Re: Turbo forum recommendations help
[Re: FastmOp]
#3148925
06/05/23 03:51 PM
06/05/23 03:51 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Turbomustangs.com
Holley, Haltech, Fueltech . For EFI. I'm getting the parts together to convert Ka-Blue-E to Holley. Fueltech would have been the other I considered but Holley is an hour from me.
I currently have FAST and it's fine but an older system and antiquated. Ah, so you are the other one (besides me) that is still using Classic Fast! ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: FastmOp]
#3149018
06/05/23 11:12 PM
06/05/23 11:12 PM
Posts: 2,260 IL
furious70
IL
I'm also running classic FAST, a circa 2000 unit. I have bought 2 unknown SKU back up boxes in the last couple years just incase I need components to keep mine living
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Cab_Burge]
#3149029
06/06/23 12:16 AM
06/06/23 12:16 AM
Posts: 714 Lake Villa Il
INTMD8
Lake Villa Il
What components are you looking for and what turbo do you have?
[Re: Cab_Burge]
#3149106
06/06/23 12:15 PM
06/06/23 12:15 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Holley HP minimum, preferably a Dominator. Skip the “value” priced systems. Trust me, you want on board data logging.Holley support is everywhere. I don’t have a holley system myself, but have had my hands in enough systems to feel extremely confident in recommending it.
[Re: INTMD8]
#3149425
06/07/23 03:21 PM
06/07/23 03:21 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
I'm going to buy the Edelbrock LA motor Super Victor EFI intake for direct port injectors with their fuel rail kit, Holley Terminator X ECU and all Holley EFI parts except their fuel pump to make that work on the turbocharged 360 motor in my new to me 1965 Valeant. I buying a new EFI fuel tank for the car with their in tank EFI GPA-8 fuel pump for using E85 with the turbo ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif) I haven't called Holley or Rich at Fastman EFI yet but I will to make sure which Holley EFI parts to use ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif)
[Re: Cab_Burge]
#3149428
06/07/23 03:30 PM
06/07/23 03:30 PM
TRENDZ
Milwaukee WI
Do yourself a favor and skip the terminator. Buy at least an HP.
[Re: TRENDZ]
#3149439
06/07/23 04:04 PM
06/07/23 04:04 PM
INTMD8
Lake Villa Il
Do yourself a favor and skip the terminator. Buy at least an HP. Agreed. Also would skip the efi tank and do a surge tank, I'll be making that switch myself even though mine is currently working ok.
