Crank pulley holes #3151004
06/12/23 08:42 PM
06/12/23 08:42 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Any idea if these two holes on the side of this crank pulley came that way from Chrysler? At first I thought that someone had drilled them, but they look a little too perfectly placed.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Crank pulley holes [Re: cdstl] #3151039
06/12/23 10:58 PM
06/12/23 10:58 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
I've seen drill indents on many, but never thru holes.
But possible I guess.
Re: Crank pulley holes [Re: cdstl] #3151040
06/12/23 10:59 PM
06/12/23 10:59 PM
That is a first in my opinion, not stock tsk
I've seen a lot of the thin dampeners drilled for balancing,. no pulleys ever, or heard of either shruggy
Pulleys can be changed, why would the factory make that pulley only good on that motor work tsk
Get another one and put that one on the coffee table whistling grin
Re: Crank pulley holes [Re: Cab_Burge] #3151054
06/13/23 12:52 AM
06/13/23 12:52 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Yeah, weird. I was cleaning up a bunch of pulleys and decided not to fool with this one.
