Turbo forum recommendations help #3148729
06/04/23 11:03 PM
06/04/23 11:03 PM
Cab_Burge Offline OP
I'm in the middle of buying EFI parts for a dry throttle body EFI turbocharged motors, I'm not familiar with turbos or EFI system so I would like to visit some turbo forum to learn from those that are running them now help
All help appreciated bow up
Re: Turbo forum recommendations help [Re: Cab_Burge] #3148747
06/05/23 06:00 AM
06/05/23 06:00 AM
Odessa, Fl
blowndart Online content
blowndart  Online Content
Odessa, Fl
This one has some decent advice, sometimes.
https://www.yellowbullet.com/forums/turbo-charged.20/
Re: Turbo forum recommendations help [Re: blowndart] #3148872
06/05/23 01:35 PM
06/05/23 01:35 PM
thanks, I look at that site a tiny bit last night and will look at it longer later when I get ready to start buying the EFI parts up bow
I bought a complete turbo system except the guys carb from a local guy earlier this year that will be used in my next project, a 1965 Valient Signet. His car was the same year and model so bolt in on it in my car except for adding the EFI system wrench grin
I hope I don't hurt myself, the car or the new motor learning on how to work on and tune them luck
I'm shooting for around 600 HP, nothing crazy for a street car grin
Re: Turbo forum recommendations help [Re: Cab_Burge] #3148878
06/05/23 01:40 PM
06/05/23 01:40 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Turbomustangs.com
Holley, Haltech, Fueltech . For EFI.
I'm getting the parts together to convert Ka-Blue-E to Holley. Fueltech would have been the other I considered but Holley is an hour from me.
I currently have FAST and it's fine but an older system and antiquated.
Re: Turbo forum recommendations help [Re: Cab_Burge] #3148879
06/05/23 01:41 PM
06/05/23 01:41 PM
Odessa, Fl
Odessa, Fl
Re: Turbo forum recommendations help [Re: FastmOp] #3148925
06/05/23 03:51 PM
06/05/23 03:51 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Originally Posted by FastmOp
Turbomustangs.com
Ah, so you are the other one (besides me) that is still using Classic Fast! wave
Re: Turbo forum recommendations help [Re: TheOtherDodge] #3148949
06/05/23 04:58 PM
06/05/23 04:58 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
It's still better then the throttle body deals. But lacking some of the bells and whistles of the newer stuff
Re: Turbo forum recommendations help [Re: FastmOp] #3149018
06/05/23 11:12 PM
06/05/23 11:12 PM
IL
furious70 Offline
furious70  Offline
IL
I'm also running classic FAST, a circa 2000 unit. I have bought 2 unknown SKU back up boxes in the last couple years just incase I need components to keep mine living
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Turbo forum recommendations help [Re: furious70] #3149024
06/05/23 11:40 PM
06/05/23 11:40 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Re: Turbo forum recommendations help [Re: Cab_Burge] #3149029
06/06/23 12:16 AM
06/06/23 12:16 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
What components are you looking for and what turbo do you have?
Re: Turbo forum recommendations help [Re: Cab_Burge] #3149106
06/06/23 12:15 PM
06/06/23 12:15 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Holley HP minimum, preferably a Dominator. Skip the “value” priced systems. Trust me, you want on board data logging.Holley support is everywhere. I don’t have a holley system myself, but have had my hands in enough systems to feel extremely confident in recommending it.
Re: Turbo forum recommendations help [Re: INTMD8] #3149425
06/07/23 03:21 PM
06/07/23 03:21 PM
I'm going to buy the Edelbrock LA motor Super Victor EFI intake for direct port injectors with their fuel rail kit, Holley Terminator X ECU and all Holley EFI parts except their fuel pump to make that work on the turbocharged 360 motor in my new to me 1965 Valeant.
I buying a new EFI fuel tank for the car with their in tank EFI GPA-8 fuel pump for using E85 with the turbo luck
I haven't called Holley or Rich at Fastman EFI yet but I will to make sure which Holley EFI parts to use luck
Re: Turbo forum recommendations help [Re: Cab_Burge] #3149428
06/07/23 03:30 PM
06/07/23 03:30 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Do yourself a favor and skip the terminator. Buy at least an HP.
Re: Turbo forum recommendations help [Re: TRENDZ] #3149439
06/07/23 04:04 PM
06/07/23 04:04 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Agreed.
Also would skip the efi tank and do a surge tank, I'll be making that switch myself even though mine is currently working ok.
