Re: 1938 Dodge truck parts [Re: poorboy] #3151946
06/16/23 07:37 AM
06/16/23 07:37 AM
E
earlymopar Offline
earlymopar  Offline
E
No. The later windshield drive mechanisms are quite a bit different.
Re: 1938 Dodge truck parts [Re: earlymopar] #3151993
06/16/23 10:24 AM
06/16/23 10:24 AM
AZ
Mike P Offline
Mike P  Offline
AZ
“…..It does have the fender mounted spare, I wish it didn't, I bought a weld in patch for that from a JR's PT50 site, but it seems a bit too small, like 1/4-3/8"……”
Wow that’s quite a gap. I ended up making my own patch from a junk fender of that era (33 Chevy if I remember correctly).
I wonder if you could do kind of what I did and cut the bucket out right below the flange it’s spot welded to. The tabs could be used to help fill the gaps. I didn’t have a gap problem but I bent several of the taps up to hold the patch up while I welded it in (and then cut the tabs off from the bottom when I was done).
[Linked Image]tabs by M Patterson, on Flickr
Over all it worked out well.
[Linked Image]welded1 by M Patterson, on Flickr
“………found the windshield crank that goes in the center of the dash, I don't have the mechanism, not sure what I will do there…….”
I ran in to the same problem and I really wanted to have a crank out windshield. The mechanism is pot metal and I’ve yet to come across one that isn’t broken or repairable. It made a good hole to stuff the oil pressure gauge in. I just ran a small bead of silicone around the windshield frame to seal the windshield in (I can get a thin knife in to cut the silicone if I ever have to remove the windshield).
Good luck on your search.
Re: 1938 Dodge truck parts [Re: Mike P] #3152046
06/16/23 01:13 PM
06/16/23 01:13 PM
My body guy is going to weld a few braces just below the surface of the fender to see just how bad the gap is, then figures things from there.
I don't even know what that windshield mechanism even looks like, just got a shop manual, it should show some sort of pic or drawing of it, I would like to have the crank work and push the windshield just for the cool factor, but I am adding AC to the truck for the "real" cool part, lol.
Does anybody know the sizes/lengths of the hardware for the window garnishes, haven't gotten to that point, but I try to keep ahead of things like that as I go along. From what I understand, the battery was mounted behind the passenger front tire, may move that.
Re: 1938 Dodge truck parts [Re: johnnycuda] #3152054
06/16/23 01:48 PM
06/16/23 01:48 PM
moparx Offline
moparx  Offline
really cool truck. up
beer
