Source for brake backing plates ??? #3148696
06/04/23 08:28 PM
06/04/23 08:28 PM
Ontario, Canada
Stanton Online content OP
Don't question me!
Stanton  Online Content OP
Don't question me!
Ontario, Canada
Anyone reproducing brake backing plates for 8-3/4's or Dana's ??
Re: Source for brake backing plates ??? [Re: Stanton] #3148723
06/04/23 10:03 PM
06/04/23 10:03 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Doc Diff used to sell the entire setup, might ask him.
https://www.doctordiff.com/mopar-drum-brake-assembly.html
Re: Source for brake backing plates ??? [Re: Sniper] #3148733
06/04/23 11:32 PM
06/04/23 11:32 PM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
I haven't seen any repros out there. I had been looking for a decent pair of 11x2.5 plates for awhile.
I got lucky and found a newer pair of NOS ones off ebay about 5 months ago.
Re: Source for brake backing plates ??? [Re: skdmark] #3148735
06/04/23 11:54 PM
06/04/23 11:54 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Are the backing plates 8 3/4 specific? I've been tripping over a set I pulled off a '77 9 1/4 rear months ago.
John
Re: Source for brake backing plates ??? [Re: SattyNoCar] #3148740
06/05/23 01:31 AM
06/05/23 01:31 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
That's what I get them from, Dodge vans with 9-1/4". If I remember, they have four bolts, but the plates have five holes.
Re: Source for brake backing plates ??? [Re: 375inStroke] #3148778
06/05/23 08:40 AM
06/05/23 08:40 AM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Reading some other posts (some quite old) it seems ALL Mopar diffs can use the same backing plates - 8-1/4, 8-3/4, 9-1/4, 9-3/4 - all interchangeable. HOWEVER, the plates will differ (obviously) between 10" and 11". Not so obviously they also differ depending on the shoe width - a wider shoe will need a plate with more offset from the mounting flange - and this will not be as visibly noticeable as the diameter!
Dr Diff currently (as of Friday) has no backing plates for his kits.
Worth noting is that virtually everything - EXCEPT backing plates - is available from RockAuto, etc.
Re: Source for brake backing plates ??? [Re: Stanton] #3148779
06/05/23 08:57 AM
06/05/23 08:57 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I have a set of 11" drum setup from an 88 M body on the 8 3/4 in my 65 Cuda (cut down C body axle).
Re: Source for brake backing plates ??? [Re: Sniper] #3148783
06/05/23 09:12 AM
06/05/23 09:12 AM
VA
dragon slayer Offline
VA
Are there pictures that show the difference in backing plate for the shoe width?
Re: Source for brake backing plates ??? [Re: dragon slayer] #3148822
06/05/23 11:22 AM
06/05/23 11:22 AM
BDW Offline
BDW  Offline
Re: Source for brake backing plates ??? [Re: BDW] #3148911
06/05/23 03:27 PM
06/05/23 03:27 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
What magazine and issue (year/month) is that article from?
Re: Source for brake backing plates ??? [Re: Stanton] #3149025
06/05/23 11:45 PM
06/05/23 11:45 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
That was in mopar action sometime in the past year or so.
I want my fair share
